path: root/c/src/libnetworking (follow)
* 2001-01-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-023-54/+59
| | | | | * CHANGELOG: Removed. * README: Merged CHANGELOG contents as initial changes.
* 2000-12-14 Eric Norum <eric.norum@usask.ca>Joel Sherrill2000-12-142-498/+589
| | | | * lib/tftpDriver.c: Added write capability.
* 2000-12-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-086-32/+52
| | | | | | | | | | * libc/linkaddr.c: Initialized variable to remove warning. * modem/ppp.c, modem/ppp_tty.c: Made numerous variable declarations conditional on PPP_COMPRESS and PPP_FILTER. Commented out variables that were not used because the code using them was commented out. Removed totally unused variables. * modem/pppcompress.c: Added parentheses to avoid warnings. * pppd/pppmain.c: Removed numerous warnings.
* 2000-11-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-302-1/+6
| | | | | * modem/ppp_tty.c: Changed to include <rtems/termiostypes.h> since that is an RTEMS specific header file.
* 2000-11-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-303-143/+7
| | | | | * sys/ttycom.h: Moved to lib/include/sys. * Makefile.am: Modified to reflect above.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-272-1/+5
| | | | * libc/res_init.c: Fix typo - adding missing # on include.
* 2000-11-25 Antti P Miettinen <antti.p.miettinen@nokia.com>Joel Sherrill2000-11-259-0/+4833
| | | | | | | | | | | | * wrapup/Makefile.am: Added modem subdir. * configure.in, Makefile.am: Added modem subdir. * net/Makefile.am: Added if_pppvar.h, pppcompress.h. * pppd/Makefile.am: Added pppmain.c (which needs work). * pppd/chat.c, pppd/fsm.c, pppd/fsm.h, pppd/ipxcp.c, pppd/main.c, pppd/ppp_tty.c, pppd/upap.c: Changes from Thomas Doerfler <Thomas.Doerfler@imd-systems.de> and cosmetic changes by me. Actually main.c and ppp_tty.c should be scratched. The modem subdir has the real ppp_tty.c and the real pppd main is in pppmain.c.
* 2000-11-25 Eric Norum <eric.norum@usask.ca>Joel Sherrill2000-11-252-1/+9
| | | | * libc/res_init.c: Move include to avoid compiler dumping core.
* 2000-11-25 Antti P Miettinen <antti.p.miettinen@nokia.com>Joel Sherrill2000-11-2510-12/+31
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-092-1/+5
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-022-1/+5
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-313-0/+14
| | | | | | | | | | * POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * machine/types.h: Added _CLOCKID_T_ and _TIMER_T_ to be in sync with newlib's <machine/types.h>. * rtems/rtems_bsdnet_internal.h: newlib now includes definition of struct itimerval in <sys/time.h>.
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-252-1/+6
* 2000-10-19 Antti P Miettinen <anmietti@trshp.ntc.nokia.com>Joel Sherrill2000-10-193-13/+21
| | | | | | * lib/tftpDriver.c: add comments to handlers struct function pointers. * rtems/rtems_glue.c: move pointer arithmetic to be _after_ pointer has been checked against NULL.
* 2000-10-18 Chris Johns <ccj@acm.org>Joel Sherrill2000-10-182-1/+5
| | | | * pppd/ipxcp.c: Fixed a typo.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-281-0/+789
| | | | | | * rtems_webserver/Makefile.am, rtems_webserver/base64.c, rtems_webserver/base64.c: Renamed base64.c to wbase64.c. * rtems_webserver/sock.c: Added file missed in merger.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-283-4/+10
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-225-9/+24
| | | | | | | | | | * machine/types.h, pppd/pppd.h, rtems/rtems_bsdnet_internal.h, rtems_webserver/webmain.c: machine/types.h should not have included rtems.h. It is now including precisely the least amount of low level, yet portable .h files to get the basic RTEMS types defined. This rippled into other files since rtems_bsdnet_internal.h used machine/types.h to include rtems.h.
* 2000-09-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-061-5/+9
| | | | * ChangeLog: Cleanup.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0514-38/+58
| | | | | | | * kern/Makefile.am, lib/Makefile.am, libc/Makefile.am, net/Makefile.am, netinet/Makefile.am, nfs/Makefile.am, pppd/Makefile.am, rtems/Makefile.am, rtems_servers/Makefile.am, rtems_webserver/Makefile.am, wrapup/Makefile.am: Include compile.am
* 2000-09-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-052-1/+7
| | | | | | * rtems/rtems_syscall.c: Changed from O_NONBLOCK to internal RTEMS_LIBIO_FLAGS_NO_DELAY to avoid O_NONBLOCK/O_NDELAY confusion and to work with the converted flags.
* 2000-09-01 Rosimildo daSilva <rdasilva@connecttel.com>Joel Sherrill2000-09-012-1/+6
| | | | | * emfdb.c: Removed stray semi-colon. Reported on GoAhead mailing lists by Jim Rudnicki <jdrudnicki@yahoo.com>
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-0139-1847/+8718
| | | | | | | | | | | | * Merged version 2.1 of GoAhead webserver. This update was submitted by Antti P Miettinen <antti.p.miettinen@nokia.com>. * NOTES, base64.c, ejIntrn.h, emfdb.c, emfdb.h, md5.h, md5c.c, um.c, um.h: New files. * wbase64.c: Removed. * Makefile.am, asp.c, balloc.c, default.c, ej.h, ejlex.c, ejparse.c, form.c, h.c, handler.c, mime.c, misc.c, ringq.c, rom.c, security.c, socket.c, sym.c, uemf.c, uemf.h, url.c, value.c, webcomp.c, webmain.c, webpage.c, webrom.c, webs.c, webs.h, websuemf.c, wsIntrn.h: Modified.
* 2000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-012-1/+5
| | | | * netinet/tcp_input.c: Spelling corrections.
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-302-0/+128
| | | | * rtems_webserver/license.txt: New file.
* Patch from Eric Norum <eric@cls.usask.ca> to add optional support forJoel Sherrill2000-08-021-3/+47
| | | | | fast mutexes that bypass the API level to directly interface with the SuperCore.
* Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill2000-07-263-3/+3
| | | | | | | | | | | a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
* Changed name of static table versions to avoid conflict.Joel Sherrill2000-07-141-2/+2
* Patch from Chris Johns <cjohns@cybertec.com.au> so the web serverJoel Sherrill2000-06-302-3/+12
| | | | shuts down on error -- not exitting the system.
* Moved <sys/cdefs.h> to lib/include so non-networking applications couldJoel Sherrill2000-06-151-1/+1
| | | | include <sys/ioctl.h>.
* Moved <sys/cdefs.h> from libnetworking to lib/include so non-networkingJoel Sherrill2000-06-141-177/+0
| | | | | configurations could see it while including <sys/ioctl.h> and <sys/ioccom.h>.
* *** empty log message ***Joel Sherrill2000-06-143-76/+4
* Patch from Chris Johns <cjohns@cybertec.com.au> to enhance networkJoel Sherrill2000-06-142-43/+216
| | | | | | | | | | | | | initialization. This adds an interface which makes it easier to control the BSD stack from user code. The BSD stack initialise uses it. It is a sort of `function' interface for an ifconfig command. I also added support for attaching and removing interfaces. With hot swap PCI comming online support for hot swap PCI will be an important factor in "state of art" RTOS's. This is also part of a general move on my part to allow RTEMS to be configured at runtime by calls rather than table driven at initialisation.
* Merge lossage. Apparently the DOS/UNIX CRLF issue got lost.Joel Sherrill2000-06-121-1438/+1438
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-1233-500/+314
* New files added on 4.5 branch.Joel Sherrill2000-04-282-0/+0
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-1317-0/+45
| | | | adds .cvsignore.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-081-4/+2
* Patches rtems-rc-20000118-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-0330-776/+936
| | | | | | | | | | | | | | | | | that contains the automake files for libnetworking plus a couple of minor fixes. [Now only one unused/unsupported Makefile.in remains (./c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in).] To apply: patch -p1 < rtems-rc-20000118-7.diff /bin/sh rtems-rc-20000118-7.rm /bin/sh rtems-rc-20000118-7.add ./bootstrap Notes: * I have tested this one by building all BSPs for m68k, powerpc, sh and unix with toolchains built since last weekend. * I did not touch libnetworking's directory layout.
* Patch from Eric Norum <eric@cls.usask.ca> at the request of JakeJoel Sherrill2000-01-211-33/+56
| | | | | | | Janovetz <janovetz@tempest.ece.uiuc.edu> to return a status from network initialization rather than panic'ing. It changes a bunch of rtems_panics to printfs and returns a status from rtems_bsdnet_initialize_network().
* Patch from Eric Norum <eric@cls.usask.ca> to remove warnings.Joel Sherrill2000-01-211-4/+3
* Added -U__STRICT_ANSI__ to remove MANY warnings since the BSD codeJoel Sherrill2000-01-141-1/+1
| | | | is not strict ANSI.
* Removed definition of USHRT_MAX to remove lots of redefinition warnings.Joel Sherrill2000-01-101-2/+0
* Comments added and some messages translated from Polish.Joel Sherrill2000-01-032-5/+51
* Made prototype of ChapReceiveSuccess and ChapReceiveFailure match.Joel Sherrill1999-12-211-2/+2
* Patch from Eric Norum <eric@cls.usask.ca> to make the NTP handler a littleJoel Sherrill1999-12-131-1/+1
| | | | more flexible about the error status returned from a timeout.
* Correction from Eric Norum for timeout in TFTP driver following bugJoel Sherrill1999-12-131-2/+3
| | | | | | | | | report by Nick.SIMON@syntegra.bt.co.uk: TFTP uses UDP and UDP packets are prime targets for getting dropped when the network gets busy. I want the number of retries quite large in my application. I see that PACKET_REPLY_MILLISECONDS is, in fact, not being used.
* Patch from Eric Norum <eric@cls.usask.ca> to provide more networkJoel Sherrill1999-12-131-4/+7
| | | | | | | | | | | | | | | | | | | | functionality. This puts RTEMS in near compliance with the network functionality defined in the first draft of the EL/IX API. Comments follow: With the attached changes to the libnetworking/libc/Makefile.in, RTEMS provides all the functions listed in section 4.14 of the EL/IX document except: socketpair if_nametoindex if_indextoname if_nameindex if_freenameindex Some of the routines which get information from files may be of limited use unless an application sets up the files somehow (TFTP/untar from host, etc.), but at least RTEMS is pretty much fully buzzword compliant with the networking section of the EL/IX API.
* New file.Joel Sherrill1999-12-031-0/+7
