path: root/c/src/libfs/src/imfs/imfs_getchild.c (follow)
* 2001-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-221-0/+4
| | | | | | | * configure.in: Add src/imfs/config.h * src/imfs/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/imfs/.cvsignore: Add config.h and stamp-h * src/imfs/*.c: Add config.h support.
* Removed asserts that shouldn't be called and commented case where thisJennifer Averett1999-03-311-1/+2
| | | | indicates an internal error.
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+68
