path: root/c/src/libnetworking/pppd/utils.c (unfollow)
2005-10-26Remove (Moved to cpukit).Ralf Corsepius1-833/+0
2005-01-202005-01-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-2/+3
PR 736/pppd * libnetworking/pppd/chat.c, libnetworking/pppd/demand.c, libnetworking/pppd/pppd.h, libnetworking/pppd/rtemsmain.c, libnetworking/pppd/sys-rtems.c, libnetworking/pppd/utils.c: ttyfd should not be static and should have a name more specific to pppd.
2004-09-292004-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* aclocal/rtems-cpu-subdirs.m4, libchip/shmdr/shm_driver.h, libnetworking/pppd/utils.c: i960 obsoleted and all references removed.
2004-04-15Remove stray white spaces.Ralf Corsepius1-1/+0
2003-03-24Merger from rtems-4-6-branch.Ralf Corsepius1-39/+0
2002-08-122002-08-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* pppd/utils.c: Include i960 in varargs conditional to avoid error.
2002-04-182002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-2/+2
* pppd/utils.c: Adapt to gcc-3.x.
2001-08-162001-08-16 Mike Siers <mikes@poliac.com>Joel Sherrill1-0/+872
* Update of PPPD to 2.3.11 from 2.3.5 and addition of an example application. Mike's notes on the modifications: - renamed error() function because of namespace problems - removed calls to the exit() funciton - removed extra files from the pppd source directory - defined pppd task constant values in rtemspppd.h - modifyied example code to get actual tick per second value - placed the pppd 2.3.11 man page file (pppd.8) into the pppd directory * pppd/cbcp.c, pppd/cbcp.h, pppd/main.c, pppd/ppp_tty.c, pppd/pppmain.c, pppd/rtems-ppp.c, pppd/rtems-ppp.c: Deleted. * pppd/pppd.8, pppd/rtemsmain.c, pppd/rtemspppd.c, pppd/rtemspppd.h, pppd/sys-rtems.c, pppd/utils.c, pppd/example/Makefile, pppd/example/README, pppd/example/init.c, pppd/example/netconfig.h, pppd/example/ppp.conf, pppd/example/pppdapp.c, pppd/example/system.h: New files. * modem/ppp_tty.c, net/if_ppp.h, pppd/Makefile.am, pppd/README, pppd/STATUS, pppd/auth.c, pppd/ccp.c, pppd/ccp.h, pppd/chap.c, pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c, pppd/ipcp.h, pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h, pppd/magic.c, pppd/magic.h, pppd/options.c, pppd/patchlevel.h, pppd/pathnames.h, pppd/pppd.h, pppd/upap.c, pppd/upap.h: Modified.
