* | libchip/network/if_fxp.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -1/+1 | |
* | libchip/i2c/spi-memdrv.c: Do not use rtems_clock_get() | Joel Sherrill | 2015-03-17 | 1 | -7/+4 | |
* | libchip/serial: Fix warning | Sebastian Huber | 2015-03-05 | 1 | -2/+1 | |
* | libchip: Fix high capacity detection for MMC | Sebastian Huber | 2015-01-23 | 1 | -1/+1 | |
| | | | | Close #2239. | |||||
* | libchip/serial/z85c30.c: Remove redundant assignment | Josh Oguin | 2014-11-26 | 1 | -1/+0 | |
| | | | | This was flagged by CodeSonar. | |||||
* | libchip/serial/ns16550* and z8530*: Assert on baud number to avoid divide by 0 | Josh Oguin | 2014-11-26 | 3 | -1/+14 | |
| | | | | | | This was flagged by CodeSonar. It should be impossible to get an incorrect baud number back but ensure this in debug mode. The _Assert() keeps their scanner from evaluating for divide by 0 past this point. | |||||
* | libchip/display/disp_hcms29xx.c: Remove useless variable and check | Josh Oguin | 2014-11-26 | 1 | -6/+1 | |
* | Delete or rename MIN/MAX macros and defines | Sebastian Huber | 2014-11-21 | 1 | -1/+1 | |
| | | | | Include <sys/param.h> if necessary to get the MIN()/MAX() macros. | |||||
* | arm/nds: Warning clean up | Joel Sherrill | 2014-10-10 | 1 | -1/+3 | |
| | | | | | | This patch eliminates most of the warnings in this BSP but attempts very little clean up. This BSP includes copies of a lot of code from free NDS libraries and modifications should be kept to a minimum. | |||||
* | libchip/rtc/mc146818a.c: Compiles again and clean up | Joel Sherrill | 2014-10-10 | 1 | -6/+14 | |
* | libchip/rtc/mc146818a*: Fix prototypes to use uintptr_t and fix set but ↵ | Joel Sherrill | 2014-10-09 | 2 | -11/+17 | |
| | | | | unused warning | |||||
* | libchip/serial: Task driven mode for NS16550 | Sebastian Huber | 2014-10-07 | 2 | -12/+120 | |
* | libchip/serial: Fix NS16550 for pppstart() | Sebastian Huber | 2014-10-07 | 2 | -18/+40 | |
| | | | | | | | Call rtems_termios_dequeue_characters() only in case all characters of the last write handler invocation have been transmitted. This avoids problems with pppstart() since the start line discipline does not know how many characters have been dequeued and assumes the maximum. | |||||
* | libchip/serial: Add alternative NS16550 driver | Sebastian Huber | 2014-10-07 | 5 | -88/+798 | |
| | | | | Use the Termios device API. | |||||
* | libchip/dwmac: Use RTEMS_DEVOLATILE() | Sebastian Huber | 2014-09-08 | 1 | -4/+11 | |
* | Regenerate all preinstall.am files. | Chris Johns | 2014-08-29 | 1 | -6/+6 | |
| | | | | | With this patch the preinstall.am files are in a set order and not dependent on now perl implements a hash. | |||||
* | libchip/dwmac: Make PHY address user configurable | Christian Mauderer | 2014-08-22 | 3 | -12/+30 | |
| | | | | | | This patch allows the user to configure the PHY address for the DWMAC driver by giving a pointer to a dwmac_user_cfg structure to network stack via rtems_bsdnet_ifconfig::drv_ctrl. | |||||
* | GRETH: remove TCP/UDP HW checksum generation | Daniel Hellstrom | 2014-06-05 | 1 | -2/+2 | |
| | | | | The GRETH doesn't support IP fragments. | |||||
* | libchip: Add asserts to dwmac driver | Ralf Kirchner | 2014-04-30 | 1 | -0/+3 | |
* | libchip: Correct netstats message for dwmac driver | Ralf Kirchner | 2014-04-30 | 1 | -1/+1 | |
* | libchip: Correct error handling in dwmac driver | Ralf Kirchner | 2014-04-17 | 1 | -11/+4 | |
| | | | | By fault an rtems_status_code has been expected instead of an errno error number. | |||||
* | libchip: Reduce tx interrupts | Ralf Kirchner | 2014-04-17 | 4 | -222/+262 | |
| | | | | | | | Reduce number of packet transmitted interrupts by using the interrupt mechanism only if we run out of DMA descriptors. Under normal conditions regaining DMA descriptors, mbufs and clusters is handled via a counter. | |||||
* | libchip: Cleanup | Ralf Kirchner | 2014-04-17 | 1 | -2/+2 | |
* | libchip: Improve handling of DMA suspends | Ralf Kirchner | 2014-04-17 | 1 | -0/+1 | |
| | | | | Reset the corresponding DMA status bit | |||||
* | libchip: SMP support for NS16550 | Sebastian Huber | 2014-04-16 | 1 | -19/+22 | |
* | libchip: Avoid __DEVOLATILE() | Sebastian Huber | 2014-03-31 | 1 | -11/+9 | |
* | SPI SD-Card: adapt common driver code to block devices core API changes. | Pavel Pisa | 2014-03-31 | 1 | -3/+3 | |
* | greth: Make local functions static, remove overflow and correct printf call. | Daniel Cederman | 2014-03-21 | 1 | -6/+8 | |
* | smc91111: Move driver attach prototype to header file. | Daniel Cederman | 2014-03-21 | 2 | -3/+8 | |
| | | | | Also signal to compiler that the start variable in lan91cxx_recv is only used when debugging. | |||||
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 80 | -80/+80 | |
* | libchip: Relax buffer counts and add fatal error | Ralf Kirchner | 2014-03-14 | 1 | -2/+13 | |
* | libchip: Include <bsp.h> BSP options definition | Sebastian Huber | 2014-03-14 | 1 | -2/+2 | |
* | libchip: Check interrupt extension availability | Sebastian Huber | 2014-03-13 | 1 | -0/+13 | |
* | libchip: Avoid <bsp/utility.h> | Sebastian Huber | 2014-03-13 | 2 | -578/+612 | |
* | libchip: Add dwmac 10/100/1000 network driver | Ralf Kirchner | 2014-03-13 | 16 | -1/+6540 | |
* | sapi: Use one SMP lock for all chains | Sebastian Huber | 2014-03-11 | 1 | -1/+1 | |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | This partially reverts commit 1215fd4d9426a59d568560e9a485628560363133. In order to support profiling of SMP locks and provide a future compatible SMP locks API it is necessary to add an SMP lock destroy function. Since the commit above adds an SMP lock to each chain control we would have to add a rtems_chain_destroy() function as well. This complicates the chain usage dramatically. Thus revert the patch above. A global SMP lock for all chains is used to implement the protected chain operations. Advantages: * The SAPI chain API is now identical on SMP and non-SMP configurations. * The size of the chain control is reduced and is then equal to the Score chains. * The protected chain operations work correctly on SMP. Disadvantage: * Applications using many different chains and the protected operations may notice lock contention. The chain control size drop is a huge benefit (SAPI chain controls are 66% larger than the Score chain controls). The only disadvantage is not really a problem since these applications can use specific interrupt locks and unprotected chain operations to avoid this issue. | |||||
* | libchip/serial: Documentation | Sebastian Huber | 2014-01-23 | 1 | -10/+1 | |
* | SPI SD-Card: setup valid CRC-7 for STOP_TRANSMISSION command. | Pavel Pisa | 2013-10-08 | 1 | -0/+5 | |
| | | | | | | | | | | | | STOP_TRANSMISSION command is used to finish READ_MULTIPLE_BLOCK command and its format is regular command format. It requires valid CRC-7 to have effect at least on same cards types else it is ignored and attempt to issue next READ or WRITE commands results in illegal command condition (0x04) preceded by strange (0x3f) for tested card. Signed-off-by: Pavel Pisa <ppisa@pikron.com> | |||||
* | sapi: SMP support for chains | Sebastian Huber | 2013-08-30 | 1 | -1/+1 | |
| | | | | | | | | Add ISR lock to chain control for proper SMP protection. Replace rtems_chain_extract() with rtems_chain_explicit_extract() and rtems_chain_insert() with rtems_chain_explicit_insert() on SMP configurations. Use rtems_chain_explicit_extract() and rtems_chain_explicit_insert() to provide SMP support. | |||||
* | score: Merge tod implementation into one file | Sebastian Huber | 2013-07-26 | 2 | -5/+5 | |
| | | | | | Delete TOD_MICROSECONDS_PER_SECOND, TOD_MICROSECONDS_TO_TICKS() and TOD_MILLISECONDS_TO_TICKS(). | |||||
* | score: Merge sysstate API into one file | Sebastian Huber | 2013-07-24 | 3 | -0/+3 | |
* | Include missing <string.h> | Sebastian Huber | 2013-07-23 | 3 | -0/+3 | |
* | bsps/serial: Move bsp_console_select() declaration | Sebastian Huber | 2013-07-17 | 1 | -0/+7 | |
* | libchip/ata: Remove dead code | Sebastian Huber | 2013-07-16 | 1 | -58/+5 | |
* | libchip ns16550.c: Improve comment | Joel Sherrill | 2013-07-09 | 1 | -1/+4 | |
* | libchip/serial: Add const qualifier | Sebastian Huber | 2013-06-29 | 1 | -1/+1 | |
* | libchip/serial: Fix warning | Sebastian Huber | 2013-06-21 | 1 | -1/+0 | |
* | greth: do not advertise 1000M capability if MAC does not support it. | Jiri Gaisler | 2013-06-19 | 1 | -0/+11 | |
* | greth: prefer full duplex if available | Jiri Gaisler | 2013-06-19 | 1 | -3/+3 | |
* | libchip: Use Termios API change for NS16550 | Sebastian Huber | 2013-06-12 | 1 | -13/+9 | |
| | | | | This avoids a race condition on SMP configurations. |
