Include files now installed as <rtems/*.h>.
it work.
I think I figured out why rtems_panic was locking up instead of
shutting down the executive and returning to the code that called
boot_card().
Later on there is code to print some messages on the standard error
stream, a recursive call back to rtems_verror (through rtems_error)
and finally a call to _exit().
I think that the _Thread_Disable_dispatch() is preventing the final
context switch back to the boot_card() code. Does this sound right
to you?
This makes the headings line up above the columns a little better.
Now that it's so easy to include/exclude the stack check code I find
myself adding it to all my `debug' targets.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
enclose.
unsigned numbers.
to lib/include.
be resolved.
proper include files added.
from the application code, this file required more visibility than
is given by default to application code.
system exit.
like signal dispatching.
correct Information block.
