future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
printing messages.
prototype.
the inet checksum routine.
I've fixed a few minor probs with the optimised version that Eric put
together for me the other day and sent the fixes back to him. Provided he
doesn't have a problem with it we've got a pretty solid in_cksum for the
ColdFire as well as straight m68k. I've enclosed my updated in_cksum_m68k.c
At the moment my own bottlenecks are elsewhere...as my driver is pulling
16bit data chunks through a libchip-esq access routine from the chip which
for a polled I/O device is never going to be quick.
for the ColdFire.
file to switch out to CPU specific implementations.
