Close #2742.
The network interface driver for this module is located in the new
network stack (libbsd), see file "if_dwc.c".
Rename _ISR_Disable() into _ISR_Local_disable(). Rename _ISR_Enable()
into _ISR_Local_enable(). Remove _Debug_Is_owner_of_giant().
This is a preparation to remove the Giant lock.
Update #2555.
GCC 6.0 previews give the following warning on sonic.c:
../../../../../rtems/c/src/libchip/network/sonic.c:837:11: warning:
statement is indented as if it were guarded by... [-Wmisleading-indentation]
This was discussed here:
https://lists.rtems.org/pipermail/devel/2016-March/014004.html
and we concluded it would be better to rewrite the entire snippet.
This first step eliminates the following as public APIs for the pc386
BSP:
+ pcib_conf_read8
+ pcib_conf_read16
+ pcib_conf_read32
+ pcib_conf_write8
+ pcib_conf_write16
+ pcib_conf_write32
The if_fxp.c driver uses these enough where I provided local macros
to allow the code to be mostly unmodified. On other architectures
these names have been used privately. It will take multiple patches
to completely eliminate these symbols from the RTEMS source tree.
The focus of the first effort is just to eliminate these as a public
pc386 API so support can be added for systems without legacy PCI BIOS.
Close #2239.
This was flagged by CodeSonar.
This was flagged by CodeSonar. It should be impossible to get an
incorrect baud number back but ensure this in debug mode. The _Assert()
keeps their scanner from evaluating for divide by 0 past this point.
Include <sys/param.h> if necessary to get the MIN()/MAX() macros.
This patch eliminates most of the warnings in this BSP but attempts
very little clean up. This BSP includes copies of a lot of code
from free NDS libraries and modifications should be kept to a minimum.
unused warning
Call rtems_termios_dequeue_characters() only in case all characters of
the last write handler invocation have been transmitted. This avoids
problems with pppstart() since the start line discipline does not know
how many characters have been dequeued and assumes the maximum.
Use the Termios device API.
This patch allows the user to configure the PHY address for the DWMAC
driver by giving a pointer to a dwmac_user_cfg structure to network
stack via rtems_bsdnet_ifconfig::drv_ctrl.
The GRETH doesn't support IP fragments.
By fault an rtems_status_code has been expected instead of an errno error number.
Reduce number of packet transmitted interrupts by using the interrupt mechanism only
if we run out of DMA descriptors.
Under normal conditions regaining DMA descriptors, mbufs and clusters is handled
via a counter.
Reset the corresponding DMA status bit
Also signal to compiler that the start variable in lan91cxx_recv is only used when debugging.
This partially reverts commit 1215fd4d9426a59d568560e9a485628560363133.
In order to support profiling of SMP locks and provide a future
compatible SMP locks API it is necessary to add an SMP lock destroy
function. Since the commit above adds an SMP lock to each chain control
we would have to add a rtems_chain_destroy() function as well. This
complicates the chain usage dramatically. Thus revert the patch above.
A global SMP lock for all chains is used to implement the protected
chain operations.
Advantages:
* The SAPI chain API is now identical on SMP and non-SMP
configurations.
* The size of the chain control is reduced and is then equal to the
Score chains.
* The protected chain operations work correctly on SMP.
Disadvantage:
* Applications using many different chains and the protected operations
may notice lock contention.
The chain control size drop is a huge benefit (SAPI chain controls are
66% larger than the Score chain controls). The only disadvantage is not
really a problem since these applications can use specific interrupt
locks and unprotected chain operations to avoid this issue.
STOP_TRANSMISSION command is used to finish READ_MULTIPLE_BLOCK
command and its format is regular command format.
It requires valid CRC-7 to have effect at least on
same cards types else it is ignored and attempt
to issue next READ or WRITE commands results in
illegal command condition (0x04) preceded by strange
(0x3f) for tested card.
Signed-off-by: Pavel Pisa <ppisa@pikron.com>
Add ISR lock to chain control for proper SMP protection. Replace
rtems_chain_extract() with rtems_chain_explicit_extract() and
rtems_chain_insert() with rtems_chain_explicit_insert() on SMP
configurations. Use rtems_chain_explicit_extract() and
rtems_chain_explicit_insert() to provide SMP support.
TOD_MILLISECONDS_TO_TICKS().
