path: root/c/src/libfs/src/imfs/linearfile.c (follow)
* 2002-01-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-041-3/+4
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * src/imfs/imfs_eval.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * src/imfs/memfile.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * src/imfs/imfs_readlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * src/imfs/imfs_unlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * src/imfs/imfs_link.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * src/imfs/imfs_chown.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * src/imfs/ioman.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * src/imfs/imfs_mount.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * src/imfs/imfs_directory.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * src/imfs/imfs_stat.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * src/imfs/imfs_fchmod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * src/imfs/imfs_symlink.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * src/imfs/imfs_mknod.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * src/imfs/linearfile.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * src/imfs/imfs_unmount.c: Include <rtems/seterr.h>. Apply rtems_set_errno_and_return_minus_one. * src/imfs/imfs.h: Apply rtems_set_errno_and_return_minus_one. Comment out increment_and_check_linkcounts.
* 2001-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-221-0/+4
| | | | | | | * configure.in: Add src/imfs/config.h * src/imfs/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/imfs/.cvsignore: Add config.h and stamp-h * src/imfs/*.c: Add config.h support.
* 2000-12-12 Jake Janovetz <janovetz@uiuc.edu>Joel Sherrill2000-12-131-0/+110
* src/imfs/linearfile.c, src/imfs/imfs_load_tar.c: New files. * src/imfs/Makefile.am, src/imfs/imfs.h, src/imfs/imfs_creat.c, src/imfs/imfs_debug.c, src/imfs/imfs_eval.c, src/imfs/imfs_handlers_memfile.c, src/imfs/imfs_init.c, src/imfs/imfs_initsupp.c, src/imfs/imfs_stat.c, src/imfs/miniimfs_init.c: Added "tarfs". This is not really a tar filesystem. It is a way to load a tar image into the IMFS but actually leave bulky file contents in the original tar image. It essentially adds the linear file type and associated support and a loader routine.
