PR 607/networking
* libchip/network/dec21140.c: Made PCI configuration minimum sane
instead of fully specifying unused PCI features.
* libchip/network/if_fxp.c: Add include of <sys/errno.h>.
* PR/625/networking
* libchip/network/dec21140.c, ... : Prevent name clashes by making
'ld_le32()' etc. static inlines. Let dec21140 attach routine return
an error rather than panic if no chip is detected (thus allowing
for probing).
* libchip/network/elnk.c: Let elnk bail out if autoneg never completes
instead of looping forever. Avoid divide by zero (crashed my PC).
* libchip/network/if_fxp.c: Enable more fxp chip variants but warn that
they are UNTESTED.
* libchip/network/dec21140.c, libchip/network/elnk.c:
#include <errno.h>.
* libchip/network/if_media.h: Update from FreeBSD.
* libchip/network/open_eth.c, libchip/network/cs8900.c,
libchip/network/i82586.c: #include <errno.h>.
* librdbg/src/i386/rdbg_cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* librdbg/src/m68k/rdbg_cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* librdbg/src/powerpc/rdbg_cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* libchip/ide/ata.c: Include <rtems/chain.h> instead of <chain.h>.
* libchip/ide/ide_controller.c: Include <rtems/chain.h> instead of <chain.h>.
* libchip/shmdr/shm_driver.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>.
* libchip/serial/ns16550.c: Include <rtems/ringbuf.h> instead of <ringbuf.h>.
* libchip/ide/ata.c, libchip/network/dec21140.c,
libchip/network/elnk.c, libchip/network/i82586.c,
libchip/network/if_fxp.c, libchip/network/if_fxpvar.h,
libchip/network/open_eth.c, libchip/network/sonic.c,
libchip/rtc/icm7170.c, libchip/serial/ns16550.c,
libchip/serial/z85c30.c, libchip/shmdr/cnvpkt.c,
libchip/shmdr/init.c, libchip/shmdr/intr.c,
libchip/shmdr/shm_driver.h: Cosmetics.
PR/589 rtems
* libchip/network/pci.h: Remove (Moved to cpukit).
* libchip/ide/ata.c, libchip/ide/ata_internal.h,
libchip/ide/ide_controller.c, libchip/ide/ide_ctrl_cfg.h,
libchip/ide/ide_ctrl_io.h, libchip/network/cs8900.c,
libchip/network/dec21140.c, libchip/network/elnk.c,
libchip/network/if_fxp.c, libchip/network/open_eth.c,
libchip/network/open_eth.h, libchip/network/sonic.c,
libchip/network/sonic.h, libchip/rtc/icm7170.c, libchip/rtc/icm7170.h,
libchip/rtc/icm7170_reg.c, libchip/rtc/icm7170_reg2.c,
libchip/rtc/icm7170_reg4.c, libchip/rtc/icm7170_reg8.c,
libchip/rtc/m48t08.c, libchip/rtc/m48t08.h, libchip/rtc/m48t08_reg.c,
libchip/rtc/m48t08_reg2.c, libchip/rtc/m48t08_reg4.c,
libchip/rtc/m48t08_reg8.c, libchip/rtc/rtc.h, libchip/serial/mc68681.c,
libchip/serial/mc68681.h, libchip/serial/mc68681_reg.c,
libchip/serial/mc68681_reg2.c, libchip/serial/mc68681_reg4.c,
libchip/serial/mc68681_reg8.c, libchip/serial/ns16550.c,
libchip/serial/ns16550_p.h, libchip/serial/serial.h,
libchip/serial/z85c30.c, libchip/serial/z85c30.h,
libchip/serial/z85c30_p.h, libchip/serial/z85c30_reg.c,
libchip/shmdr/addlq.c, libchip/shmdr/cnvpkt.c, libchip/shmdr/dump.c,
libchip/shmdr/fatal.c, libchip/shmdr/getlq.c, libchip/shmdr/init.c,
libchip/shmdr/initlq.c, libchip/shmdr/intr.c, libchip/shmdr/poll.c,
libchip/shmdr/send.c, libchip/shmdr/shm_driver.h: Convert to using c99
fixed-size types.
support.
Minor formating clean up.
Add documentation to the header file.
* libchip/network/dec21140.c: Use __PPC__ instead of __PPC.
Cosmetics.
* libchipnetwork/open_eth.c: Remove warnings by conditionally
compiling this file only only those CPU families with supported
exception models.
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am,
wrapup/Makefile.am: Fix automake problems having been introduced
in previous patch.
* libchip/Makefile.am, librdbg/Makefile.am, optman/Makefile.am:
Preinstall dirs.
* wrapup/Makefile.am: Preinstall dirs. Cosmetics.
* aclocal/check-multiprocessing.m4: Cosmetics.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_ROOT.
* aclocal/project-root.m4: Remove obsolete comments. Remove PACKHEX.
* libchip/Makefile.am: Don't include lib.am.
* librdbg/src/i386/Makefile.am, librdbg/src/m68k/Makefile.am,
librdbg/src/powerpc/Makefile.am: Don't include lib.am. Remove
unnecessary EXTRA_DISTs.
* ChangeLog: Merge-in optman/ChangeLog.
* libchip/ChangeLog: Remove.
* Makefile.am: Fix typo in previous patch.
* Makefile.am: Use automake compilation rules.
* Makefile.am: Add shmdr. Use noinst_DATA instead of TMP_LIBS.
* shmdr/addlq.c, shmdr/cnvpkt.c, shmdr/dump.c, shmdr/fatal.c,
shmdr/getlq.c, shmdr/getpkt.c, shmdr/init.c, shmdr/initlq.c,
shmdr/intr.c, shmdr/mpci.h, shmdr/mpisr.c, shmdr/poll.c,
shmdr/README, shmdr/receive.c, shmdr/retpkt.c, shmdr/send.c,
shmdr/setckvec.c, shmdr/shm_driver.h: Copied from libbsp/shmdr.
* Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Fix variant-tmpinstall support.
* ide/Makefile.am, network/Makefile.am, rtc/Makefile.am,
serial/Makefile.am: Remove.
* Makefile.am: Merge-in Makefile.am above.
Add preinstallation + compilation dirstamp support.
* ide/Makefile.am: Remove all-local: $(ARCH).
* rtc/Makefile.am: Remove all-local: $(ARCH).
* serial/Makefile.am: Remove all-local: $(ARCH).
* ide/Makefile.am: Use dirstamps for preinstallation. Reformat.
* network/Makefile.am: Ditto.
* rtc/Makefile.am: Ditto.
* serial/Makefile.am: Ditto.
* network/open_eth.c: Remove #define OPEN_ETH_SUPPORTED (Unused).
PR 499/rtems_misc
* serial/mc68681.c: Miscellaneous corrections:
- Correction of ACR_BIT[7] (Baudrate table) Configuration
- Correction of Parity Bit Configuration (Odd was forced)
- Correction of Stop Bit configuration (inversed)
- Correction of ISR Handler to call
rtems_termios_dequeue_character() only if is a Tx Empty IRQ.
- Add RTS CTS Hardware flow control Configuration
* addlq.c, cnvpkt.c, dump.c, fatal.c, getlq.c, getpkt.c, init.c,
initlq.c, intr.c, mpci.h, mpisr.c, poll.c, receive.c, retpkt.c,
send.c, setckvec.c, shm_driver.h: URL for license changed.
* ide/ata.c, ide/ata.h, ide/ata_internal.h, ide/ide_controller.c,
ide/ide_ctrl.h, ide/ide_ctrl_cfg.h, ide/ide_ctrl_io.h,
network/cs8900.c, network/cs8900.c.bsp, network/cs8900.h,
network/dec21140.c, network/elnk.c, network/open_eth.c,
network/sonic.c, network/sonic.h, rtc/icm7170.c, rtc/icm7170.h,
rtc/icm7170_reg.c, rtc/icm7170_reg2.c, rtc/icm7170_reg4.c,
rtc/icm7170_reg8.c, rtc/m48t08.c, rtc/m48t08.h, rtc/m48t08_reg.c,
rtc/m48t08_reg2.c, rtc/m48t08_reg4.c, rtc/m48t08_reg8.c, rtc/rtc.h,
rtc/rtcprobe.c, serial/mc68681.c, serial/mc68681.h,
serial/mc68681_p.h, serial/mc68681_reg.c, serial/mc68681_reg2.c,
serial/mc68681_reg4.c, serial/mc68681_reg8.c, serial/serial.h,
serial/z85c30.c, serial/z85c30.h, serial/z85c30_p.h,
serial/z85c30_reg.c: URL for license changed.
PR 477/networking
* network/Makefile.am: Add driver for OpenCores NIC.
* network/README.open_eth, network/open_eth.c, network/open_eth.h:
New files.
* ide/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* network/cs8900.c: Correct copyright statements.
ide/Makefile.am: Reflect having moved automake.
rtc/Makefile.am: Reflect having moved automake.
serial/Makefile.am: Reflect having moved automake.
serial/Makefile.am: Add conditional LIBCHIP.
Conditionally build include-dirs.
* network/if_fxp.c: Replace deprecated b* funcs by mem* funcs.
PR 429/bsps
PR 432/bsps
* network/elnk.c: Due to a bug in the driver, if multiple packets
are queued onto an elnk board, the ISR will deadlock the device with
a tx complete interrupt. Lighter tx loads are not affected as they
end up submitting single packets to the device.
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am, ide/Makefile.am, network/Makefile.am,
rtc/Makefile.am, serial/Makefile.am:
Reflect having merged configure.ac into ../configure.ac
* network/dec21140.c, network/elnk.c: Update to compile on i386.
* network/README.3com: New file missed in previous commit.
