that contains:
* Removes MKLIB
handling)
./bootstrap
Janovetz <janovetz@tempest.ece.uiuc.edu> to return a status from
network initialization rather than panic'ing. It changes a bunch
of rtems_panics to printfs and returns a status from
rtems_bsdnet_initialize_network().
is not strict ANSI.
more flexible about the error status returned from a timeout.
report by Nick.SIMON@syntegra.bt.co.uk:
TFTP uses UDP and UDP packets are prime targets for getting dropped when
the network gets busy. I want the number of retries quite large in my
application. I see that PACKET_REPLY_MILLISECONDS is, in fact, not
being used.
functionality. This puts RTEMS in near compliance with the network
functionality defined in the first draft of the EL/IX API. Comments
follow:
With the attached changes to the libnetworking/libc/Makefile.in, RTEMS
provides all the functions listed in section 4.14 of the EL/IX document
except:
socketpair
if_nametoindex
if_indextoname
if_nameindex
if_freenameindex
Some of the routines which get information from files may be of limited
use unless an application sets up the files somehow (TFTP/untar from
host, etc.), but at least RTEMS is pretty much fully buzzword compliant
with the networking section of the EL/IX API.
This was used on a mpc823 based system.
system table from when the rtems_filesystem_operations_table structure changed
and the initializer in libnetworking/lib/tftpDriver.c did not get
updated.
Tomasz only tested this on the mpc823.
The official site for the original source for this PPP implementation is:
ftp://cs.anu.edu.au/pub/software/ppp
NOTE: As of 11/30/1999, the current version of this source is 2.3.10.
in the previous commits.
to UnixWare (UW).
POSIX API is disabled.
Patches against 1105 snapshot to add NTP server support to network
configuration/BOOTP.
EPICS needs a synchronized time-of-day clock. This patch is the changes
needed to get NTP server information from a BOOTP server.
This patch also adds NTP server information to the network configuration
structure, too.
pack warnings in uemf.h.
<valette@crf.canon.fr> to add a port of the GoAhead web server
(httpd) to the RTEMS build tree. They have successfully used
this BSP on i386/pc386 and PowerPC/mcp750.
Mark and Joel spoke with Nick Berliner <nickb@goahead.com> on
26 Oct 1999 about this port and got verbal approval to include
it in RTEMS distributions.
report from Philip A. Prindeville <philipp@zembu.com>:
I was working on a device driver for a certain ethernet chipset that
occassionally wraps in its buffer, and causes a resulting mbuf chain
with only a few dozen bytes in the first mbuf of the chain.
I wouldn't have thought this would be a problem, until I ran some
stress tests that flooded the ethernet receiver with packets and
started to get panics here:
250
251 if (m->m_pkthdr.len < sizeof(struct ip))
252 goto tooshort;
253
254 #ifdef DIAGNOSTIC
255 if (m->m_len < sizeof(struct ip))
256 panic("ipintr mbuf too short");
257 #endif
258
259 if (m->m_len < sizeof (struct ip) &&
260 (m = m_pullup(m, sizeof (struct ip))) == 0) {
261 ipstat.ips_toosmall++;
262 return;
263 }
264 ip = mtod(m, struct ip *);
and the panic was at line 256. But if I #undef'd DIAGNOSTICS,
then the m_pullup() at line 260 does the right thing and the packet
ends up being processed just fine.
So I started wondering, (a) why was the test checking for
something that apparently wasn't a fatal condition but rather
one that is subsequently recovered from a couple of lines later
and (b) why panic as a diagnostic "aid" from a recoverable
condition rather than just (say) log a message to the console?
All of this seems overly severe for no reason that is readily
apparent to me.
now prototypes the malloc family in stdlib.h. This causes conflicts
with the way the network stack overrides the definitions of malloc.
As best I (being Joel) can tell, commenting stdlib.h out keeps the
files compiling and referencing the desired malloc/free but results
in more warnings.
a top level more independently configured package.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
The old system would panic when the loopback interface was included as
part of the network initialation structures. With the printf you get an
message, but the interface is still properly initialized.
the minor number indicated the port number to try.
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
dependencies of "Makefile".
--enable-maintainer-mode.
I get the following warning when compiling the latest snapshot. I had
a quick look at the source -- it certainly looks to me like this is a
real bug.
../../../../src/rtems-19990709/c/src/lib/libc/mount.c:97: warning:
`options' might be used uninitialized in this function
Also, I changed the TFTP test program and TFTP driver to reflect the
changes in the way paths are passed to the TFTP driver. The TFTP driver
now needs a proper `dotted-decimal' hostname as the second component of
the path name.
