* shell/shell.c: Remove #undef __STRICT_ANSI__.
* rootfs/Makefile.am: Use include_rtems_HEADERS instead of H_FILES.
* mw-fb/mw_uid.c: Apply rtems_set_errno_and_return_minus_one.
* rootfs/mkrootfs.c, rootfs/mkrootfs.h: Fixed typo.
* configure.in: Remove.
* dummy/dummy.c: Now a useful configuration that starts main().
* wrapup/Makefile.am: Include a base level configuration in
RTEMS library.
* untar/Makefile.am: Use 'PREINSTALL_FILES ='.
* monitor/Makefile.am: Use 'PREINSTALL_FILES ='.
* shell/Makefile.am: Use 'PREINSTALL_FILES ='.
* devnull/Makefile.am: Use 'PREINSTALL_FILES ='.
* dumpbuf/Makefile.am: Use 'PREINSTALL_FILES ='.
* mw-fb/Makefile.am: Use 'PREINSTALL_FILES ='.
* stackchk/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtmonuse/Makefile.am: Use 'PREINSTALL_FILES ='.
* cpuuse/Makefile.am: Use 'PREINSTALL_FILES ='.
* rootfs/Makefile.am: Use 'PREINSTALL_FILES ='.
* ChangeLog: Fixed typo in date.
* configure.in, rootfs/Makefile.am: Added conditional to make sure
rootfs does not get built with networking is disabled. Also
added include of compile.am to rootfs/Makefile.am.
* wrapup/Makefile.am: Added rootfs conditionally if networking enabled.
* Added support for populating the initial "root" filesystem
with information obtained via the DHCP response.
* rootfs: New directory.
* rootfs/.cvsignore, rootfs/Makefile.am, rootfs/mkrootfs.c,
rootfs/mkrootfs.h: New files.
* configure.in, Makefile.am: Modified to reflect addition.
* ChangeLog: Fixed some mistakes.
* devnull/devnull.c: Eliminate warning.
* mw-fb\Makefile.am: Corrected problem.
* shell/pty.c: Moved to libnetworking/rtems_telnetd.
* shell/Makefile.am, shell/README, shell/cmds.c, shell/shell.c,
shell/shell.h: Updates.
* monitor/mon-command.c: Add support for partial command matching.
The monitor used to have this functionality before it was overhauled
to support addition of user commands.
* shell/telnetd.c, shell/telnetd.h: Moved to
libnetworking/rtems_servers so the network stack to address network
depenendency.
* shell/Makefile.am: Modified to reflect above.
* shell/cmds.c: Removed code from inappropriate source.
* monitor/mon-prmisc.c: Correct print line.
* shell/Makefile.am: Added new file telnetd.c.
* shell/telnetd.c, shell/telnetd.h, shell/pty.c: New files.
* shell/shell.c, shell/cmds.c, shell/shell.h: Numerous improvments:
- The shell_init has a new parameter 'forever' because in
/dev/console you need that this process runs forever but in
tcp/ip not. (respawn?)
- A new task for every session opened trought tcp/ip telnet client.
(the chargen,daytime and more are possible of implementation but
I ask me if they are necesary)
- Exit from the session delete the task and when the client fails too.
- More cmds have been implemented. (very reduced version of these)
umask, chmod, id, whoami, rm, cat, ...
- A reduced line edit has been implemented.
Ctrl-C abort the input,
Ctrl-d in the first position gives EOF (logout).
'\b' and DEL makes the rubout operation.
I think that readline() for every session spents a lot of resources.
* shell/cmds.c, shell/shell.c: Remove fileno-hacks.
* monitor/mon-symbols.c: Remove #undef __STRICT_ANSI__.
* Added initial shell functionality.
* Makefile.am, configure.in, wrapup/Makefile.am:
* shell/.cvsignore, shell/Makefile.am, shell/README,
shell/cmds.c, shell/shell.c, shell/shell.h: New files.
* devnull/devnull.c (null_initialize): Added check to
ensure that the driver is only initialized once. Otherwise,
it will abort when the device /dev/null is present.
(null_write): Do not dereference a NULL pointer.
* monitor/mon-command.c: Use #if defined(RTEMS_UNIX).
* untar/Makefile.am, monitor/Makefile.am, dummy/Makefile.am,
devnull/Makefile.am, dumpbuf/Makefile.am, mw-fb/Makefile.am,
stackchk/Makefile.am, rtmonuse/Makefile.am, cpuuse/Makefile.am:
* devnull: New addition. Moved from libcpu/sh.
* devnull/devnull.c, devnull/devnull.h, devnull/.cvsignore,
devnull/Makefile.am: New files.
* Makefile.am, configure.in, wrapup/Makefile.am: Modified to reflect
addition of above.
* mw-fb/mw_uid.c: Removed unnecessary dependency on <bsp.h>.
* monitor/mon-driver.c: Accounted for addition of "_entry" to
fields in rtems_driver_address_table.
* cpuuse/Makefile.am, dummy/Makefile.am, dumpbuf/Makefile.am,
monitor/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am,
untar/Makefile.am, wrapup/Makefile.am, mw-fb/Makefile.am:
Include compile.am.
all APIs.
* mw-fb/.cvsignore: New file.
* Added generic Micro FrameBuffer interface for MicroWindows.
This interface allows MicroWindows to under RTEMS. A sample
driver has been developed for the pc386 BSP. See
pc386/fb_vga.c as a sample.
* Added Uniform Input Device interface for MicroWindows.
See PC386 bsp for sample drivers for mouse and keyboard (console).
* mw-bf: New directory.
* Makefile.am, configure.in, wrapup/Makefile.am: Account for mw-fb.
* mw-fb/Makefile.am: New file.
* mw-fb/mw_fb.c: New file.
* mw-fb/mw_fb.h: New file.
* mw-fb/mw_uid.c: New file.
* mw-fb/mw_uid.h: New file.
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
that breaks when the target has 16 bit address space. One of the H8
multilibs is a 16-bit address space CPU. When a real attempt is
made to support this CPU model, the code that assumes an address
is 32 bits will have to change. This constant is probably not
flagging all impacted code.
to:
I have also added the ability to register and unregister commands. This
allows me to create a set of monitor commands for the network stack plus
basic memory dump/patch commands (needs a working probe interface). I
will also look at a basic ls/cd/rm/mv/cp command set at some stage.
I have been thinking about changing the monitor in the future to more
like a light weight RTEMS shell, `eshell' for embedded shell. This is a
story for another day but is a process or getting the commands to map to
the filesystem (eg, major=commands, minor=command) and supporting an
environment. The filesystem provide a structure for the commands.
that contains:
* Removes MKLIB
handling)
converted to automake.
to convert the libmisc directory from Makefile.in to Makefile.am.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
