* | Use ioctl_command_t as ioctl argument. | Ralf Corsepius | 2006-12-14 | 2 | -3/+3 |
* | 2006-11-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-11-17 | 1 | -117/+0 |
| | | | | | * libchip/network/dec21140.c: Fix spacing -- remove long sections of blank lines. | ||||
* | *** empty log message *** | Joel Sherrill | 2006-09-11 | 5 | -117/+129 |
* | Remove extra CRLF. | Chris Johns | 2006-09-11 | 1 | -41/+41 |
* | 2006-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-09-04 | 4 | -5/+19 |
| | | | | | | * libchip/network/greth.c, libchip/network/open_eth.c, libchip/network/smc91111.c, libchip/network/sonic.c: Fix error introduced by warning removal. | ||||
* | 2006-09-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-09-01 | 3 | -3/+3 |
| | | | | | | * libchip/network/greth.c, libchip/network/open_eth.c, libchip/network/smc91111.c: Remove warnings and correct prototype added earlier today. | ||||
* | 2006-09-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-09-01 | 5 | -7/+12 |
| | | | | | | | * libchip/network/cs8900.c, libchip/network/greth.c, libchip/network/i82586.c, libchip/network/open_eth.c, libchip/network/sonic.c: Remove warnings -- use uintptr_t, properly sized integers, and inttypes.h printf helpers. | ||||
* | 2006-07-12 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-07-12 | 1 | -0/+3 |
| | | | | * libchip/shmdr/shm_driver.h: Merge sparc shm driver mods from 4.6. | ||||
* | 2006-07-11 Jerry Needell <jerry.needell@unh.edu> | Joel Sherrill | 2006-07-11 | 4 | -0/+788 |
| | | | | | | * libchip/Makefile.am, libchip/preinstall.am: Merge SPARC updates from 4.6 branch. Original modifications by Gaisler Enterprises. * libchip/network/greth.c, libchip/network/greth.h: New files. | ||||
* | applied patches for PR1117/1118/1119/1120 | Thomas Doerfler | 2006-07-09 | 2 | -3/+6 |
* | 2006-03-07 Thomas Doerfler <Thomas.Doerfler@embedded-brains.de> | Joel Sherrill | 2006-03-07 | 2 | -7/+169 |
| | | | | | | | PR 853/filesystem * libchip/ide/ata.c, libchip/ide/ide_controller.c: The ata driver should be modified to support the new exception scheme and to use the handle parameter. | ||||
* | Changes from Daron Chabot | Eric Norum | 2006-02-23 | 2 | -45/+87 |
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Replace illegal lvalue casts with explicit increments. | Eric Norum | 2006-01-12 | 1 | -5/+8 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+4 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | 2006-01-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-12 | 3 | -37/+26 |
| | | | | | | * libchip/Makefile.am: Build libchip/network/smc91111. * libchip/network/smc91111.c, libchip/network/smc91111config.h: Eliminate cyg_int* crap. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -7/+12 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-09 | 1 | -0/+8 |
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 2 | -17/+13 |
| | | | | | * libchip/network/open_eth.c, libchip/network/open_eth.h: Merger from rtems-4-6-branch. | ||||
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 5 | -4/+2297 |
| | | | | | | | | * libchip/network/smc91111.c libchip/network/smc91111config.h libchip/network/smc91111exp.h libchip/network/smc91111.h: New. Merger from rtems-4-6-branch. * libchip/Makefile.am: Reflect adding smc91111*. | ||||
* | 2006-01-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-08 | 2 | -5/+9 |
| | | | | | * libchip/i2c/i2c-2b-eeprom.c, libchip/i2c/i2c-ds1621.c: Eliminate warnings. | ||||
* | Reflect mii.h and if_media.h having moved. | Ralf Corsepius | 2005-11-14 | 2 | -4/+5 |
* | Regenerate. | Ralf Corsepius | 2005-11-14 | 1 | -8/+0 |
* | Reflect having moved libchip/network/mii.h and libchip/network/if_media.h. | Ralf Corsepius | 2005-11-14 | 1 | -2/+2 |
* | Remove (Moved to cpukit). | Ralf Corsepius | 2005-11-14 | 2 | -733/+0 |
* | Eliminate obsolete types. | Ralf Corsepius | 2005-11-06 | 2 | -3/+3 |
* | Use libcpu/byteorder.h for i386. | Ralf Corsepius | 2005-11-04 | 2 | -21/+8 |
* | Cosmetics | Ralf Corsepius | 2005-11-04 | 1 | -1/+2 |
* | Regenerate. | Ralf Corsepius | 2005-11-04 | 1 | -8/+9 |
* | 2005-11-02 straumanatslacdotstanford.edu | Till Straumann | 2005-11-03 | 6 | -0/+307 |
| | | | | | | | | | * libchip/i2c/i2c-2b-eeprom.c, libchip/i2c/i2c-2b-eeprom.h, libchip/i2c/i2c-ds1621.c, libchip/i2c/i2c-ds1621.h: New files. * libchip/Makefile.am, libchip/preinstall.am, wrapup/Makefile.am: added a simple API/library for i2c devices and drivers for i2c 2-byte eeproms and a ds1621 temperature sensor; API is documented in libi2c.h | ||||
* | Numerous changes and cleanups to support MVME2100. | Eric Norum | 2005-10-20 | 1 | -1/+1 |
* | Include <errno.h> instead of <sys/errno.h>. | Ralf Corsepius | 2005-09-19 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2005-09-19 | 1 | -1/+4 |
* | 2005-08-18 Karel Gardas <kgardas@objectsecurity.com> | Joel Sherrill | 2005-08-22 | 3 | -17/+0 |
| | | | | | * libchip/network/if_fxp.c, libchip/network/if_dc.c, libchip/network/dec21140.c: Remove initialization of PCI bus. | ||||
* | Regenerate. | Ralf Corsepius | 2005-08-15 | 1 | -0/+4 |
* | 2005-07-18 Karel Gardas <kgardas@objectsecurity.com> | Joel Sherrill | 2005-07-18 | 1 | -1/+1 |
| | | | | | * libchip/network/if_fxp.c: Change status of PCI Id 0x1229 from UNTESTED to tested. | ||||
* | 2005-06-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-06-17 | 1 | -7/+22 |
| | | | | | | * libchip/network/if_dc.c: Begin to convert to new PCI and IRQ interface. Also correct attempting to build on other than PowerPC and x86. | ||||
* | 2005-06-16 Daron Chabot <daron@nucleus.usask.ca> | Joel Sherrill | 2005-06-16 | 4 | -3/+5021 |
| | | | | | | * libchip/Makefile.am: Add driver for Tulip clones. * libchip/network/README.tulipclone, libchip/network/if_dc.c, libchip/network/if_dcreg.h: New files. | ||||
* | 2005-05-17 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 2005-05-17 | 2 | -2/+2 |
| | | | | | * ChangeLog, libchip/network/if_fxp.c, libchip/serial/ns16550.c: Modified to use rtems/irq.h. | ||||
* | Include preinstall.am. | Ralf Corsepius | 2005-05-11 | 1 | -123/+4 |
* | New. | Ralf Corsepius | 2005-05-11 | 1 | -0/+123 |
* | 2005-05-06 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 2005-05-06 | 4 | -8/+7 |
| | | | | | * libchip/network/open_eth.c, libchip/serial/mc68681.c, libchip/serial/ns16550.c, libchip/serial/z85c30.c: Removed warning | ||||
* | 2005-05-06 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 2005-05-06 | 3 | -12/+2 |
| | | | | | * libchip/network/dec21140.c, libchip/network/elnk.c, libchip/network/if_fxp.c: Moved irq.h to bsp subdirectory. | ||||
* | 2005-05-04 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 2005-05-04 | 2 | -33/+11 |
| | | | | | * libchip/network/dec21140.c, libchip/network/elnk.c: Consolidation of code as a result of the implementation of a common PCI interface. | ||||
* | 2005-05-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-05-04 | 1 | -6/+0 |
| | | | | * libchip/network/open_eth.c: Remove prototype of set_vector. | ||||
* | 2005-05-03 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 2005-05-03 | 4 | -5/+5 |
| | | | | | | * libchip/network/dec21140.c, libchip/network/elnk.c, libchip/network/if_fxp.c, libchip/serial/mc68681.c: Modified parameter list to remove warnings. | ||||
* | 2005-05-02 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 2005-05-02 | 5 | -6/+12 |
| | | | | | | | * libchip/network/cs8900.c, libchip/network/i82586.c, libchip/network/open_eth.c, libchip/network/sonic.c, libchip/serial/mc68681.c: Modified types to remove warnings. Added initialization to remove warnings. | ||||
* | 2005-04-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-04-28 | 1 | -2/+122 |
| | | | | | * libchip/network/README.sonic: Rewritten to account for removal of dmv177. |
