PR 771/pppd
* libnetworking/pppd/chat.c, libnetworking/pppd/rtemsmain.c: The fix
committed to fix PR736 breaks pppd. chat.c should have its own static
ttyfd for pppd to work correctly. The symptom is that second
invokation of chat (for connect script) fails due to pppd_ttyfd set
to -1 by previous chat invokation (for init script). In addition,
this patch fixes leaving of dangling pointer in the abort_stbring[]
by chat_send().
PR 736/pppd
* libnetworking/pppd/chat.c, libnetworking/pppd/demand.c,
libnetworking/pppd/pppd.h, libnetworking/pppd/rtemsmain.c,
libnetworking/pppd/sys-rtems.c, libnetworking/pppd/utils.c: ttyfd
should not be static and should have a name more specific to pppd.
PR 599/pppd
* libnetworking/pppd/chat.c: Fre memory that is allocated to fix leak.
* pppd/chat.c: Removed warnings.
PR 371/pppd
* pppd/auth.c, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/lcp.c,
pppd/options.c, pppd/pppd.h, pppd/rtemsmain.c, pppd/rtemspppd.c:
Change many symbols to static. There are still global symbols in
rtemspppd.h which might need to be changed or converted into member
of a structure which is dereferenced with a pointer that is managed
as a per task variable. But this patch should avoid many conflicts.
* pppd/chat.c: Convert routines with common names to static. This
included get_char(), put_char(), and character() among others.
* net/if_ppp.c, pppd/auth.c, pppd/chat.c, pppd/pppd.h,
pppd/sys-rtems.c: Add server with pap-authorization
capabilities as well as eliminate some warnings.
* Nice Update of PPPD support which eliminates the
requiremetn that drivers be in the termios TASK_DRIVEN mode.
Mike did significant testing and reports that it seems to be
more stable and handle larger packets better. This patch
replaces the termios tasks with more general pppd network
driver tasks. The functions pppinput() and pppstart() get
called from the interrupt service routine.
* Makefile.am, configure.ac, net/Makefile.am, net/bpf.h,
net/ethernet.h, net/if.c, net/if.h, net/if_arp.h, net/if_dl.h,
net/if_ethersubr.c, net/if_llc.h, net/if_loop.c, net/if_ppp.h,
net/if_pppvar.h, net/if_types.h, net/netisr.h, net/ppp-comp.h,
net/ppp_defs.h, net/pppcompress.h, net/radix.c, net/radix.h,
net/raw_cb.c, net/raw_cb.h, net/raw_usrreq.c, net/route.c,
net/route.h, net/rtsock.c, pppd/Makefile.am, pppd/README,
pppd/STATUS, pppd/auth.c, pppd/cbcp.c, pppd/ccp.c, pppd/ccp.h,
pppd/chap.c, pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h,
pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c,
pppd/ipcp.h, pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h,
pppd/magic.c, pppd/magic.h, pppd/options.c, pppd/patchlevel.h,
pppd/pathnames.h, pppd/pppd.8, pppd/pppd.h, pppd/rtemsmain.c,
pppd/rtemspppd.c, pppd/rtemspppd.h, pppd/sys-rtems.c, pppd/upap.c,
pppd/upap.h, pppd/utils.c, pppd/example/README,
pppd/example/netconfig.h, wrapup/Makefile.am: Modified.
* net/bsd-comp.c, net/if_ppp.c, net/ppp-deflate.c, net/ppp.h,
net/ppp_tty.c, net/pppcompress.c, net/zlib.c, net/zlib.h: New file.
* modem/, modem/.cvsignore, modem/Makefile.am, modem/ppp.c,
modem/ppp.h, modem/ppp_tty.c, modem/pppcompress.c: Subdirectory removed.
* Update to stable working state. Congratulations Mike! :)
* modem_example: Directory removed.
* modem_example/16550.h, modem_example/README, modem_example/modem.c,
modem_example/modem.h, modem_example/ppp.c, modem_example/ppp.h,
modem_example/pppcompress.c: Files removed.
* pppd/example/pppd.options: New file.
* pppd/README, pppd/STATUS, pppd/cbcp.c, pppd/cbcp.h, pppd/chat.c,
pppd/pppd.h, pppd/rtemsmain.c: Updated.
* Update of PPPD to 2.3.11 from 2.3.5 and addition of an example
application. Mike's notes on the modifications:
- renamed error() function because of namespace problems
- removed calls to the exit() funciton
- removed extra files from the pppd source directory
- defined pppd task constant values in rtemspppd.h
- modifyied example code to get actual tick per second value
- placed the pppd 2.3.11 man page file (pppd.8) into the pppd
directory
* pppd/cbcp.c, pppd/cbcp.h, pppd/main.c, pppd/ppp_tty.c,
pppd/pppmain.c, pppd/rtems-ppp.c, pppd/rtems-ppp.c: Deleted.
* pppd/pppd.8, pppd/rtemsmain.c, pppd/rtemspppd.c, pppd/rtemspppd.h,
pppd/sys-rtems.c, pppd/utils.c, pppd/example/Makefile,
pppd/example/README, pppd/example/init.c, pppd/example/netconfig.h,
pppd/example/ppp.conf, pppd/example/pppdapp.c, pppd/example/system.h:
New files.
* modem/ppp_tty.c, net/if_ppp.h, pppd/Makefile.am, pppd/README,
pppd/STATUS, pppd/auth.c, pppd/ccp.c, pppd/ccp.h, pppd/chap.c,
pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h, pppd/chat.c,
pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c, pppd/ipcp.h,
pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h, pppd/magic.c,
pppd/pathnames.h, pppd/pppd.h, pppd/upap.c, pppd/upap.h: Modified.
* wrapup/Makefile.am: Added modem subdir.
* configure.in, Makefile.am: Added modem subdir.
* net/Makefile.am: Added if_pppvar.h, pppcompress.h.
* pppd/Makefile.am: Added pppmain.c (which needs work).
* pppd/chat.c, pppd/fsm.c, pppd/fsm.h, pppd/ipxcp.c, pppd/main.c,
pppd/ppp_tty.c, pppd/upap.c: Changes from Thomas Doerfler
<Thomas.Doerfler@imd-systems.de> and cosmetic changes by me.
Actually main.c and ppp_tty.c should be scratched. The modem
subdir has the real ppp_tty.c and the real pppd main is in pppmain.c.
Tomasz only tested this on the mpc823.
The official site for the original source for this PPP implementation is:
ftp://cs.anu.edu.au/pub/software/ppp
NOTE: As of 11/30/1999, the current version of this source is 2.3.10.
