Renamed IMFS handler tables to include IMFS prefix.
rather then NAME_MAX. NAME_MAX is 255 and that lets IMFS chew up memory
too fast. Perhaps in the future, the places in IMFS that put a maximum
length name string on the stack and the jnode structure does not include
a maximu length name string can be fixed so this is not a problem.
to avoid dereferencing NULLs.
PROBLEMS
can/will be fixed.
