portion is now in the libchip tree and the dmv177 configuration is in
the dmv177 bsp. The performance impact of libchip'ing this driver
was minimal.
PROBLEMS
can/will be fixed.
with libchip.
of the SONIC driver to the new FreeBSD stack instead of KA9Q.
Fixed a comment.
busy. This type of behavior perturbs the tests and many of them will
not pass.
Corrected prototypes to reflect unsigned32 values being passed around
instead of unsigned8's.
Renamed port table.
Set time->ticks to 0.
Added function table.
version compiles cleanly but there is not a BSP with a configuration
table to utilize it.
and manage the interrupt sources like the other drivers. This
let use remove the ns16550_flush() routine.
Reworked transmit interrupt processing to remove ring buffer and
to mask the TX empty interrupt when it was not expected. This code
now uses termios to buffer TX output.
rather than doing repeated table lookups.
and to correctly set the TX active indicator.
than with a disable/enable pair.
Move some code around.
size of the minimum mc68681 driver. The clock speed field can not
now be configured as NULL but must instead specify the address of
the default table.
Added prototype for mc68681_build_imr(), mc68681_process(), and
mc68681_enable_interrupts().
the need for the ringbuffer manipulation in this driver. It should
also allow the removal of mc68681_flush. This greatly simplified the
interrupt processing.
Reworked Interrupt Mask Register handling. Added imr field to the device
context. This handling makes sure that the IMR accurately reflects the
state of the port in use and its mate. This required the reworking of
the mc68681_enable_interrupts() routine to allow for the specification
of which interrupt sources were being enabled/disabled.
Reworked initialization to reset using port address rather than chip
base address. Basically we were always resetting port 0.
Added deviceType field which allows for multiple chips of the same
class to have the same vector number.
The scheme used in the mc68681 is the one to follow.
driven.
Redid "mate determination" code to check that the chip base address was
the same but the port address was different.
Moved mc68681_process and mc68681_build_imr to the bottom of the file
so they would not be inlined.
Removed the code which forced mc68681_build_imr to always return 0 which
resulted in interrupts never being enabled from the chip.
Corrected spacing in prototype of mc68681_write_support_int.
