* shell/cmds.c, shell/shell.c: Remove fileno-hacks.
* monitor/mon-symbols.c: Remove #undef __STRICT_ANSI__.
* monitor/mon-command.c: Use #if defined(RTEMS_UNIX).
* untar/Makefile.am, monitor/Makefile.am, dummy/Makefile.am,
devnull/Makefile.am, dumpbuf/Makefile.am, mw-fb/Makefile.am,
stackchk/Makefile.am, rtmonuse/Makefile.am, cpuuse/Makefile.am:
* monitor/mon-driver.c: Accounted for addition of "_entry" to
fields in rtems_driver_address_table.
* cpuuse/Makefile.am, dummy/Makefile.am, dumpbuf/Makefile.am,
monitor/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am,
untar/Makefile.am, wrapup/Makefile.am, mw-fb/Makefile.am:
Include compile.am.
that breaks when the target has 16 bit address space. One of the H8
multilibs is a 16-bit address space CPU. When a real attempt is
made to support this CPU model, the code that assumes an address
is 32 bits will have to change. This constant is probably not
flagging all impacted code.
to:
I have also added the ability to register and unregister commands. This
allows me to create a set of monitor commands for the network stack plus
basic memory dump/patch commands (needs a working probe interface). I
will also look at a basic ls/cd/rm/mv/cp command set at some stage.
I have been thinking about changing the monitor in the future to more
like a light weight RTEMS shell, `eshell' for embedded shell. This is a
story for another day but is a process or getting the commands to map to
the filesystem (eg, major=commands, minor=command) and supporting an
environment. The filesystem provide a structure for the commands.
that contains:
* Removes MKLIB
handling)
converted to automake.
to convert the libmisc directory from Makefile.in to Makefile.am.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
configuration and unix/posix:
c/src/lib/libc/Makefile.in
only (was completely broken).
Linux-posix.cfg.
of other bsp's/CPU.
cd <srcdir>
and
cd c/src/lib; autoconf
or
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
it work.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
unsigned numbers.
to lib/include.
be resolved.
proper include files added.
from the application code, this file required more visibility than
is given by default to application code.
like signal dispatching.
correct Information block.
