Tomasz only tested this on the mpc823.
The official site for the original source for this PPP implementation is:
ftp://cs.anu.edu.au/pub/software/ppp
NOTE: As of 11/30/1999, the current version of this source is 2.3.10.
POSIX API is disabled.
<valette@crf.canon.fr> to add a port of the GoAhead web server
(httpd) to the RTEMS build tree. They have successfully used
this BSP on i386/pc386 and PowerPC/mcp750.
Mark and Joel spoke with Nick Berliner <nickb@goahead.com> on
26 Oct 1999 about this port and got verbal approval to include
it in RTEMS distributions.
a top level more independently configured package.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
