* network/Makefile.am: Use AM_*FLAGS += .. .
* ChangeLog: Fix formating.
* network/Makefile.am, rtc/Makefile.am, serial/Makefile.am:
Include compile.am.
<corsepiu@faw.uni-ulm.de> to use __i386__ instead of __i386 and i386
to be able to compile this file with -ansi.
that contains:
* Removes MKLIB
handling)
expansion. These macros were modified to correct warnings and
obviously needed more parentheses to expand correctly.
in the dec21140 driver. Comments follow:
I have tried to use bootp with the dec21140 driver
and I had problems. I have found them
- Ethernet address must be known in Attach step
(read from the board)
- Endian problem for Ethernet address storage.
Now it is solved and I can use bootp to obtain
the network configuration of the target.
dec21140 drivers from the i386/pc386 and powerpc/mcp750 (all Motorola
PowerPC boards) and move the network driver to libchip. This driver
should work on all PCI based uses of this chip.
Renamed file shmsupp/intr.c in some BSPs to shmsupp/cause_intr.c to
avoid conflict with rtems/src/intr.c (Classic API Interrupt Manager).
in the previous commits.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
rdir=/opt/rtems
cd $idir
find . -type f | while read file
do
if [ ! -f ${file} ] ; then
echo ${file} missing
fi
done
Jay Kulpinski <jskulpin@eng01.gdds.com>.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
dependencies of "Makefile".
--enable-maintainer-mode.
I added __INSIDE_RTEMS_BSD_TCPIP_STACK__ that trips all the needed
macro definitions for a network driver.
future.
cd <rtems-source-tree>
With my most recent automake patch (automake II) we could even simplify more
files below make/, because the host-compiler related parts of those files
aren't used anymore :-.
Whatsoever, the patch below should fix this problem.
Note: This is a mere bug fix, it doesn't move any of the variables involved
to target.cfg nor does it try to eliminate any variable.
interface naming convention.
fix some problems encountered when reusing this driver on
a SPARC ERC32 based Tharsys board. He eliminted the need
for TX interrupts and added code that can optionally ensure that
the IP address is 32-bit aligned. He also fixed a handful of
problems that only occured because the 8 Mhz ERC32 was
enough slower than the 100 Mhz PPC603e that timing
issues in this driver were magnified.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
by Jiri Gaisler <jgais@ws.estec.esa.nl> when using this
driver on a SPARC.
portion is now in the libchip tree and the dmv177 configuration is in
the dmv177 bsp. The performance impact of libchip'ing this driver
was minimal.
PROBLEMS
can/will be fixed.
with libchip.
of the SONIC driver to the new FreeBSD stack instead of KA9Q.
Fixed a comment.
busy. This type of behavior perturbs the tests and many of them will
not pass.
Corrected prototypes to reflect unsigned32 values being passed around
instead of unsigned8's.
Renamed port table.
Set time->ticks to 0.
Added function table.
