* monitor/mon-command.c: Don't build rtems_monitor_line_editor for
RTEMS_UNIX to avoid gcc warning.
* capture/capture.c, monitor/mon-manager.c, stackchk/check.c:
Patch to remove problems introduced by object name rework.
* capture/Makefile.am: Use .$(OBJEXT) instead of .o.
* cpuuse/Makefile.am: Use .$(OBJEXT) instead of .o.
* devnull/Makefile.am: Use .$(OBJEXT) instead of .o.
* dummy/Makefile.am: Use .$(OBJEXT) instead of .o.
* dumpbuf/Makefile.am: Use .$(OBJEXT) instead of .o.
* monitor/Makefile.am: Use .$(OBJEXT) instead of .o.
* mw-fb/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtmonuse/Makefile.am: Use .$(OBJEXT) instead of .o.
* serdbg/Makefile.am: Use .$(OBJEXT) instead of .o.
* shell/Makefile.am: Use .$(OBJEXT) instead of .o.
* stackchk/Makefile.am: Use .$(OBJEXT) instead of .o.
* untar/Makefile.am: Use .$(OBJEXT) instead of .o.
* capture/capture-cli.c, cpuuse/cpuuse.c, monitor/mon-monitor.c,
monitor/mon-object.c, monitor/monitor.h: Corrected use of
_Objects_Information_table now that it is a two dimensional
array based upon API and class. In addition, in the monitor,
corrected an error which occured when a target has 64 bit pointers.
* monitor/mon-command.c: Per PR192 the RTEMS monitor makes everything
lowercase. The capture engine need to set triggers or watches on task
with uppercase names.
Also stop the monitor repeating command when enter is pressed.
* monitor/mon-monitor.c: Replace done with return (gcc3).
* devnull/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dummy/Makefile.am: Remove AUTOMAKE_OPTIONS.
* dumpbuf/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mw-fb/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rootfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shell/Makefile.am: Remove AUTOMAKE_OPTIONS.
* untar/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR148.
* monitor/mon-prmisc.c: Fixed to print task states correctly.
* untar/Makefile.am: Use 'PREINSTALL_FILES ='.
* monitor/Makefile.am: Use 'PREINSTALL_FILES ='.
* shell/Makefile.am: Use 'PREINSTALL_FILES ='.
* devnull/Makefile.am: Use 'PREINSTALL_FILES ='.
* dumpbuf/Makefile.am: Use 'PREINSTALL_FILES ='.
* mw-fb/Makefile.am: Use 'PREINSTALL_FILES ='.
* stackchk/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtmonuse/Makefile.am: Use 'PREINSTALL_FILES ='.
* cpuuse/Makefile.am: Use 'PREINSTALL_FILES ='.
* rootfs/Makefile.am: Use 'PREINSTALL_FILES ='.
* monitor/mon-command.c: Add support for partial command matching.
The monitor used to have this functionality before it was overhauled
to support addition of user commands.
* monitor/mon-prmisc.c: Correct print line.
* shell/Makefile.am: Added new file telnetd.c.
* shell/telnetd.c, shell/telnetd.h, shell/pty.c: New files.
* shell/shell.c, shell/cmds.c, shell/shell.h: Numerous improvments:
- The shell_init has a new parameter 'forever' because in
/dev/console you need that this process runs forever but in
tcp/ip not. (respawn?)
- A new task for every session opened trought tcp/ip telnet client.
(the chargen,daytime and more are possible of implementation but
I ask me if they are necesary)
- Exit from the session delete the task and when the client fails too.
- More cmds have been implemented. (very reduced version of these)
umask, chmod, id, whoami, rm, cat, ...
- A reduced line edit has been implemented.
Ctrl-C abort the input,
Ctrl-d in the first position gives EOF (logout).
'\b' and DEL makes the rubout operation.
I think that readline() for every session spents a lot of resources.
* shell/cmds.c, shell/shell.c: Remove fileno-hacks.
* monitor/mon-symbols.c: Remove #undef __STRICT_ANSI__.
* monitor/mon-command.c: Use #if defined(RTEMS_UNIX).
* untar/Makefile.am, monitor/Makefile.am, dummy/Makefile.am,
devnull/Makefile.am, dumpbuf/Makefile.am, mw-fb/Makefile.am,
stackchk/Makefile.am, rtmonuse/Makefile.am, cpuuse/Makefile.am:
* monitor/mon-driver.c: Accounted for addition of "_entry" to
fields in rtems_driver_address_table.
* cpuuse/Makefile.am, dummy/Makefile.am, dumpbuf/Makefile.am,
monitor/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am,
untar/Makefile.am, wrapup/Makefile.am, mw-fb/Makefile.am:
Include compile.am.
that breaks when the target has 16 bit address space. One of the H8
multilibs is a 16-bit address space CPU. When a real attempt is
made to support this CPU model, the code that assumes an address
is 32 bits will have to change. This constant is probably not
flagging all impacted code.
to:
I have also added the ability to register and unregister commands. This
allows me to create a set of monitor commands for the network stack plus
basic memory dump/patch commands (needs a working probe interface). I
will also look at a basic ls/cd/rm/mv/cp command set at some stage.
I have been thinking about changing the monitor in the future to more
like a light weight RTEMS shell, `eshell' for embedded shell. This is a
story for another day but is a process or getting the commands to map to
the filesystem (eg, major=commands, minor=command) and supporting an
environment. The filesystem provide a structure for the commands.
that contains:
* Removes MKLIB
handling)
converted to automake.
to convert the libmisc directory from Makefile.in to Makefile.am.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
configuration and unix/posix:
c/src/lib/libc/Makefile.in
only (was completely broken).
Linux-posix.cfg.
of other bsp's/CPU.
cd <srcdir>
and
cd c/src/lib; autoconf
or
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
it work.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
unsigned numbers.
to lib/include.
be resolved.
