path: root/c/src/libmisc/devnull (follow)
* 2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-281-1/+1
| | | | | | | | | | | | | * untar/Makefile.am: Use 'PREINSTALL_FILES ='. * monitor/Makefile.am: Use 'PREINSTALL_FILES ='. * shell/Makefile.am: Use 'PREINSTALL_FILES ='. * devnull/Makefile.am: Use 'PREINSTALL_FILES ='. * dumpbuf/Makefile.am: Use 'PREINSTALL_FILES ='. * mw-fb/Makefile.am: Use 'PREINSTALL_FILES ='. * stackchk/Makefile.am: Use 'PREINSTALL_FILES ='. * rtmonuse/Makefile.am: Use 'PREINSTALL_FILES ='. * cpuuse/Makefile.am: Use 'PREINSTALL_FILES ='. * rootfs/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-131-1/+1
| | | | * devnull/devnull.c: Eliminate warning.
* 2001-04-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-201-10/+16
| | | | | | | * devnull/devnull.c (null_initialize): Added check to ensure that the driver is only initialized once. Otherwise, it will abort when the device /dev/null is present. (null_write): Do not dereference a NULL pointer.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-3/+4
| | | | | | | * untar/Makefile.am, monitor/Makefile.am, dummy/Makefile.am, devnull/Makefile.am, dumpbuf/Makefile.am, mw-fb/Makefile.am, stackchk/Makefile.am, rtmonuse/Makefile.am, cpuuse/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* 2001-01-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-054-0/+290
* devnull: New addition. Moved from libcpu/sh. * devnull/devnull.c, devnull/devnull.h, devnull/.cvsignore, devnull/Makefile.am: New files. * Makefile.am, configure.in, wrapup/Makefile.am: Modified to reflect addition of above.
