path: root/c/src/libnetworking/sys/sockio.h (follow)
* Merged Eric Norum's select patch that was based on 4.0 and resolvedJoel Sherrill1998-12-101-3/+2
| | | | all conflicts.
* Patch from Ian Lance Taylor <ian@airs.com>:Joel Sherrill1998-12-101-0/+7
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | From: Eric Norum <eric@skatter.usask.ca> Date: Sat, 5 Dec 98 13:20:51 -0600 What do you think of this patch? It implements your `tap' suggestion in a way that adds support for all ethernet devices with no driver modifications. I also added a return value from the tap function. If the return value is zero, the packet will be passed up the chain as usual. If the return value is non-zero the mbuf holding the packet will be freed and the packet will be dropped. If you like it, please submit it to Joel. I guess there needs to be an addition to the network documentation describing the additional ioctl's -- and a big warning that the tap function is called from a context that holds the network semaphore. Here is Eric's patch. I've tested it a bit, and made a couple of trivial changes. This is certainly better than mine: it should work for all Ethernet drivers. ================================================== The only concern I have about this patch is that the tap function may want to fiddle with the mbuf, calling functions like m_pullup and the like. If those force the networking code to rearrange the mbuf structure, then the caller's call to m_freem may crash. I don't know if this is a realistic concern--I don't know enough about the mbuf layer.
* Base filesJoel Sherrill1998-08-191-0/+86
