* | Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-02-18 | 1 | -0/+2 |
| | | | | | | | | | | | | | | | | > 5) rtems-rc-19990202-1.diff/reorg-install.sh > > reorg-install.sh fixes a Makefile variable name clash of RTEMS > configuration files and automake/autoconf standards. > Until now, RTEMS used $(INSTALL) for install-if-change. Automake and > autoconf use $(INSTALL) for a bsd-compatible install. As > install-if-change and bsd-install are not compatible, I renamed all > references to install-if-changed to $(INSTALL_CHANGED) and used > $(INSTALL) for bsd-install (==automake/autoconf standard). When > automake will be introduced install-if-change will probably be replaced > by $(INSTALL) and therefore will slowly vanish. For the moment, this > patch fixes a very nasty problem which prevents adding any automake file > until now (There are still more). | ||||
* | Made to compile after hacking tftp driver into beginnings of a mini-filesystem. | Joel Sherrill | 1999-01-21 | 1 | -2/+2 |
* | All warnings removed. | Joel Sherrill | 1998-08-21 | 1 | -1/+1 |
* | Fixed warning about pointer/integer conversion which turned out to be | Joel Sherrill | 1998-08-21 | 1 | -1/+1 |
| | | | | a missed "&" on a write. | ||||
* | Added CVS Ids | Joel Sherrill | 1998-08-20 | 29 | -0/+56 |
* | Fixed many warnings. | Joel Sherrill | 1998-08-20 | 18 | -65/+90 |
* | Temporarily leave strsep out of the build. | Joel Sherrill | 1998-08-20 | 1 | -2/+4 |
* | FreeBSD stack compiles for the first time (except libc/strsep.c). | Joel Sherrill | 1998-08-20 | 1 | -3/+3 |
* | Base files | Joel Sherrill | 1998-08-20 | 1 | -0/+54 |
* | Base files | Joel Sherrill | 1998-08-19 | 70 | -0/+15065 |
