* | Added rtems_filesystem_freenode() macro and added calls at appropriate | Joel Sherrill | 1999-10-12 | 1 | -4/+2 |
| | | | | | places to make sure memory allocated for filesystem specifif nodes gets freed. | ||||
* | Corrected mistakes in the IMFS file handlers table and added the missing | Joel Sherrill | 1999-10-12 | 2 | -0/+30 |
| | | | | routine imfs_fcntl.c | ||||
* | Added call to freenod to let each filesystem free its own internal | Joel Sherrill | 1999-10-12 | 1 | -4/+16 |
| | | | | node used to manage file access. | ||||
* | Warning removal from D. V. Henkel-Wallace <gumby@zembu.com>. | Joel Sherrill | 1999-06-14 | 1 | -6/+0 |
* | Removed usage of printf. | Joel Sherrill | 1999-05-27 | 1 | -1/+1 |
* | Removed asserts that shouldn't be called and commented case where this | Jennifer Averett | 1999-03-31 | 2 | -3/+2 |
| | | | | indicates an internal error. | ||||
* | Corrected bug where pointer to doubly linked blocks was being incorrectly | Joel Sherrill | 1999-03-08 | 1 | -2/+34 |
| | | | | calculated. | ||||
* | Changed IMFS to use IMFS_NAME_MAX as the maximum length of a basename | Joel Sherrill | 1999-02-24 | 7 | -23/+29 |
| | | | | | | | rather then NAME_MAX. NAME_MAX is 255 and that lets IMFS chew up memory too fast. Perhaps in the future, the places in IMFS that put a maximum length name string on the stack and the jnode structure does not include a maximu length name string can be fixed so this is not a problem. | ||||
* | Corrected multiple places the file size was not being properly updated. | Joel Sherrill | 1999-02-10 | 1 | -2/+8 |
* | Corrected spacing and added some new error checks that were needed | Joel Sherrill | 1999-02-05 | 1 | -9/+9 |
| | | | | to avoid dereferencing NULLs. | ||||
* | Added imfs_fdatasync routine that gets called from both fdatasync and datasync. | Jennifer Averett | 1998-12-03 | 1 | -0/+26 |
* | Added a imfs fdatasync routine that gets called for fdatasync and datasync. | Jennifer Averett | 1998-12-03 | 1 | -0/+4 |
* | Modifications for RTEMS_UNIX. | Jennifer Averett | 1998-12-03 | 1 | -1/+10 |
* | Added base version of file system infrastructure. This includes a major | Joel Sherrill | 1998-11-23 | 26 | -0/+4268 |
overhaul of the RTEMS system call interface. This base file system is the "In-Memory File System" aka IMFS. The design and implementation was done by the following people: + Joel Sherrill (joel@OARcorp.com) + Jennifer Averett (jennifer@OARcorp.com) + Steve "Mr Mount" Salitasc (salitasc@OARcorp.com) + Kerwin Wade (wade@OARcorp.com) PROBLEMS ======== + It is VERY likely that merging this will break the UNIX port. This can/will be fixed. + There is likely some reentrancy/mutual exclusion needed. + Eventually, there should be a "mini-IMFS" description table to eliminate links, symlinks, etc to save memory. All you need to have "classic RTEMS" functionality is technically directories and device IO. All the rest could be left out to save memory. |
