path: root/c/src/libmisc/stackchk/check.c (follow)
* Include files now installed as <rtems/*.h>.Joel Sherrill1998-12-011-1/+1
* Cosmetic fix from Eric Norum:Joel Sherrill1998-04-271-1/+1
| | | | | | This makes the headings line up above the columns a little better. Now that it's so easy to include/exclude the stack check code I find myself adding it to all my `debug' targets.
* Fixed so this would compile without warning.Joel Sherrill1998-04-151-0/+2
* Stack check now initialized as part of initial extension set.Joel Sherrill1998-04-151-0/+8
* printing task names now instead of id numbersJoel Sherrill1997-04-091-3/+16
* pointer arithmetic reworked to be more portableJoel Sherrill1996-09-181-8/+8
* updates from Tony BennettJoel Sherrill1996-04-221-5/+31
* removed post switch extensionJoel Sherrill1996-02-131-1/+0
* Added condition compile flag for dump of stack usage information onJoel Sherrill1996-01-191-0/+10
| | | | system exit.
* all targets compile .. tony's patches in placeJoel Sherrill1995-09-291-1/+8
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-16/+35
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-281-1/+1
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1995-08-231-8/+18
| | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-2/+2
* Modified references to task name.Joel Sherrill1995-08-181-2/+3
* incorporated mc68302 supportJoel Sherrill1995-06-071-1/+1
* Fully tested on all in-house targetsJoel Sherrill1995-05-241-0/+1
* Initial revisionJoel Sherrill1995-05-111-0/+439
