* | Switched to default probe routine. | Joel Sherrill | 1998-07-09 | 1 | -17/+2 | |
* | Added new baud rate to number function and default serial probe routine. | Joel Sherrill | 1998-07-09 | 4 | -0/+107 | |
| | | | | | Renamed sersupp.c so we could have one routine per file to decrease the baggage pulled into an application by default. | |||||
* | Added proper handling of extended baud rate table selection at boot time. | Joel Sherrill | 1998-07-09 | 1 | -1/+6 | |
| | | | | Still need to address default terminal settings. | |||||
* | Properly handle extended baud rate set commands. | Joel Sherrill | 1998-07-09 | 1 | -15/+22 | |
| | | | | | | | | | | | | | Temporarily "if 0" of code which enables interrupts. Moved setting of command registers at open but the current implementation is questionable. Added reset of RX errors while polling TX. Read polled character as unsigned. Baud rate mask must be in upper and lower nibble. | |||||
* | Corrected definition of MC68681_RX_BUFFER. | Joel Sherrill | 1998-07-09 | 1 | -1/+1 | |
* | Changed static to MC68681_STATIC to make all data and routines | Joel Sherrill | 1998-07-09 | 1 | -105/+192 | |
| | | | | | | | | | globally visiable to ease debugging. Added support for mc68681 "2 column" style baud rate table as well as the Exar 88681 "4 column" style baud rate table. Added support for user override of the default baud rate table. | |||||
* | Removed commented out line. | Joel Sherrill | 1998-07-09 | 1 | -1/+0 | |
* | Added sersupp.c. | Joel Sherrill | 1998-07-09 | 1 | -1/+1 | |
* | New files to contain generally needed serial driver support routines. | Joel Sherrill | 1998-07-09 | 1 | -0/+13 | |
* | Changed static to MC68681_STATIC to make all routines and data global | Joel Sherrill | 1998-07-09 | 1 | -11/+20 | |
| | | | | to ease debugging. | |||||
* | Added support for the Extended Baud Rate set control found in the | Joel Sherrill | 1998-07-09 | 1 | -2/+20 | |
| | | | | | | | Exar 88681 but not in the base 68681. Added support for user provided baud rate tables. This is needed when the board does not use the standard baud rate clock. | |||||
* | Changed static to NS16550_STATIC to make all routines and data global | Joel Sherrill | 1998-07-09 | 2 | -31/+40 | |
* | Changed static to Z85C30_STATIC so all data and routines could be global | Joel Sherrill | 1998-07-09 | 2 | -32/+41 | |
| | | | | for debugging purposes. | |||||
* | Added information to README.mc68681. | Joel Sherrill | 1998-07-09 | 3 | -3/+136 | |
| | | | | Created the basic README and the README.z85c30. | |||||
* | Added include of termios.h. | Joel Sherrill | 1998-07-05 | 1 | -0/+59 | |
| | | | | | Also added a block of comments above the console_tbl structure to explain each entry. | |||||
* | Removed RTS and DTR handling code since the MC68681 seems to only have | Joel Sherrill | 1998-06-23 | 3 | -249/+91 | |
| | | | | | | | | | | automatic handling of RTS/CTS. This only protects the on-chip buffers and FIFOs -- not the termios queues as the RTS/CTS code in here did. It may be necessary in the future to enable this automatic support. Interrupt processing code added. In some places, channel and duart base addresses were swapped. | |||||
* | New file describing mc68681 libchip driver. | Joel Sherrill | 1998-06-23 | 1 | -0/+39 | |
* | Added numerous comments. | Joel Sherrill | 1998-06-23 | 1 | -15/+72 | |
* | Added concept of "mate" -- the other port on the same DUART. This is | Joel Sherrill | 1998-06-23 | 3 | -46/+80 | |
| | | | | | needed to properly handle the interrupt mask register since it is shared. | |||||
* | Added close. | Joel Sherrill | 1998-06-23 | 1 | -4/+28 | |
* | Added set attributes and written initialize and first open. | Joel Sherrill | 1998-06-23 | 1 | -78/+236 | |
* | Added more registers. | Joel Sherrill | 1998-06-23 | 1 | -0/+11 | |
* | Added set attributes prototype. | Joel Sherrill | 1998-06-23 | 1 | -0/+5 | |
* | Added NULL entry for setAttributes. | Joel Sherrill | 1998-06-23 | 3 | -2/+7 | |
* | Added initial part of iniitialization. | Joel Sherrill | 1998-06-22 | 2 | -8/+36 | |
* | Added mc68681 stuff to the makefile. | Joel Sherrill | 1998-06-22 | 4 | -90/+344 | |
| | | | | | | | | | Added numerous constants to mc68681_p.h. Changed spacing. At this point the polled support is in but nothing else is right except the structure. | |||||
* | Moved get and set register/data typedefs to this file. | Joel Sherrill | 1998-06-22 | 1 | -4/+14 | |
* | Moved set and get Register and Data type defininitions to serial.h. | Joel Sherrill | 1998-06-22 | 4 | -20/+5 | |
| | | | | Cleaned up spacing. | |||||
* | Corrected spacing | Joel Sherrill | 1998-06-22 | 1 | -26/+25 | |
* | spacing changes | Joel Sherrill | 1998-06-22 | 3 | -31/+36 | |
* | Added comments and corrected spacing. | Joel Sherrill | 1998-06-22 | 3 | -197/+213 | |
* | Added a comment and cleaned up spacing | Joel Sherrill | 1998-06-22 | 2 | -50/+63 | |
* | Initial version of these files. | Joel Sherrill | 1998-06-22 | 3 | -0/+735 | |
* | Initial incarnation of libchip compiles. | Joel Sherrill | 1998-06-13 | 4 | -9/+84 | |
* | Base code from ppcn_60x BSP | Joel Sherrill | 1998-06-13 | 7 | -0/+2184 | |
* | Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros for | Joel Sherrill | 1998-03-24 | 1 | -7/+7 | |
| | | | | the CPU family name constants. | |||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 17 | -17/+17 | |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 17 | -34/+34 | |
* | First attempt at values for PPC | Joel Sherrill | 1997-08-04 | 1 | -0/+3 | |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 17 | -85/+85 | |
| | | | | of switching to the modified GNU GPL. | |||||
* | added mips64orion entries for SHM_LOCK_VALUE and SHM_UNLOCK_VALUE | Joel Sherrill | 1996-09-08 | 1 | -0/+5 | |
* | added code to insure that delay is always non-zero | Joel Sherrill | 1996-05-23 | 1 | -0/+2 | |
* | Fixed so now supports more than 16 nodes. Tested for up to 24 nodes | Joel Sherrill | 1996-04-22 | 2 | -1/+10 | |
| | | | | by Tony Bennett. Information table is now malloc'ed. | |||||
* | updates from Tony Bennett for PA and UNIX ports | Joel Sherrill | 1996-01-15 | 2 | -6/+2 | |
* | all targets compile .. tony's patches in place | Joel Sherrill | 1995-09-29 | 4 | -3/+10 | |
* | Modified UNIX simulator port so all references to native unix | Joel Sherrill | 1995-09-27 | 1 | -0/+1 | |
| | | | | | stuff is in the executive source proper in the file cpu.c. This should help avoid conflicts between RTEMS POSIX files and UNIX files. | |||||
* | posix support initially added | Joel Sherrill | 1995-09-26 | 1 | -1/+1 | |
* | moving files around and adding the exec/wrapup directory | Joel Sherrill | 1995-09-22 | 1 | -1/+1 | |
* | The word "RTEMS" almost completely removed from the core. | Joel Sherrill | 1995-09-11 | 3 | -14/+8 | |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API. | |||||
* | Support for variable length names added to Object Handler. This supports | Joel Sherrill | 1995-08-23 | 1 | -1/+1 | |
| | | | | | | both fixed length "raw" names and strings from the API's point of view. Both inline and macro implementations were tested. |
