path: root/c/src/libfs/src/imfs/imfs_unlink.c (follow)
* Correctly set and called handlers table for the link.Jennifer Averett1999-11-051-1/+3
* Unmount was failing as a side-effect of splitting the rmnod handlerJoel Sherrill1999-11-051-3/+8
| | | | and not handling every case properly.
* The object memfile.o was being included in the miniIMFS even though itJoel Sherrill1999-11-021-2/+2
| | | | | | | should not have been. This required that IMFS_rmnod be split into three separate (per file type) routines to avoid dependencies. In the end, a miniIMFS application is 6K smaller than one using the full IMFS.
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+67
