* | Added header files per request from Chris Johns to avoid problems | Joel Sherrill | 1998-10-12 | 1 | -0/+4 |
| | | | | in include file order. | ||||
* | Patch from Eric Norum <eric@skatter.usask.ca>: | Joel Sherrill | 1998-09-29 | 1 | -3/+2 |
| | | | | | | | | | | | | | | Remember the test to see if a socket could be read and written at the same time by two different tasks? I discovered that if both tasks attempt to close the socket a panic can occur from inside the BSD code. Closing the same socket twice from two different threads is certainly an error, but a panic is not the greatest error reporting method :-) The following small change to the socket close routine should reduce the chances of the panic. | ||||
* | Patch from Eric Norum <eric@skatter.usask.ca>: | Joel Sherrill | 1998-09-21 | 1 | -29/+101 |
| | | | | | | | Here's a patch to make the rtems_showroute routine a little more useful. For `host' route table entries the link-level address is now displayed. This is equivalent to the old `show arp table' information displayed by the KA9Q code. | ||||
* | Patch from Eric Norum and David Fiddes to put ColdFire support in | Joel Sherrill | 1998-09-21 | 1 | -8/+9 |
| | | | | the inet checksum routine. | ||||
* | Patch from "David J. Fiddes" <D.J@fiddes.surfaid.org>: | Joel Sherrill | 1998-09-11 | 1 | -126/+37 |
| | | | | | | | | | | | I've fixed a few minor probs with the optimised version that Eric put together for me the other day and sent the fixes back to him. Provided he doesn't have a problem with it we've got a pretty solid in_cksum for the ColdFire as well as straight m68k. I've enclosed my updated in_cksum_m68k.c At the moment my own bottlenecks are elsewhere...as my driver is pulling 16bit data chunks through a libchip-esq access routine from the chip which for a polled I/O device is never going to be quick. | ||||
* | Patch from David Fiddes <D.J.Fiddes@hw.ac.uk> to make this compile | Joel Sherrill | 1998-09-10 | 1 | -1/+1 |
| | | | | for the ColdFire. | ||||
* | Patch from Eric Norum <eric@skatter.usask.ca> to fix a cryptic error | Joel Sherrill | 1998-09-10 | 1 | -1/+3 |
| | | | | message after comments from Eric Valette <valette@crf.canon.fr>. | ||||
* | Fixed spacing. More comments from Eric Norum need to be addressed. | Joel Sherrill | 1998-08-31 | 1 | -7/+7 |
* | Patch from Emmanuel Raguet <raguet@crf.canon.fr>: | Joel Sherrill | 1998-08-31 | 1 | -0/+9 |
| | | | | | I have reworked the ethernet driver for the BSP pc386 and here is the patch to apply. | ||||
* | Added i386 specific version of in_cksum.c and restructured the main | Joel Sherrill | 1998-08-21 | 3 | -151/+515 |
| | | | | file to switch out to CPU specific implementations. | ||||
* | Another missing piece. Thanks Eric. | Joel Sherrill | 1998-08-21 | 1 | -0/+3 |
* | All warnings removed. | Joel Sherrill | 1998-08-21 | 7 | -6/+25 |
* | Removed networkconfig.h since it reflects target specific initialization. | Joel Sherrill | 1998-08-21 | 1 | -2/+2 |
* | Fixed warning about pointer/integer conversion which turned out to be | Joel Sherrill | 1998-08-21 | 1 | -1/+1 |
| | | | | a missed "&" on a write. | ||||
* | Patches from Eric Norum | Joel Sherrill | 1998-08-20 | 2 | -3/+19 |
* | Added CVS Ids | Joel Sherrill | 1998-08-20 | 65 | -0/+205 |
* | Fixed many warnings. | Joel Sherrill | 1998-08-20 | 35 | -86/+162 |
* | Temporarily leave strsep out of the build. | Joel Sherrill | 1998-08-20 | 1 | -2/+4 |
* | Added missing file. | Joel Sherrill | 1998-08-20 | 1 | -1/+1 |
* | FreeBSD stack compiles for the first time (except libc/strsep.c). | Joel Sherrill | 1998-08-20 | 18 | -12/+380 |
* | Base files | Joel Sherrill | 1998-08-20 | 2 | -0/+95 |
* | Base files | Joel Sherrill | 1998-08-20 | 6 | -0/+292 |
* | Base version. | Joel Sherrill | 1998-08-20 | 1 | -0/+14 |
* | Base files | Joel Sherrill | 1998-08-19 | 216 | -0/+59975 |
