path: root/c/src/libmisc/monitor/mon-server.c (follow)
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-1/+1
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-171-0/+305
(tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
