* | 2000-12-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-12-08 | 1 | -3/+3 |
| | | | | | | | | | | * libc/linkaddr.c: Initialized variable to remove warning. * modem/ppp.c, modem/ppp_tty.c: Made numerous variable declarations conditional on PPP_COMPRESS and PPP_FILTER. Commented out variables that were not used because the code using them was commented out. Removed totally unused variables. * modem/pppcompress.c: Added parentheses to avoid warnings. * pppd/pppmain.c: Removed numerous warnings. | ||||
* | 2000-11-25 Antti P Miettinen <antti.p.miettinen@nokia.com> | Joel Sherrill | 2000-11-25 | 1 | -0/+593 |
* wrapup/Makefile.am: Added modem subdir. * configure.in, Makefile.am: Added modem subdir. * net/Makefile.am: Added if_pppvar.h, pppcompress.h. * pppd/Makefile.am: Added pppmain.c (which needs work). * pppd/chat.c, pppd/fsm.c, pppd/fsm.h, pppd/ipxcp.c, pppd/main.c, pppd/ppp_tty.c, pppd/upap.c: Changes from Thomas Doerfler <Thomas.Doerfler@imd-systems.de> and cosmetic changes by me. Actually main.c and ppp_tty.c should be scratched. The modem subdir has the real ppp_tty.c and the real pppd main is in pppmain.c. |
