path: root/c/src/libmisc (follow)
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2815-15/+21
| | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. * cpuuse/Makefile.am: Remove AUTOMAKE_OPTIONS. * devnull/Makefile.am: Remove AUTOMAKE_OPTIONS. * dummy/Makefile.am: Remove AUTOMAKE_OPTIONS. * dumpbuf/Makefile.am: Remove AUTOMAKE_OPTIONS. * monitor/Makefile.am: Remove AUTOMAKE_OPTIONS. * mw-fb/Makefile.am: Remove AUTOMAKE_OPTIONS. * rootfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtmonuse/Makefile.am: Remove AUTOMAKE_OPTIONS. * shell/Makefile.am: Remove AUTOMAKE_OPTIONS. * stackchk/Makefile.am: Remove AUTOMAKE_OPTIONS. * untar/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-20 Chris Johns <ccj@acm.org>Joel Sherrill2002-03-202-0/+10
| | | | | * PR148. * monitor/mon-prmisc.c: Fixed to print task states correctly.
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-302-1/+4
| | | | * shell/shell.c: Remove #undef __STRICT_ANSI__.
* 2002-01-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-082-3/+8
| | | | * rootfs/Makefile.am: Use include_rtems_HEADERS instead of H_FILES.
* 2002-01-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-042-1/+10
| | | | * mw-fb/mw_uid.c: Apply rtems_set_errno_and_return_minus_one.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-123-2/+4
| | | | * rootfs/mkrootfs.c, rootfs/mkrootfs.h: Fixed typo.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-0/+50
| | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
* 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-49/+0
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-112-0/+7
* 2001-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-283-2/+12
| | | | | | * dummy/dummy.c: Now a useful configuration that starts main(). * wrapup/Makefile.am: Include a base level configuration in RTEMS library.
* 2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-2811-10/+23
| | | | | | | | | | | | | * untar/Makefile.am: Use 'PREINSTALL_FILES ='. * monitor/Makefile.am: Use 'PREINSTALL_FILES ='. * shell/Makefile.am: Use 'PREINSTALL_FILES ='. * devnull/Makefile.am: Use 'PREINSTALL_FILES ='. * dumpbuf/Makefile.am: Use 'PREINSTALL_FILES ='. * mw-fb/Makefile.am: Use 'PREINSTALL_FILES ='. * stackchk/Makefile.am: Use 'PREINSTALL_FILES ='. * rtmonuse/Makefile.am: Use 'PREINSTALL_FILES ='. * cpuuse/Makefile.am: Use 'PREINSTALL_FILES ='. * rootfs/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-271-1/+5
| | | | * ChangeLog: Fixed typo in date.
* 2001-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-214-2/+18
| | | | | | | * configure.in, rootfs/Makefile.am: Added conditional to make sure rootfs does not get built with networking is disabled. Also added include of compile.am to rootfs/Makefile.am. * wrapup/Makefile.am: Added rootfs conditionally if networking enabled.
* 2001-09-19 Chris Johns <ccj@acm.org>Joel Sherrill2001-09-197-1/+469
| | | | | | | | | * Added support for populating the initial "root" filesystem with information obtained via the DHCP response. * rootfs: New directory. * rootfs/.cvsignore, rootfs/Makefile.am, rootfs/mkrootfs.c, rootfs/mkrootfs.h: New files. * configure.in, Makefile.am: Modified to reflect addition.
* 2001-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-142-1/+41
| | | | * ChangeLog: Fixed some mistakes.
* 2001-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-132-1/+5
| | | | * devnull/devnull.c: Eliminate warning.
* 2001-08-26 Brett Swimley <brett.swimley@aedinc.net>Joel Sherrill2001-08-161-4/+6
| | | | * mw-fb\Makefile.am: Corrected problem.
* 2001-08-09 Fernando-Ruiz Casas <correo@fernando-ruiz.com>Joel Sherrill2001-08-092-406/+4
| | | | * shell/pty.c: Moved to libnetworking/rtems_telnetd.
* 2001-08-09 Fernando-Ruiz Casas <correo@fernando-ruiz.com>Joel Sherrill2001-08-096-103/+146
| | | | | * shell/Makefile.am, shell/README, shell/cmds.c, shell/shell.c, shell/shell.h: Updates.
* 2001-08-09 Keith Outwater <vac4050@cae597.rsc.raytheon.com>Joel Sherrill2001-08-092-10/+49
| | | | | | * monitor/mon-command.c: Add support for partial command matching. The monitor used to have this functionality before it was overhauled to support addition of user commands.
* 2001-06-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-06-144-130/+10
| | | | | | | * shell/telnetd.c, shell/telnetd.h: Moved to libnetworking/rtems_servers so the network stack to address network depenendency. * shell/Makefile.am: Modified to reflect above.
* 2001-05-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-05-252-47/+18
| | | | * shell/cmds.c: Removed code from inappropriate source.
* 2000-05-24 Fernando Ruiz Casas <fernando.ruiz@ctv.es>Joel Sherrill2001-05-2410-78/+901
| | | | | | | | | | | | | | | | | | | | | * monitor/mon-prmisc.c: Correct print line. * shell/Makefile.am: Added new file telnetd.c. * shell/telnetd.c, shell/telnetd.h, shell/pty.c: New files. * shell/shell.c, shell/cmds.c, shell/shell.h: Numerous improvments: - The shell_init has a new parameter 'forever' because in /dev/console you need that this process runs forever but in tcp/ip not. (respawn?) - A new task for every session opened trought tcp/ip telnet client. (the chargen,daytime and more are possible of implementation but I ask me if they are necesary) - Exit from the session delete the task and when the client fails too. - More cmds have been implemented. (very reduced version of these) umask, chmod, id, whoami, rm, cat, ... - A reduced line edit has been implemented. Ctrl-C abort the input, Ctrl-d in the first position gives EOF (logout). '\b' and DEL makes the rubout operation. I think that readline() for every session spents a lot of resources.
* 2001-04-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-074-5/+7
| | | | | * shell/cmds.c, shell/shell.c: Remove fileno-hacks. * monitor/mon-symbols.c: Remove #undef __STRICT_ANSI__.
* 2001-04-20 Correo Fernando-ruiz <correo@fernando-ruiz.com>Joel Sherrill2001-04-2010-1/+1104
| | | | | | | * Added initial shell functionality. * Makefile.am, configure.in, wrapup/Makefile.am: * shell/.cvsignore, shell/Makefile.am, shell/README, shell/cmds.c, shell/shell.c, shell/shell.h: New files.
* 2001-04-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-202-10/+23
| | | | | | | * devnull/devnull.c (null_initialize): Added check to ensure that the driver is only initialized once. Otherwise, it will abort when the device /dev/null is present. (null_write): Do not dereference a NULL pointer.
* 2001-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-122-1/+5
| | | | * monitor/mon-command.c: Use #if defined(RTEMS_UNIX).
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-059-27/+48
| | | | | | | * untar/Makefile.am, monitor/Makefile.am, dummy/Makefile.am, devnull/Makefile.am, dumpbuf/Makefile.am, mw-fb/Makefile.am, stackchk/Makefile.am, rtmonuse/Makefile.am, cpuuse/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* 2001-01-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-058-2/+303
| | | | | | | | * devnull: New addition. Moved from libcpu/sh. * devnull/devnull.c, devnull/devnull.h, devnull/.cvsignore, devnull/Makefile.am: New files. * Makefile.am, configure.in, wrapup/Makefile.am: Modified to reflect addition of above.
* 2000-11-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-302-1/+11
| | | | * mw-fb/mw_uid.c: Removed unnecessary dependency on <bsp.h>.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-092-1/+5
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-022-1/+5
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-252-1/+6
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-282-6/+11
| | | | | * monitor/mon-driver.c: Accounted for addition of "_entry" to fields in rtems_driver_address_table.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-0510-2/+19
| | | | | | | * cpuuse/Makefile.am, dummy/Makefile.am, dumpbuf/Makefile.am, monitor/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, untar/Makefile.am, wrapup/Makefile.am, mw-fb/Makefile.am: Include compile.am.
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-302-1/+24
| | | | | | * Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs.
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-302-0/+6
| | | | * mw-fb/.cvsignore: New file.
* 2000-08-26 Rosimildo da Silva <rdasilva@connecttel.com>Joel Sherrill2000-08-309-2/+649
| | | | | | | | | | | | | | | | * Added generic Micro FrameBuffer interface for MicroWindows. This interface allows MicroWindows to under RTEMS. A sample driver has been developed for the pc386 BSP. See pc386/fb_vga.c as a sample. * Added Uniform Input Device interface for MicroWindows. See PC386 bsp for sample drivers for mouse and keyboard (console). * mw-bf: New directory. * Makefile.am, configure.in, wrapup/Makefile.am: Account for mw-fb. * mw-fb/Makefile.am: New file. * mw-fb/mw_fb.c: New file. * mw-fb/mw_fb.h: New file. * mw-fb/mw_uid.c: New file. * mw-fb/mw_uid.h: New file.
* Increased the defaults to be more reasonable.Joel Sherrill2000-08-011-1/+3
* Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill2000-07-261-0/+4
| | | | | | | | | | | a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
* Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-131-1/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
* Added RTEMS_CPU_HAS_16_BIT_ADDRESSES constant to disable codeJoel Sherrill2000-06-291-0/+8
| | | | | | | | that breaks when the target has 16 bit address space. One of the H8 multilibs is a 16-bit address space CPU. When a real attempt is made to support this CPU model, the code that assumes an address is 32 bits will have to change. This constant is probably not flagging all impacted code.
* Patch rtems-4.5-beta3-mon.diff from Chris Johns <cjohns@cybertec.com.au>Joel Sherrill2000-06-143-174/+761
| | | | | | | | | | | | | | | to: I have also added the ability to register and unregister commands. This allows me to create a set of monitor commands for the network stack plus basic memory dump/patch commands (needs a working probe interface). I will also look at a basic ls/cd/rm/mv/cp command set at some stage. I have been thinking about changing the monitor in the future to more like a light weight RTEMS shell, `eshell' for embedded shell. This is a story for another day but is a process or getting the commands to map to the filesystem (eg, major=commands, minor=command) and supporting an environment. The filesystem provide a structure for the commands.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-1211-21/+22
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-139-0/+29
| | | | adds .cvsignore.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-087-93/+88
* Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff fromJoel Sherrill2000-01-313-35/+27
| | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams
* Removed warnings.Joel Sherrill1999-12-131-0/+1
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-238-18/+13
| | | | to convert the libmisc directory from Makefile.in to Makefile.am.
