path: root/c/src/libmisc (follow)
* updated copyright to 1998Joel Sherrill1998-02-176-6/+6
* Big patch form Ralf Corsepius described in this email:Joel Sherrill1998-01-307-28/+14
* Corrected Linux port for glibc2Joel Sherrill1998-01-301-1/+2
* Solaris port updates from Chris JohnsJoel Sherrill1998-01-232-11/+13
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-207-7/+7
* Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1998-01-164-4/+4
| | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
* Modified a lot of files to take a first cut at supporting building fromJoel Sherrill1997-12-107-10/+31
* Fixed indexing bug reported by Phil Wilshire.Joel Sherrill1997-12-071-1/+1
* Removed warnings.Joel Sherrill1997-11-292-1/+6
* Fixed a number of warnings regarding comparisons between signed andJoel Sherrill1997-10-214-9/+9
| | | | unsigned numbers.
* Fixed endian problem in printing object names.Joel Sherrill1997-10-211-0/+5
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-086-12/+12
* Removed include directory at "build" point and the link of this directoryJoel Sherrill1997-10-086-8/+8
| | | | | | to lib/include. Went to using a PROJECT_INCLUDE variable.
* Cleaned up as part of adding the Monitor test.Joel Sherrill1997-09-2118-28/+22
* updatedJoel Sherrill1997-09-161-4/+11
* Removed assert condition when not initialized or there are 0 periods.Joel Sherrill1997-08-221-0/+5
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-226-30/+30
* removed commented out line performing a linkJoel Sherrill1997-04-111-1/+0
* printing task names now instead of id numbersJoel Sherrill1997-04-091-3/+16
* new files.Joel Sherrill1997-04-098-0/+617
* added rtmonuse and cpuuse directoriesJoel Sherrill1997-04-091-0/+2
* changed signed int to unsigned int to eliminate a warning.Joel Sherrill1997-04-071-1/+1
* removed noreturn attribute to eliminate warnings.Joel Sherrill1997-04-071-2/+7
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-015-0/+251
| | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved.
* pointer arithmetic reworked to be more portableJoel Sherrill1996-09-181-8/+8
* casts added to numerous arguments, prototypes corrected, andJoel Sherrill1996-09-1810-22/+27
| | | | proper include files added.
* added initial posix configuration supportJoel Sherrill1996-05-282-11/+12
* updates from Tony BennettJoel Sherrill1996-04-2222-181/+130
* As part of reducing visibility into rtems and hiding the .inl filesJoel Sherrill1996-03-068-0/+8
| | | | | from the application code, this file required more visibility than is given by default to application code.
* removed post switch extensionJoel Sherrill1996-02-131-1/+0
* Added condition compile flag for dump of stack usage information onJoel Sherrill1996-01-191-0/+10
| | | | system exit.
* Update from Tony Bennett (tbennett@divnc.com)Joel Sherrill1996-01-177-76/+75
* Split error handler into its own directory.Joel Sherrill1996-01-151-1/+1
* updates from Tony Bennett for PA and UNIX portsJoel Sherrill1996-01-157-81/+102
* all targets compile .. tony's patches in placeJoel Sherrill1995-09-296-32/+41
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-192-4/+4
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-118-33/+66
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-282-5/+5
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1995-08-232-9/+19
| | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-2/+2
* Modified references to task name.Joel Sherrill1995-08-181-2/+3
* + Added object type field to object id.Joel Sherrill1995-08-181-3/+7
| | | | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. + Added parameter "object class" to calls to Initialize Information
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-1722-223/+3714
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* Ada95, gnat, go32Joel Sherrill1995-07-121-1/+1
* incorporated mc68302 supportJoel Sherrill1995-06-071-1/+1
* Fully tested on all in-house targetsJoel Sherrill1995-05-241-0/+1
* Initial revisionJoel Sherrill1995-05-1110-0/+1390
