* | 2001-04-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-04-04 | 1 | -2/+1 |
| | | | | | * src/dosfs/Makefile.am: Per PR129 do not install as many files to the $(includedir). | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -1/+0 |
| | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * src/dosfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/imfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2002-03-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-20 | 1 | -1/+2 |
| | | | | | | | | | | | | | Addressing PR 140. * src/dosfs/config.h.in: Removed. * src/dosfs/stamp-h2.in: Removed. * .cvsignore: Add config.h*, stamp-h*. * configure.ac: Remove AC_SRC_DIR(.../dosfs.h). Remove AM_CONFIG_HEADER(src/dosfs/config.h). Remove AM_CONFIG_HEADER(src/imfs/config.h). Add AM_CONFIG_HEADER(config.h). * src/dosfs/Makefile.am: INCLUDES = -I../.. . * src/imfs/Makefile.am: INCLUDES = -I../.. . | ||||
* | 2002-03-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-15 | 1 | -39/+15 |
| | | | | | | Reported and tracked as PR130. * src/dosfs/Makefile.am: Reworked, Disable dosfs for UNIX. * wrapup/Makefile.am: Disable dosfs for UNIX. | ||||
* | 2002-02-28 Victor V. Vengerov <vvv@oktet.ru> | Joel Sherrill | 2002-02-28 | 1 | -0/+80 |
* DOS filesystem including FAT12, FAT16, and FAT32 support submitted. * src/dosfs, src/dosfs/Makefile.am, src/dosfs/stamp-h2.in, src/dosfs/config.h.in, src/dosfs/dosfs.h, src/dosfs/fat.c, src/dosfs/fat.h, src/dosfs/fat_fat_operations.c, src/dosfs/fat_fat_operations.h, src/dosfs/fat_file.c, src/dosfs/fat_file.h, src/dosfs/msdos.h, src/dosfs/msdos_create.c, src/dosfs/msdos_dir.c, src/dosfs/msdos_eval.c, src/dosfs/msdos_file.c, src/dosfs/msdos_free.c, src/dosfs/msdos_fsunmount.c, src/dosfs/msdos_handlers_dir.c, src/dosfs/msdos_handlers_file.c, src/dosfs/msdos_init.c, src/dosfs/msdos_initsupp.c, src/dosfs/msdos_misc.c, src/dosfs/msdos_mknod.c, src/dosfs/msdos_node_type.c, src/dosfs/.cvsignore: New files. * configure.ac, src/Makefile.am, wrapup/Makefile.am: Modified to reflect addition. |
