* Makefile.am: Remove headers. Remove CHANGELOG.
* configure.ac: Use AC_CONFIG_SRCDIR([pppd]).
Move networking libraries to c/src/exec/libnetworking
* configure.ac: Reflect Moval.
* Makefile.am: Reflect Moval.
* wrapup/Makefile.am: Reflect Moval.
* rtems_telnetd/pty.c: Remove bsp.h. Include <rtems/bspIo.h>.
* rtems/mkrootfs.c: Add (relocated from libmisc/rootfs).
* rtems/mkrootfs.h: Ditto.
* rtems/Makefile.am: Reflect changes above.
* sys/ioctl.h: Remove.
* sys/sockio.h: Remove.
* sys/filio.h: Remove.
* sys/Makefile.am: Reflect changes above.
* ChangeLog: Corrected -- entry should have been in libchip.
* bootloader/Makefile.am, console/Makefile.am, pci/Makefile.am:
Per PR215 address the following issues:
- _IO_BASE, _ISA_MEM_BASE and PCI_DRAM_OFFSET
are no longer defined by libcpu (powerpc/shared/include/io.h)
but by the BSP (who is the only one to know the values)
- the affected BSP (shared/motorola) headers have been fixed
in a separate "libbsp/powerpc/shared" patch.
- the DEC 21140 driver (libchip/network/dec21140.c) has been
fixed to use PCI_DRAM_OFFSET instead of PREP_PCI_DRAM_OFFSET.
and PCI_MEM_BASE instead of PREP_ISA_MEM_BASE. PCI_MEM_BASE
is to be defined by the BSP who is using this driver.
- the DEC driver also has been fixed to use the newer
rtems_bsp_delay_in_bus_cycles() instead of the obsolete
delay_in_bus_cycles().
* network/dec21140.c: Per PR215 address the following issues:
* machine/in_cksum.h: Per PR200 fix multi-line inline assembly
to satisfy gcc 3.1 and newer.
* netinet/in_cksum_i386.c: Add volatile so the more agressive
optimization in gcc 3.1 does not reorder things.
* pppd/utils.c: Adapt to gcc-3.x.
* c/src/libnetworking/rtems/rtems_bsdnet.h: To address PR59, added
the drv_ctrl driver control block field to the ifconfig network driver
structure. This field is needed by the i82586 driver which was ported
from NetBSD as it had better hardware abstraction.
* ChangeLog: Fix dates.
* libc/rcmd.c: Replace __rtems w/ __rtems__.
* arpa/Makefile.am: Remove AUTOMAKE_OPTIONS.
* kern/Makefile.am: Remove AUTOMAKE_OPTIONS.
* lib/Makefile.am: Remove AUTOMAKE_OPTIONS.
* libc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* machine/Makefile.am: Remove AUTOMAKE_OPTIONS.
* net/Makefile.am: Remove AUTOMAKE_OPTIONS.
* netinet/Makefile.am: Remove AUTOMAKE_OPTIONS.
* nfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* pppd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_servers/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_telnetd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_webserver/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sys/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR144
* nfs/bootp_subr.c bootpc_init(): Performs a write to memory address
0 when called for the first time. This is done when trying to clear
the variable "dhcp_hostname".
* PR162
* net/if_ppp.c ppp_txdaemon(), net/if_pppvar.h pppstart(): Local
variables must not be used in a device write routines. Now
ppp_softc structure have own character for writing to device
(sc_outchar). I think that converting local variables to static
is not a right solution, because problems will occur in the case
of two or more ppp instances.
* net/ppp_tty.c pppstart(): Type of the ioffset variable must be
u_long, otherwise in the case of the big output packet endless
loop may occur.
* net/if_ppp.c, net/ppp_tty.c: Initial preparations for multiple
PPPD connections.
* PR158
* libc/rcmd.c, libc/rcmd.c: Enable the rcmd() library call by
commenting out the parts that deal with signals. This enables
RTEMS to 'rsh' command to a server connecting fd to remote stdio.
The 'server-side' parts of this file which deal with authentication
are disabled since they are not needed.
* net/if_ppp.c, pppd/auth.c, pppd/chat.c, pppd/pppd.h,
pppd/sys-rtems.c: Add server with pap-authorization
capabilities as well as eliminate some warnings.
* net/radix.c: Properly handle fetching the default route when there
is no route. This was a bug in the original FreeBSD code and this
fix is from an updated version of their code.
* pppd/rtemspppd.c (rtems_pppd_disconnect): Modified to avoid bringing
the link down too fast.
NOTE: Mike reports successfully running at 56K baud on a direct link.
* pppd/rtemsdialer.h: New file missed in previous commit.
* Nice Update of PPPD support which eliminates the
requiremetn that drivers be in the termios TASK_DRIVEN mode.
Mike did significant testing and reports that it seems to be
more stable and handle larger packets better. This patch
replaces the termios tasks with more general pppd network
driver tasks. The functions pppinput() and pppstart() get
called from the interrupt service routine.
* Makefile.am, configure.ac, net/Makefile.am, net/bpf.h,
net/ethernet.h, net/if.c, net/if.h, net/if_arp.h, net/if_dl.h,
net/if_ethersubr.c, net/if_llc.h, net/if_loop.c, net/if_ppp.h,
net/if_pppvar.h, net/if_types.h, net/netisr.h, net/ppp-comp.h,
net/ppp_defs.h, net/pppcompress.h, net/radix.c, net/radix.h,
net/raw_cb.c, net/raw_cb.h, net/raw_usrreq.c, net/route.c,
net/route.h, net/rtsock.c, pppd/Makefile.am, pppd/README,
pppd/STATUS, pppd/auth.c, pppd/cbcp.c, pppd/ccp.c, pppd/ccp.h,
pppd/chap.c, pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h,
pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c,
pppd/ipcp.h, pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h,
pppd/magic.c, pppd/magic.h, pppd/options.c, pppd/patchlevel.h,
pppd/pathnames.h, pppd/pppd.8, pppd/pppd.h, pppd/rtemsmain.c,
pppd/rtemspppd.c, pppd/rtemspppd.h, pppd/sys-rtems.c, pppd/upap.c,
pppd/upap.h, pppd/utils.c, pppd/example/README,
pppd/example/netconfig.h, wrapup/Makefile.am: Modified.
* net/bsd-comp.c, net/if_ppp.c, net/ppp-deflate.c, net/ppp.h,
net/ppp_tty.c, net/pppcompress.c, net/zlib.c, net/zlib.h: New file.
* modem/, modem/.cvsignore, modem/Makefile.am, modem/ppp.c,
modem/ppp.h, modem/ppp_tty.c, modem/pppcompress.c: Subdirectory removed.
* rtems_telnetd/pty.c: Move config.h to were it belongs.
Remove printf (Reported by Till Straumann
<strauman@SLAC.Stanford.EDU>).
* lib/tftpDriver.clib/tftpDriver.c: Fix TFTP block number checking.
* pppd/sys-rtems.c: Remove unused variable status from
dodefaultroute.
* lib/tftpDriver.c: Remove set_errno_and_return_minus_one, include
<rtems/seterr.h>.
* lib/tftpDriver.c: Allow chdir() to work on TFTP `directories'
(path names with a / at the end) while disallowing open() operations
on TFTP `directories'.
* lib/tftpDriver.c: Restore write capability.
* arpa/Makefile.am: Remove stray lines.
* lib/tftpDriver.c: Properly handles ../ components in chdir() and
open() operations within the TFTP file system.
* rootfs/mkrootfs.c, rootfs/mkrootfs.h: Fixed typo.
* configure.in: Remove.
* Update to stable working state. Congratulations Mike! :)
* modem_example: Directory removed.
* modem_example/16550.h, modem_example/README, modem_example/modem.c,
modem_example/modem.h, modem_example/ppp.c, modem_example/ppp.h,
modem_example/pppcompress.c: Files removed.
* pppd/example/pppd.options: New file.
* pppd/README, pppd/STATUS, pppd/cbcp.c, pppd/cbcp.h, pppd/chat.c,
pppd/pppd.h, pppd/rtemsmain.c: Updated.
* lib/tftpDriver.c: Add limited chdir() support to the TFTP
filesystem.
* machine/Makefile.am: Use 'PREINSTALL_FILES ='.
* net/Makefile.am: Use 'PREINSTALL_FILES ='.
* netinet/Makefile.am: Use 'PREINSTALL_FILES ='.
* vm/Makefile.am: Use 'PREINSTALL_FILES ='.
* pppd/Makefile.am: Use 'PREINSTALL_FILES ='.
* sys/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems_servers/Makefile.am: Use 'PREINSTALL_FILES ='.
* arpa/Makefile.am: Use 'PREINSTALL_FILES ='.
* nfs/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems_webserver/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems_telnetd/Makefile.am: Use 'PREINSTALL_FILES ='.
* Makefile.am: Use PREINSTALL_FILES = to make automake-1.5 happy.
* lib/tftpDriver.c: Add some debugging capability.
* nfs/bootp_subr.c, rtems/rtems_bootp.c, rtems/rtems_bsdnet.h,
rtems/rtems_bsdnet_internal.h Added support for populating the
initial "root" filesystem with information obtained via the DHCP
response.
* Added support for populating the initial "root" filesystem
with information obtained via the DHCP response.
* rootfs: New directory.
* rootfs/.cvsignore, rootfs/Makefile.am, rootfs/mkrootfs.c,
rootfs/mkrootfs.h: New files.
* configure.in, Makefile.am: Modified to reflect addition.
* pppd/STATUS: Updated by Joel based upon email from Mike.
* pppd/cbcp.c, pppd/cbcp.h: Readded files. These support callback
functionality that has not even been compiled under RTEMS yet.
* pppd/example/Makefile: Removed.
* pppd/example/Makefile-user: Added was Makefile. Renamed to
avoid bootstrap -c clobbering it.
* Update of PPPD to 2.3.11 from 2.3.5 and addition of an example
application. Mike's notes on the modifications:
- renamed error() function because of namespace problems
- removed calls to the exit() funciton
- removed extra files from the pppd source directory
- defined pppd task constant values in rtemspppd.h
- modifyied example code to get actual tick per second value
- placed the pppd 2.3.11 man page file (pppd.8) into the pppd
directory
* pppd/cbcp.c, pppd/cbcp.h, pppd/main.c, pppd/ppp_tty.c,
pppd/pppmain.c, pppd/rtems-ppp.c, pppd/rtems-ppp.c: Deleted.
* pppd/pppd.8, pppd/rtemsmain.c, pppd/rtemspppd.c, pppd/rtemspppd.h,
pppd/sys-rtems.c, pppd/utils.c, pppd/example/Makefile,
pppd/example/README, pppd/example/init.c, pppd/example/netconfig.h,
pppd/example/ppp.conf, pppd/example/pppdapp.c, pppd/example/system.h:
New files.
* modem/ppp_tty.c, net/if_ppp.h, pppd/Makefile.am, pppd/README,
pppd/STATUS, pppd/auth.c, pppd/ccp.c, pppd/ccp.h, pppd/chap.c,
pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h, pppd/chat.c,
pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c, pppd/ipcp.h,
pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h, pppd/magic.c,
pppd/pathnames.h, pppd/pppd.h, pppd/upap.c, pppd/upap.h: Modified.
* rtems_telnetd/.cvsignore: New file.
* Makefile.am, configure.in, rtems_servers/Makefile.am,
rtems_servers/telnetd.c, rtems_servers/telnetd.h,
rtems_telnetd/Makefile.am, rtems_telnetd/README, rtems_telnetd/icmds.c,
rtems_telnetd/pty.c, rtems_telnetd/pty.h, rtems_telnetd/telnetd.c,
rtems_telnetd/telnetd.h, wrapup/Makefile.am:
- pty and telnetd have a new subdir rtems_telnetd to avoid
the side effect when ftpd change.
- the tcp/ip stats have been implemented into icmds.c and
started when telnetd daemon is started.
* rtems_servers/telnetd.c, rtems_servers/telnetd.h: Removed.
* rtems_telnetd: New directory.
* rtems_telnetd/Makefile.am, rtems_telnetd/README,
rtems_telnetd/icmds.c, rtems_telnetd/pty.c, rtems_telnetd/pty.h,
rtems_telnetd/telnetd.c, rtems_telnetd/telnetd.h: New files.
* rtems_servers/Makefile.am: Deleted blank lines.
* rtems_servers/telnetd.c, shell/telnetd.h: Moved from libmisc/shell
so the network stack to address network depenendency.
* rtems_servers/Makefile.am: Modified to reflect above.
