path: root/c/src/libmisc/ChangeLog (follow)
* 2001-09-19 Chris Johns <ccj@acm.org>Joel Sherrill2001-09-191-0/+9
| | | | | | | | | * Added support for populating the initial "root" filesystem with information obtained via the DHCP response. * rootfs: New directory. * rootfs/.cvsignore, rootfs/Makefile.am, rootfs/mkrootfs.c, rootfs/mkrootfs.h: New files. * configure.in, Makefile.am: Modified to reflect addition.
* 2001-09-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-141-0/+40
| | | | * ChangeLog: Fixed some mistakes.
* 2001-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-131-0/+4
| | | | * devnull/devnull.c: Eliminate warning.
* 2001-08-09 Fernando-Ruiz Casas <correo@fernando-ruiz.com>Joel Sherrill2001-08-091-0/+4
| | | | * shell/pty.c: Moved to libnetworking/rtems_telnetd.
* 2001-08-09 Fernando-Ruiz Casas <correo@fernando-ruiz.com>Joel Sherrill2001-08-091-0/+5
| | | | | * shell/Makefile.am, shell/README, shell/cmds.c, shell/shell.c, shell/shell.h: Updates.
* 2001-08-09 Keith Outwater <vac4050@cae597.rsc.raytheon.com>Joel Sherrill2001-08-091-0/+6
| | | | | | * monitor/mon-command.c: Add support for partial command matching. The monitor used to have this functionality before it was overhauled to support addition of user commands.
* 2001-06-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-06-141-0/+7
| | | | | | | * shell/telnetd.c, shell/telnetd.h: Moved to libnetworking/rtems_servers so the network stack to address network depenendency. * shell/Makefile.am: Modified to reflect above.
* 2001-05-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-05-251-0/+4
| | | | * shell/cmds.c: Removed code from inappropriate source.
* 2000-05-24 Fernando Ruiz Casas <fernando.ruiz@ctv.es>Joel Sherrill2001-05-241-0/+21
| | | | | | | | | | | | | | | | | | | | | * monitor/mon-prmisc.c: Correct print line. * shell/Makefile.am: Added new file telnetd.c. * shell/telnetd.c, shell/telnetd.h, shell/pty.c: New files. * shell/shell.c, shell/cmds.c, shell/shell.h: Numerous improvments: - The shell_init has a new parameter 'forever' because in /dev/console you need that this process runs forever but in tcp/ip not. (respawn?) - A new task for every session opened trought tcp/ip telnet client. (the chargen,daytime and more are possible of implementation but I ask me if they are necesary) - Exit from the session delete the task and when the client fails too. - More cmds have been implemented. (very reduced version of these) umask, chmod, id, whoami, rm, cat, ... - A reduced line edit has been implemented. Ctrl-C abort the input, Ctrl-d in the first position gives EOF (logout). '\b' and DEL makes the rubout operation. I think that readline() for every session spents a lot of resources.
* 2001-04-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-071-1/+7
| | | | | * shell/cmds.c, shell/shell.c: Remove fileno-hacks. * monitor/mon-symbols.c: Remove #undef __STRICT_ANSI__.
* 2001-04-20 Correo Fernando-ruiz <correo@fernando-ruiz.com>Joel Sherrill2001-04-201-0/+6
| | | | | | | * Added initial shell functionality. * Makefile.am, configure.in, wrapup/Makefile.am: * shell/.cvsignore, shell/Makefile.am, shell/README, shell/cmds.c, shell/shell.c, shell/shell.h: New files.
* 2001-04-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-201-0/+7
| | | | | | | * devnull/devnull.c (null_initialize): Added check to ensure that the driver is only initialized once. Otherwise, it will abort when the device /dev/null is present. (null_write): Do not dereference a NULL pointer.
* 2001-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-121-0/+4
| | | | * monitor/mon-command.c: Use #if defined(RTEMS_UNIX).
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-0/+7
| | | | | | | * untar/Makefile.am, monitor/Makefile.am, dummy/Makefile.am, devnull/Makefile.am, dumpbuf/Makefile.am, mw-fb/Makefile.am, stackchk/Makefile.am, rtmonuse/Makefile.am, cpuuse/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* 2001-01-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-051-0/+8
| | | | | | | | * devnull: New addition. Moved from libcpu/sh. * devnull/devnull.c, devnull/devnull.h, devnull/.cvsignore, devnull/Makefile.am: New files. * Makefile.am, configure.in, wrapup/Makefile.am: Modified to reflect addition of above.
* 2000-11-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-301-0/+4
| | | | * mw-fb/mw_uid.c: Removed unnecessary dependency on <bsp.h>.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-0/+4
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-0/+4
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-251-0/+5
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-281-0/+5
| | | | | * monitor/mon-driver.c: Accounted for addition of "_entry" to fields in rtems_driver_address_table.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+7
| | | | | | | * cpuuse/Makefile.am, dummy/Makefile.am, dumpbuf/Makefile.am, monitor/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, untar/Makefile.am, wrapup/Makefile.am, mw-fb/Makefile.am: Include compile.am.
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-301-0/+6
| | | | | | * Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs.
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-301-0/+4
| | | | * mw-fb/.cvsignore: New file.
* 2000-08-26 Rosimildo da Silva <rdasilva@connecttel.com>Joel Sherrill2000-08-301-0/+16
| | | | | | | | | | | | | | | | * Added generic Micro FrameBuffer interface for MicroWindows. This interface allows MicroWindows to under RTEMS. A sample driver has been developed for the pc386 BSP. See pc386/fb_vga.c as a sample. * Added Uniform Input Device interface for MicroWindows. See PC386 bsp for sample drivers for mouse and keyboard (console). * mw-bf: New directory. * Makefile.am, configure.in, wrapup/Makefile.am: Account for mw-fb. * mw-fb/Makefile.am: New file. * mw-fb/mw_fb.c: New file. * mw-fb/mw_fb.h: New file. * mw-fb/mw_uid.c: New file. * mw-fb/mw_uid.h: New file.
