path: root/c/src/libmisc/monitor (follow)
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | This patch is the most scary of all proposals I've been mailing to you this week until now. It consists of 3 parts: 1. a patch 2. a perl script (acpolish) 3. a shell script wrapper to invoke the perl-script. The perl-script reads in each Makefile.in and modifies them ("polishes/beautifies" them :-). These modifications are not easy to describe: Basically, it hard-codes some automake Makefile-variables and rules into RTEMS autoconf-Makefile.ins (Note: autoconf vs. automake!!) and converts some settings/variables to configure scripts' requirements (Yes, plural). E.g. it adds the automake standard variables $top_builddir and $subdir, adds dependency rules for automatic re-generation of Makefiles from Makefile.in, adds support variables for relative paths to multiple configure scripts etc. The patch is a one-line patch to enable the support of the new features added by acpolish. The shell script is a wrapper which pokes around inside of the source tree for Makefile.ins and invokes acpolish on all autoconf-Makefile.ins. acpolish is designed to be able to run several times on the same Makefile.in and may once become a more general tool to convert RTEMS Makefile.in to automake. Therefore, I'd like to keep it inside of source tree. (e.g. as contrib/acpolish or c/update-tools/acpolish). However, it doesn't make sense to export it outside of RTEMS. To apply this: cd <source-tree> patch -p1 -E < <path-to-patch>/rtems-rc-19990318-1.diff tar xzvf <path-to>/rtems-rc-polish.tar.gz ./rtems-polish.sh ./autogen Note: The path contrib/acpolish is hard-coded into rtems-polish.sh, if you decide to put it in an alternative place, please modify rtems-polish.sh to reflect this change. Later: cvs rm make/rtems.cfg (It isn't used anymore) cvs add contrib cvs add contrib/acpolish cvs commit I've tested this intensively, but naturally I can't exclude bugs. Ralf. PS.: Most probably, this is the last "Towards automake" patch. The next one probably will be a real automake patch.
* Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-02-181-1/+3
* Added --disable-multiprocessing flag and modified a lot of files to makeJoel Sherrill1998-11-233-1/+20
| | | | it work.
* Increased stack space of the monitor task.Joel Sherrill1998-04-061-1/+1
* Corrected Linux port for glibc2Joel Sherrill1998-01-301-1/+2
* Solaris port updates from Chris JohnsJoel Sherrill1998-01-231-6/+6
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-201-1/+1
* Fixed indexing bug reported by Phil Wilshire.Joel Sherrill1997-12-071-1/+1
* Removed warnings.Joel Sherrill1997-11-292-1/+6
* Fixed a number of warnings regarding comparisons between signed andJoel Sherrill1997-10-214-9/+9
| | | | unsigned numbers.
* Fixed endian problem in printing object names.Joel Sherrill1997-10-211-0/+5
* Removed include directory at "build" point and the link of this directoryJoel Sherrill1997-10-081-1/+1
| | | | | | to lib/include. Went to using a PROJECT_INCLUDE variable.
* Cleaned up as part of adding the Monitor test.Joel Sherrill1997-09-2118-28/+22
* changed signed int to unsigned int to eliminate a warning.Joel Sherrill1997-04-071-1/+1
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+57
| | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved.
* casts added to numerous arguments, prototypes corrected, andJoel Sherrill1996-09-1810-22/+27
| | | | proper include files added.
* added initial posix configuration supportJoel Sherrill1996-05-282-11/+12
* updates from Tony BennettJoel Sherrill1996-04-2217-164/+94
* As part of reducing visibility into rtems and hiding the .inl filesJoel Sherrill1996-03-067-0/+7
| | | | | from the application code, this file required more visibility than is given by default to application code.
* Update from Tony Bennett (tbennett@divnc.com)Joel Sherrill1996-01-177-76/+75
* updates from Tony Bennett for PA and UNIX portsJoel Sherrill1996-01-153-16/+27
* all targets compile .. tony's patches in placeJoel Sherrill1995-09-293-29/+29
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-192-4/+4
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-115-14/+28
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-281-4/+4
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1995-08-231-1/+1
| | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
* + Added object type field to object id.Joel Sherrill1995-08-181-3/+7
| | | | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. + Added parameter "object class" to calls to Initialize Information
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-1718-223/+3174
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* Ada95, gnat, go32Joel Sherrill1995-07-121-1/+1
* Initial revisionJoel Sherrill1995-05-115-0/+759
