path: root/c/src/libfs/src (unfollow)
2000-02-11Increased block size to 128 and added comments based on feedback fromJoel Sherrill1-1/+13
Java folks including Oscar Martinez de la Torre <omt@wm.estec.esa.nl>.
2000-01-05Spacing corrected.Joel Sherrill1-1/+1
1999-11-17Updated copyright notice.Joel Sherrill35-70/+35
1999-11-16Added handler for fsync. For the memfile it is the same as the data sync.Jennifer Averett1-1/+1
1999-11-09Added imfs_unixstub.c to satisfy linker problems on UNIX port.Joel Sherrill1-0/+71
1999-11-05Correctly set and called handlers table for the link.Jennifer Averett1-1/+3
1999-11-05Fixed commentJennifer Averett1-1/+1
1999-11-05Moved imfs set handlers prototype to the imfs.h file.Jennifer Averett2-6/+4
1999-11-05New file.Joel Sherrill1-0/+38
1999-11-05Unmount was failing as a side-effect of splitting the rmnod handlerJoel Sherrill7-63/+102
and not handling every case properly.
1999-11-02The object memfile.o was being included in the miniIMFS even though itJoel Sherrill10-128/+227
should not have been. This required that IMFS_rmnod be split into three separate (per file type) routines to avoid dependencies. In the end, a miniIMFS application is 6K smaller than one using the full IMFS.
1999-11-02Fixed typo where memfile_handlers set twice and directory_handlersJoel Sherrill1-3/+3
was not set.
1999-11-02Properly initialize location variable.Joel Sherrill1-0/+8
1999-10-29Moved the rmnod callback from the operations table to the handler table.Jennifer Averett4-4/+14
1999-10-26New files created by split of old imfs_handlers.c.Joel Sherrill3-0/+111
1999-10-26Added initial cut at miniIMFS which leaves out memfile and directoryJoel Sherrill8-251/+219
readdir support. The next step is to add a mount table and configure either the miniIMFS or the full IMFS at the application level.
1999-10-25Patch from Eric Valette <valette@crf.canon.fr> and Emmanuel RaguetJoel Sherrill1-7/+8
<raguet@crf.canon.fr> to use a local variable.
1999-10-25Changed leading spaces to periods to ease comparing test output.Joel Sherrill1-1/+1
1999-10-12Spacing.Joel Sherrill1-0/+1
1999-10-12Split null handlers table to own file and renamed.Joel Sherrill4-10/+9
Renamed IMFS handler tables to include IMFS prefix.
1999-10-12Added rtems_filesystem_freenode() macro and added calls at appropriateJoel Sherrill1-4/+2
places to make sure memory allocated for filesystem specifif nodes gets freed.
1999-10-12Corrected mistakes in the IMFS file handlers table and added the missingJoel Sherrill2-0/+30
routine imfs_fcntl.c
1999-10-12Added call to freenod to let each filesystem free its own internalJoel Sherrill1-4/+16
node used to manage file access.
1999-06-14Warning removal from D. V. Henkel-Wallace <gumby@zembu.com>.Joel Sherrill1-6/+0
1999-05-27Removed usage of printf.Joel Sherrill1-1/+1
1999-03-31Removed asserts that shouldn't be called and commented case where thisJennifer Averett2-3/+2
indicates an internal error.
1999-03-08Corrected bug where pointer to doubly linked blocks was being incorrectlyJoel Sherrill1-2/+34
calculated.
1999-02-24Changed IMFS to use IMFS_NAME_MAX as the maximum length of a basenameJoel Sherrill7-23/+29
rather then NAME_MAX. NAME_MAX is 255 and that lets IMFS chew up memory too fast. Perhaps in the future, the places in IMFS that put a maximum length name string on the stack and the jnode structure does not include a maximu length name string can be fixed so this is not a problem.
1999-02-10Corrected multiple places the file size was not being properly updated.Joel Sherrill1-2/+8
1999-02-05Corrected spacing and added some new error checks that were neededJoel Sherrill1-9/+9
to avoid dereferencing NULLs.
1998-12-03Added imfs_fdatasync routine that gets called from both fdatasync and datasync.Jennifer Averett1-0/+26
1998-12-03Added a imfs fdatasync routine that gets called for fdatasync and datasync.Jennifer Averett1-0/+4
1998-12-03Modifications for RTEMS_UNIX.Jennifer Averett1-1/+10
1998-11-23Added base version of file system infrastructure. This includes a majorJoel Sherrill26-0/+4268
