* .cvsignore: Moved to rtems/cpukit/libmisc.
* ChangeLog: Moved to rtems/cpukit/libmisc.
* Makefile.am: Moved to rtems/cpukit/libmisc.
* README: Moved to rtems/cpukit/libmisc.
* configure.ac: Moved to rtems/cpukit/libmisc.
* capture/Makefile.am: Moved to rtems/cpukit/libmisc.
* capture/README: Moved to rtems/cpukit/libmisc.
* capture/capture-cli.c: Moved to rtems/cpukit/libmisc.
* capture/capture-cli.h: Moved to rtems/cpukit/libmisc.
* capture/capture.c: Moved to rtems/cpukit/libmisc.
* capture/capture.h: Moved to rtems/cpukit/libmisc.
* cpuuse/Makefile.am: Moved to rtems/cpukit/libmisc.
* cpuuse/README: Moved to rtems/cpukit/libmisc.
* cpuuse/cpuuse.c: Moved to rtems/cpukit/libmisc.
* cpuuse/cpuuse.h: Moved to rtems/cpukit/libmisc.
* devnull/.cvsignore: Moved to rtems/cpukit/libmisc.
* devnull/Makefile.am: Moved to rtems/cpukit/libmisc.
* devnull/devnull.c: Moved to rtems/cpukit/libmisc.
* devnull/devnull.h: Moved to rtems/cpukit/libmisc.
* dummy/.cvsignore: Moved to rtems/cpukit/libmisc.
* dummy/Makefile.am: Moved to rtems/cpukit/libmisc.
* dummy/README: Moved to rtems/cpukit/libmisc.
* dummy/dummy.c: Moved to rtems/cpukit/libmisc.
* dumpbuf/.cvsignore: Moved to rtems/cpukit/libmisc.
* dumpbuf/Makefile.am: Moved to rtems/cpukit/libmisc.
* dumpbuf/dumpbuf.c: Moved to rtems/cpukit/libmisc.
* dumpbuf/dumpbuf.h: Moved to rtems/cpukit/libmisc.
* monitor/.cvsignore: Moved to rtems/cpukit/libmisc.
* monitor/Makefile.am: Moved to rtems/cpukit/libmisc.
* monitor/README: Moved to rtems/cpukit/libmisc.
* monitor/mon-command.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-config.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-dname.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-driver.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-extension.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-itask.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-manager.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-monitor.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-mpci.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-object.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-prmisc.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-queue.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-server.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-symbols.c: Moved to rtems/cpukit/libmisc.
* monitor/mon-task.c: Moved to rtems/cpukit/libmisc.
* monitor/monitor.h: Moved to rtems/cpukit/libmisc.
* monitor/symbols.h: Moved to rtems/cpukit/libmisc.
* mw-fb/.cvsignore: Moved to rtems/cpukit/libmisc.
* mw-fb/Makefile.am: Moved to rtems/cpukit/libmisc.
* mw-fb/mw_fb.c: Moved to rtems/cpukit/libmisc.
* mw-fb/mw_fb.h: Moved to rtems/cpukit/libmisc.
* mw-fb/mw_uid.c: Moved to rtems/cpukit/libmisc.
* mw-fb/mw_uid.h: Moved to rtems/cpukit/libmisc.
* rtmonuse/.cvsignore: Moved to rtems/cpukit/libmisc.
* rtmonuse/Makefile.am: Moved to rtems/cpukit/libmisc.
* rtmonuse/rtmonuse.c: Moved to rtems/cpukit/libmisc.
* rtmonuse/rtmonuse.h: Moved to rtems/cpukit/libmisc.
* serdbg/.cvsignore: Moved to rtems/cpukit/libmisc.
* serdbg/Makefile.am: Moved to rtems/cpukit/libmisc.
* serdbg/README: Moved to rtems/cpukit/libmisc.
* serdbg/serdbg.c: Moved to rtems/cpukit/libmisc.
* serdbg/serdbg.h: Moved to rtems/cpukit/libmisc.
* serdbg/serdbgcnf.h: Moved to rtems/cpukit/libmisc.
* serdbg/serdbgio.c: Moved to rtems/cpukit/libmisc.
* serdbg/termios_printk.c: Moved to rtems/cpukit/libmisc.
* serdbg/termios_printk.h: Moved to rtems/cpukit/libmisc.
* serdbg/termios_printk_cnf.h: Moved to rtems/cpukit/libmisc.
* shell/.cvsignore: Moved to rtems/cpukit/libmisc.
* shell/Makefile.am: Moved to rtems/cpukit/libmisc.
* shell/README: Moved to rtems/cpukit/libmisc.
* shell/cmds.c: Moved to rtems/cpukit/libmisc.
* shell/shell.c: Moved to rtems/cpukit/libmisc.
* shell/shell.h: Moved to rtems/cpukit/libmisc.
* stackchk/.cvsignore: Moved to rtems/cpukit/libmisc.
* stackchk/Makefile.am: Moved to rtems/cpukit/libmisc.
* stackchk/README: Moved to rtems/cpukit/libmisc.
* stackchk/check.c: Moved to rtems/cpukit/libmisc.
* stackchk/internal.h: Moved to rtems/cpukit/libmisc.
* stackchk/stackchk.h: Moved to rtems/cpukit/libmisc.
* untar/.cvsignore: Moved to rtems/cpukit/libmisc.
* untar/Makefile.am: Moved to rtems/cpukit/libmisc.
* untar/README: Moved to rtems/cpukit/libmisc.
* untar/untar.c: Moved to rtems/cpukit/libmisc.
* untar/untar.h: Moved to rtems/cpukit/libmisc.
* wrapup/.cvsignore: Moved to rtems/cpukit/libmisc.
* wrapup/Makefile.am: Moved to rtems/cpukit/libmisc.
* capture/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* cpuuse/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* devnull/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* dummy/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* dumpbuf/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* monitor/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mw-fb/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* rtmonuse/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* serdbg/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shell/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* stackchk/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* untar/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* capture/Makefile.am: Use .$(OBJEXT) instead of .o.
* cpuuse/Makefile.am: Use .$(OBJEXT) instead of .o.
* devnull/Makefile.am: Use .$(OBJEXT) instead of .o.
* dummy/Makefile.am: Use .$(OBJEXT) instead of .o.
* dumpbuf/Makefile.am: Use .$(OBJEXT) instead of .o.
* monitor/Makefile.am: Use .$(OBJEXT) instead of .o.
* mw-fb/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtmonuse/Makefile.am: Use .$(OBJEXT) instead of .o.
* serdbg/Makefile.am: Use .$(OBJEXT) instead of .o.
* shell/Makefile.am: Use .$(OBJEXT) instead of .o.
* stackchk/Makefile.am: Use .$(OBJEXT) instead of .o.
* untar/Makefile.am: Use .$(OBJEXT) instead of .o.
* devnull/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dummy/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dumpbuf/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mw-fb/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rootfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shell/Makefile.am: Remove AUTOMAKE_OPTIONS.
* untar/Makefile.am: Remove AUTOMAKE_OPTIONS.
* untar/Makefile.am: Use 'PREINSTALL_FILES ='.
* monitor/Makefile.am: Use 'PREINSTALL_FILES ='.
* shell/Makefile.am: Use 'PREINSTALL_FILES ='.
* devnull/Makefile.am: Use 'PREINSTALL_FILES ='.
* dumpbuf/Makefile.am: Use 'PREINSTALL_FILES ='.
* mw-fb/Makefile.am: Use 'PREINSTALL_FILES ='.
* stackchk/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtmonuse/Makefile.am: Use 'PREINSTALL_FILES ='.
* cpuuse/Makefile.am: Use 'PREINSTALL_FILES ='.
* rootfs/Makefile.am: Use 'PREINSTALL_FILES ='.
* mw-fb\Makefile.am: Corrected problem.
* untar/Makefile.am, monitor/Makefile.am, dummy/Makefile.am,
devnull/Makefile.am, dumpbuf/Makefile.am, mw-fb/Makefile.am,
stackchk/Makefile.am, rtmonuse/Makefile.am, cpuuse/Makefile.am:
* cpuuse/Makefile.am, dummy/Makefile.am, dumpbuf/Makefile.am,
monitor/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am,
untar/Makefile.am, wrapup/Makefile.am, mw-fb/Makefile.am:
Include compile.am.
* Added generic Micro FrameBuffer interface for MicroWindows.
This interface allows MicroWindows to under RTEMS. A sample
driver has been developed for the pc386 BSP. See
pc386/fb_vga.c as a sample.
* Added Uniform Input Device interface for MicroWindows.
See PC386 bsp for sample drivers for mouse and keyboard (console).
* mw-bf: New directory.
* Makefile.am, configure.in, wrapup/Makefile.am: Account for mw-fb.
* mw-fb/Makefile.am: New file.
* mw-fb/mw_fb.c: New file.
* mw-fb/mw_fb.h: New file.
* mw-fb/mw_uid.c: New file.
* mw-fb/mw_uid.h: New file.
