path: root/c/src/libnetworking (follow)
* Fix broken ChangeLog entries.Ralf Corsepius2003-08-181-6/+6
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-167-17/+26
| | | | | | | | | Makefile.am: Reflect having moved automake. pppd/Makefile.am: Reflect having moved automake. rtems_servers/Makefile.am: Reflect having moved automake. rtems_telnetd/Makefile.am: Reflect having moved automake. rtems_webserver/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake.
* 2003-07-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-259-89/+50
| | | | | | | | * configure.ac: Remove (Merged into ../configure.ac). * .cvsignore, Makefile.am, pppd/Makefile.am, rtems_servers/Makefile.am, rtems_telnetd/Makefile.am, rtems_webserver/Makefile.am, wrapup/Makefile.am: Reflect having merged configure.ac into ../configure.ac
* Changed entry to reference PR397.Joel Sherrill2003-06-131-0/+1
* 2003-06-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-06-132-1/+7
| | | | * pppd/chat.c: Removed warnings.
* 2003-05-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-05-282-1/+5
| | | | * pppd/fsm.c: Make peer_mru global again.
* 2003-05-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-05-163-30/+6
| | | | | * pppd/magic.c: Remove *rand48. * pppd/chap.c: Remove prototypes of *rand48.
* 2003-04-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-04-118-0/+3081
| | | | | | | * rtems_webserver/cgi.c, rtems_webserver/sockGen.c, rtems_webserver/umui.c, rtems_webserver/websSSL.c, rtems_webserver/websSSL.h, rtems_webserver/websda.c, rtems_webserver/websda.h: New files. Not included in previous commit.
* 2002-04-10 Mike Siers <mikes@poliac.com>Joel Sherrill2003-04-1138-309/+905
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * rtems_webserver/NOTES, rtems_webserver/asp.c, rtems_webserver/balloc.c, rtems_webserver/default.c, rtems_webserver/ej.h, rtems_webserver/ejIntrn.h, rtems_webserver/ejlex.c, rtems_webserver/ejparse.c, rtems_webserver/emfdb.c, rtems_webserver/emfdb.h, rtems_webserver/form.c, rtems_webserver/h.c, rtems_webserver/handler.c, rtems_webserver/license.txt, rtems_webserver/md5.h, rtems_webserver/md5c.c, rtems_webserver/mime.c, rtems_webserver/misc.c, rtems_webserver/ringq.c, rtems_webserver/rom.c, rtems_webserver/security.c, rtems_webserver/sock.c, rtems_webserver/sym.c, rtems_webserver/uemf.c, rtems_webserver/uemf.h, rtems_webserver/um.c, rtems_webserver/um.h, rtems_webserver/url.c, rtems_webserver/value.c, rtems_webserver/wbase64.c, rtems_webserver/webcomp.c, rtems_webserver/webpage.c, rtems_webserver/webrom.c, rtems_webserver/webs.c, rtems_webserver/webs.h, rtems_webserver/websuemf.c, rtems_webserver/wsIntrn.h: Update to GoAhead Webserver 2.1.4. The following URL is the release notes from GoAhead. http://data.goahead.com/Software/Webserver/2.1.4/release.htm I have only done a minimal amount of testing (i.e. the network demo program works fine). Please try this out and let me know if it works. The patch needs to be applied on the c/src/libnetworking/rtems_webserver directory.
* 2003-04-10 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-04-1010-76/+77
| | | | | | | | | | PR 371/pppd * pppd/auth.c, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/lcp.c, pppd/options.c, pppd/pppd.h, pppd/rtemsmain.c, pppd/rtemspppd.c: Change many symbols to static. There are still global symbols in rtemspppd.h which might need to be changed or converted into member of a structure which is dereferenced with a pointer that is managed as a per task variable. But this patch should avoid many conflicts.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-242-39/+4
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-112-1/+4
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-112-1/+5
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-111-1/+1
| | | | * configure.ac: AC_PREREQ(2.57).
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-111-0/+4
* 2003-02-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-02-062-14/+19
| | | | | * pppd/chat.c: Convert routines with common names to static. This included get_char(), put_char(), and character() among others.
* 2003-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-166-24/+13
| | | | | | | | | * wrapup/Makefile.am: Don't include @RTEMS_BSP@.cfg. * pppd/Makefile.am: Don't include @RTEMS_BSP@.cfg. Eliminate *_O_FILES. * rtems_servers/Makefile.am: Ditto. * rtems_webserver/Makefile.am: Ditto. * rtems_telnetd/Makefile.am: Ditto.
* 2002-11-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-043-2/+12
| | | | * pppd/auth.c, rtems_webserver/uemf.h: Removed warnings.
* 2002-10-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-313-1/+7
| | | | | * rtems_webserver/socket.c, rtems_webserver/uemf.h: Removed warnings.
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-212-3/+9
| | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
* 2002-09-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-09-073-0/+7
| | | | | * pppd/ipcp.c, rtems_servers/ftpd.c: Add include files to resolve warnings.
* 2002-09-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-09-022-1/+5
| | | | * rtems_webserver/md5.h: Add missing newline.
* 2002-08-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-312-1/+5
| | | | * rtems_webserver/webmain.c: Commented out rootWeb to eliminate warning.
* 2002-08-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-145-3/+11
| | | | | | | * rtems_servers/ftpd.c: Remove unused variable buf. * pppd/md5.c: #include <string.h> to make gcc31 happy. * rtems_telnetd/telnetd.c: #include <string.h> to make gcc31 happy. * rtems_webserver/webmain.c: Remove unused variable dir, cp.
* 2002-08-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-122-1/+5
| | | | * pppd/utils.c: Include i960 in varargs conditional to avoid error.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-116-5/+13
| | | | | | | | * pppd/Makefile.am: Use .$(OBJEXT) instead of .o. * rtems_servers/Makefile.am: Use .$(OBJEXT) instead of .o. * rtems_telnetd/Makefile.am: Use .$(OBJEXT) instead of .o. * rtems_webserver/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-07-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-07-255-5/+10
| | | | | * pppd/chap.c, pppd/fsm.c, pppd/fsm.h, pppd/upap.c: Per PR255 fix prototype mismatches.
* 2002-07-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-012-14/+4
| | | | * rtems_webserver/misc.c: Per PR236 eliminate definition of strnlen().
* 2002-06-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-262-9/+7
| | | | | * wrapup/Makefile.am: Build libnetapps.a. Don't preinstall libnetapps.a
* 2002-05-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-303-17/+6
| | | | | * Makefile.am: Remove headers. Remove CHANGELOG. * configure.ac: Use AC_CONFIG_SRCDIR([pppd]).
* 2002-05-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-29265-75145/+11
| | | | | | | Move networking libraries to c/src/exec/libnetworking * configure.ac: Reflect Moval. * Makefile.am: Reflect Moval. * wrapup/Makefile.am: Reflect Moval.
* 2002-05-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-282-1/+5
| | | | * rtems_telnetd/pty.c: Remove bsp.h. Include <rtems/bspIo.h>.
* 2002-05-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-172-5/+9
| | | | | | * rtems/mkrootfs.c: Add (relocated from libmisc/rootfs). * rtems/mkrootfs.h: Ditto. * rtems/Makefile.am: Reflect changes above.
* 2002-05-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-145-233/+9
| | | | | | | * sys/ioctl.h: Remove. * sys/sockio.h: Remove. * sys/filio.h: Remove. * sys/Makefile.am: Reflect changes above.
* 2001-05-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-05-141-16/+3
| | | | * ChangeLog: Corrected -- entry should have been in libchip.
* 2001-05-14 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2002-05-141-1/+2
| | | | | | | | | | | | | | | | | * bootloader/Makefile.am, console/Makefile.am, pci/Makefile.am: Per PR215 address the following issues: - _IO_BASE, _ISA_MEM_BASE and PCI_DRAM_OFFSET are no longer defined by libcpu (powerpc/shared/include/io.h) but by the BSP (who is the only one to know the values) - the affected BSP (shared/motorola) headers have been fixed in a separate "libbsp/powerpc/shared" patch. - the DEC 21140 driver (libchip/network/dec21140.c) has been fixed to use PCI_DRAM_OFFSET instead of PREP_PCI_DRAM_OFFSET. and PCI_MEM_BASE instead of PREP_ISA_MEM_BASE. PCI_MEM_BASE is to be defined by the BSP who is using this driver. - the DEC driver also has been fixed to use the newer rtems_bsp_delay_in_bus_cycles() instead of the obsolete delay_in_bus_cycles().
* 2001-05-14 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2002-05-141-0/+16
| | | | | | | | | | | | | | | | * network/dec21140.c: Per PR215 address the following issues: - _IO_BASE, _ISA_MEM_BASE and PCI_DRAM_OFFSET are no longer defined by libcpu (powerpc/shared/include/io.h) but by the BSP (who is the only one to know the values) - the affected BSP (shared/motorola) headers have been fixed in a separate "libbsp/powerpc/shared" patch. - the DEC 21140 driver (libchip/network/dec21140.c) has been fixed to use PCI_DRAM_OFFSET instead of PREP_PCI_DRAM_OFFSET. and PCI_MEM_BASE instead of PREP_ISA_MEM_BASE. PCI_MEM_BASE is to be defined by the BSP who is using this driver. - the DEC driver also has been fixed to use the newer rtems_bsp_delay_in_bus_cycles() instead of the obsolete delay_in_bus_cycles().
* 2002-05-01 Eric Norum <eric.norum@usask.ca>Joel Sherrill2002-05-012-1/+6
| | | | | * machine/in_cksum.h: Per PR200 fix multi-line inline assembly to satisfy gcc 3.1 and newer.
* 2002-04-26 Eric Norum <eric.norum@usask.ca>Joel Sherrill2002-04-262-4/+13
| | | | | * netinet/in_cksum_i386.c: Add volatile so the more agressive optimization in gcc 3.1 does not reorder things.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-182-2/+6
| | | | * pppd/utils.c: Adapt to gcc-3.x.
* 2002-04-11 Chris Johns <ccj@acm.org>Joel Sherrill2002-04-132-0/+14
| | | | | | | * c/src/libnetworking/rtems/rtems_bsdnet.h: To address PR59, added the drv_ctrl driver control block field to the ifconfig network driver structure. This field is needed by the i82586 driver which was ported from NetBSD as it had better hardware abstraction.
* 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-081-4/+8
| | | | * ChangeLog: Fix dates.
* 2002-03-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-012-9/+13
| | | | * libc/rcmd.c: Replace __rtems w/ __rtems__.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2819-19/+25
| | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * arpa/Makefile.am: Remove AUTOMAKE_OPTIONS. * kern/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * lib/Makefile.am: Remove AUTOMAKE_OPTIONS. * libc/Makefile.am: Remove AUTOMAKE_OPTIONS. * machine/Makefile.am: Remove AUTOMAKE_OPTIONS. * net/Makefile.am: Remove AUTOMAKE_OPTIONS. * netinet/Makefile.am: Remove AUTOMAKE_OPTIONS. * nfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * pppd/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_servers/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_telnetd/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_webserver/Makefile.am: Remove AUTOMAKE_OPTIONS. * sys/Makefile.am: Remove AUTOMAKE_OPTIONS. * vm/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-27 Thomas.Doerfler@imd-systems.deJoel Sherrill2002-03-272-9/+46
| | | | | | | * PR144 * nfs/bootp_subr.c bootpc_init(): Performs a write to memory address 0 when called for the first time. This is done when trying to clear the variable "dhcp_hostname".
* 2002-03-27 Ilya Alexeev <ilya@continuum.ru>Joel Sherrill2002-03-274-13/+26
| | | | | | | | | | | | | * PR162 * net/if_ppp.c ppp_txdaemon(), net/if_pppvar.h pppstart(): Local variables must not be used in a device write routines. Now ppp_softc structure have own character for writing to device (sc_outchar). I think that converting local variables to static is not a right solution, because problems will occur in the case of two or more ppp instances. * net/ppp_tty.c pppstart(): Type of the ioffset variable must be u_long, otherwise in the case of the big output packet endless loop may occur.
* 2002-03-21 Ilya Alexeev <ilya@continuum.ru>Joel Sherrill2002-03-213-16/+43
| | | | | * net/if_ppp.c, net/ppp_tty.c: Initial preparations for multiple PPPD connections.
* 2001-03-20 Till Straumann <strauman@SLAC.Stanford.EDU>Joel Sherrill2002-03-203-2/+35
| | | | | | | | | * PR158 * libc/rcmd.c, libc/rcmd.c: Enable the rcmd() library call by commenting out the parts that deal with signals. This enables RTEMS to 'rsh' command to a server connecting fd to remote stdio. The 'server-side' parts of this file which deal with authentication are disabled since they are not needed.
* 2002-02-27 Ilya Alexeev <ilya@continuum.ru>Joel Sherrill2002-02-276-10/+47
| | | | | | * net/if_ppp.c, pppd/auth.c, pppd/chat.c, pppd/pppd.h, pppd/sys-rtems.c: Add server with pap-authorization capabilities as well as eliminate some warnings.
* 2002-02-27 Eric Norum <eric.norum@usask.ca>Joel Sherrill2002-02-272-1/+10
| | | | | | * net/radix.c: Properly handle fetching the default route when there is no route. This was a bug in the original FreeBSD code and this fix is from an updated version of their code.
