* libnetworking/pppd/Makefile.am,
libnetworking/rtems_servers/Makefile.am,
libnetworking/rtems_telnetd/Makefile.am,
libnetworking/rtems_webserver/Makefile.am, optman/Makefile.am,
support/Makefile.am: Don't include lib.am.
* libnetworking/rtems_webserver/Makefile.am: Add PREINSTALL_DIRS.
* libnetworking/rtems_telnetd/Makefile.am: Add PREINSTALL_DIRS.
* libnetworking/rtems_servers/Makefile.am: Add PREINSTALL_DIRS.
* libnetworking/pppd/Makefile.am: Add PREINSTALL_DIRS.
* ChangeLog: Merge-in libnetworking/ChangeLog.
* libnetworking/ChangeLog: Remove.
* Makefile.am: Remove wrapup.
* pppd/Makefile.am: Build libpppd.
Use automake-compilation rules.
* rtems_servers/Makefile.am: Build libftpd.
* rtems_telnetd/Makefile.am: Build libtelnetd.
* rtems_webserver/Makefile.am: Build libhttpd.
* wrapup/Makefile.am: Remove (Unused).
* pppd/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* rtems_servers/Makefile.am: Ditto.
* rtems_telnetd/Makefile.am: Ditto.
* rtems_webserver/Makefile.am: Ditto.
* pppd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_servers/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_telnetd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_webserver/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Cosmetics.
* pppd/Makefile.am: Cosmetics.
* pppd/Makefile.am: Remove all-local: $(ARCH).
* rtems_servers/Makefile.am: Remove all-local: $(ARCH).
* rtems_telnetd/Makefile.am: Remove all-local: $(ARCH).
* rtems_webserver/Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Reformat. Apply dirstamps to preinstallation.
* pppd/Makefile.am: Ditto.
* wrapup/Makefile.am: Ditto.
pppd/Makefile.am: Reflect having moved automake.
rtems_servers/Makefile.am: Reflect having moved automake.
rtems_telnetd/Makefile.am: Reflect having moved automake.
rtems_webserver/Makefile.am: Reflect having moved automake.
* configure.ac: Remove (Merged into ../configure.ac).
* .cvsignore, Makefile.am, pppd/Makefile.am,
rtems_servers/Makefile.am, rtems_telnetd/Makefile.am,
rtems_webserver/Makefile.am, wrapup/Makefile.am:
Reflect having merged configure.ac into ../configure.ac
* pppd/chat.c: Removed warnings.
* pppd/fsm.c: Make peer_mru global again.
* pppd/magic.c: Remove *rand48.
* pppd/chap.c: Remove prototypes of *rand48.
* rtems_webserver/cgi.c, rtems_webserver/sockGen.c,
rtems_webserver/umui.c, rtems_webserver/websSSL.c,
rtems_webserver/websSSL.h, rtems_webserver/websda.c,
rtems_webserver/websda.h: New files. Not included in previous commit.
* rtems_webserver/NOTES, rtems_webserver/asp.c,
rtems_webserver/balloc.c, rtems_webserver/default.c,
rtems_webserver/ej.h, rtems_webserver/ejIntrn.h,
rtems_webserver/ejlex.c, rtems_webserver/ejparse.c,
rtems_webserver/emfdb.c, rtems_webserver/emfdb.h,
rtems_webserver/form.c, rtems_webserver/h.c,
rtems_webserver/handler.c, rtems_webserver/license.txt,
rtems_webserver/md5.h, rtems_webserver/md5c.c,
rtems_webserver/mime.c, rtems_webserver/misc.c,
rtems_webserver/ringq.c, rtems_webserver/rom.c,
rtems_webserver/security.c, rtems_webserver/sock.c,
rtems_webserver/sym.c, rtems_webserver/uemf.c,
rtems_webserver/uemf.h, rtems_webserver/um.c, rtems_webserver/um.h,
rtems_webserver/url.c, rtems_webserver/value.c,
rtems_webserver/wbase64.c, rtems_webserver/webcomp.c,
rtems_webserver/webpage.c, rtems_webserver/webrom.c,
rtems_webserver/webs.c, rtems_webserver/webs.h,
rtems_webserver/websuemf.c, rtems_webserver/wsIntrn.h:
Update to GoAhead Webserver 2.1.4. The following URL is
the release notes from GoAhead.
http://data.goahead.com/Software/Webserver/2.1.4/release.htm
I have only done a minimal amount of testing (i.e. the network
demo program works fine). Please try this out and let me know
if it works. The patch needs to be applied on the
c/src/libnetworking/rtems_webserver directory.
PR 371/pppd
* pppd/auth.c, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/lcp.c,
pppd/options.c, pppd/pppd.h, pppd/rtemsmain.c, pppd/rtemspppd.c:
Change many symbols to static. There are still global symbols in
rtemspppd.h which might need to be changed or converted into member
of a structure which is dereferenced with a pointer that is managed
as a per task variable. But this patch should avoid many conflicts.
* pppd/chat.c: Convert routines with common names to static. This
included get_char(), put_char(), and character() among others.
* pppd/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Eliminate *_O_FILES.
* pppd/auth.c, rtems_webserver/uemf.h: Removed warnings.
* rtems_webserver/socket.c, rtems_webserver/uemf.h: Removed
warnings.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* pppd/ipcp.c, rtems_servers/ftpd.c: Add include files to resolve
warnings.
* rtems_webserver/md5.h: Add missing newline.
* rtems_webserver/webmain.c: Commented out rootWeb to eliminate warning.
* rtems_servers/ftpd.c: Remove unused variable buf.
* pppd/md5.c: #include <string.h> to make gcc31 happy.
* rtems_telnetd/telnetd.c: #include <string.h> to make gcc31 happy.
* rtems_webserver/webmain.c: Remove unused variable dir, cp.
* pppd/utils.c: Include i960 in varargs conditional to avoid error.
* pppd/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_servers/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_telnetd/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_webserver/Makefile.am: Use .$(OBJEXT) instead of .o.
* pppd/chap.c, pppd/fsm.c, pppd/fsm.h, pppd/upap.c: Per PR255
fix prototype mismatches.
* rtems_webserver/misc.c: Per PR236 eliminate definition of strnlen().
* wrapup/Makefile.am: Build libnetapps.a.
Don't preinstall libnetapps.a
* Makefile.am: Remove headers. Remove CHANGELOG.
* configure.ac: Use AC_CONFIG_SRCDIR([pppd]).
Move networking libraries to c/src/exec/libnetworking
* configure.ac: Reflect Moval.
* Makefile.am: Reflect Moval.
* wrapup/Makefile.am: Reflect Moval.
* rtems_telnetd/pty.c: Remove bsp.h. Include <rtems/bspIo.h>.
* rtems/mkrootfs.c: Add (relocated from libmisc/rootfs).
* rtems/mkrootfs.h: Ditto.
* rtems/Makefile.am: Reflect changes above.
* sys/ioctl.h: Remove.
* sys/sockio.h: Remove.
* sys/filio.h: Remove.
* sys/Makefile.am: Reflect changes above.
* ChangeLog: Corrected -- entry should have been in libchip.
* bootloader/Makefile.am, console/Makefile.am, pci/Makefile.am:
Per PR215 address the following issues:
- _IO_BASE, _ISA_MEM_BASE and PCI_DRAM_OFFSET
are no longer defined by libcpu (powerpc/shared/include/io.h)
but by the BSP (who is the only one to know the values)
- the affected BSP (shared/motorola) headers have been fixed
in a separate "libbsp/powerpc/shared" patch.
- the DEC 21140 driver (libchip/network/dec21140.c) has been
fixed to use PCI_DRAM_OFFSET instead of PREP_PCI_DRAM_OFFSET.
and PCI_MEM_BASE instead of PREP_ISA_MEM_BASE. PCI_MEM_BASE
is to be defined by the BSP who is using this driver.
- the DEC driver also has been fixed to use the newer
rtems_bsp_delay_in_bus_cycles() instead of the obsolete
delay_in_bus_cycles().
* network/dec21140.c: Per PR215 address the following issues:
* machine/in_cksum.h: Per PR200 fix multi-line inline assembly
to satisfy gcc 3.1 and newer.
* netinet/in_cksum_i386.c: Add volatile so the more agressive
optimization in gcc 3.1 does not reorder things.
* pppd/utils.c: Adapt to gcc-3.x.
