* libchip/serial/ns16550.c: Revert previous commit and extend existing
mechanic.
* libchip/serial/ns16550.c, libchip/serial/ns16550_p.h: Support i386
style IRQs.
* libchip/network/smc91111config.h:
* src/libchip/network/dec21140.c, src/libchip/network/elnk.c,
src/libchip/network/greth.c, src/libchip/network/greth.h,
src/libchip/network/open_eth.c: Fix typo where license said
found in found in.
* libchip/ide/ata.c: Fix spelling.
* libchip/serial/ns16550.c: Install interrupt handler after TTY
pointer is valid.
* libchip/ide/ata.c: Do not violate chain API.
* libchip/network/greth.c, libchip/network/open_eth.c: Add constants
for buffer modes.
* libchip/ide/ata_internal.h: C++ compatibility.
* libchip/Makefile.am, libchip/preinstall.am: Install
<libchip/ata_internal.h>.
* libchip/ide/ata_util.c: New file.
* libchip/Makefile.am: Reflect change from above.
* libchip/ide/ata.c: Moved ata_breq_init(), ata_identify_device(), and
ata_process_request_on_init_phase() into new file.
* libchip/ide/ata_internal.h, libchip/ide/ata.c: Moved code into
separate functions. Added public ata_breq_init(),
ata_identify_device(), and ata_process_request_on_init_phase()
functions.
PR 1586/misc
* libchip/i2c/spi-sd-card.h, libchip/i2c/spi-sd-card.c: Add retries to
SD card accesses.
PR 1580/misc
* libchip/i2c/spi-sd-card.c: Use bigger chunks and yield processor
while waiting for read data.
PR 1579/misc
* libchip/i2c/spi-sd-card.c: Gradually increasing sleep times when
waiting for write to finish.
PR 1567/misc
* libchip/i2c/spi-sd-card.h, libchip/i2c/spi-sd-card.c: Fixed
timeouts.
PR 1576/misc
* libchip/i2c/spi-sd-card.c: Enable CRC checks.
PR 1569/misc
* libchip/i2c/spi-sd-card.c: Added CRC checks.
PR 1557/misc
* libchip/i2c/spi-sd-card.c: Fixed low capacity special case.
* libchip/network/if_dc.c: Fix warning.
* libchip/network/greth.c: Misc. hacks to allow compilation on
16bit targets.
PR 1531/newlib
* libchip/network/i82586.c:
Add local copy of ALIGN().
* libchip/network/cs8900.c:
Misc. changes to make code 16bit-target compliant.
Use int32_t instead of int for 16bit-target compliance.
* libchip/network/open_eth.c:
* libchip/i2c/spi-sd-card.c, libchip/ide/ata.c: PR
1448/filesystem.
* libchip/network/if_dc.c: Remove warnings.
* libchip/serial/mc68681.c, libchip/serial/mc68681_reg.c,
libchip/serial/ns16550.c, libchip/serial/serial.h,
libchip/serial/z85c30.c, libchip/serial/z85c30_reg.c: Use uintptr_t
or intptr_t instead of uint32_t or int32_t.
* libchip/rtc/ds1375-rtc.h, libchip/rtc/ds1375.c,
libchip/rtc/icm7170.c, libchip/rtc/icm7170_reg.c,
libchip/rtc/m48t08_reg.c, libchip/rtc/rtc.h: Use uintptr_t instead of
uint32_t.
* libchip/ide/ata.c: Change missed use of ATA_USE_OLD_EXCEPTIONS to
CPU_SIMPLE_VECTORED_INTERRUPTS.
* libchip/ide/ata.c: Use correct macro from RTEMS to determine whether
simple or PIC interrupt model.
* libchip/network/i82586.c: Readdress use of ctype methods per
recommendation from D.J. Delorie on the newlib mailing list. We
should pass an unsigned char into these methods.
* libchip/ide/ide_controller.c: Fix warnings for uninitialized
variable.
* libchip/network/i82586.c: Fix warnings for ctype methods.
* libchip/ide/ide_controller.c: Create the devices as block
devices.
* libchip/network/greth.c: Eliminate unused type
rtems_clock_time_value.
* libchip/network/dec21140.c: Warning elimination
(dec21140_softc->base now is an uint32_t).
* libchip/network/dec21140.c, libchip/network/elnk.c,
libchip/network/if_dc.c: Ensure PCI drivers are built on all
supported configurations. PowerPC conditionals were not current and
code was not being built on supported BSPs.
* libchip/network/smc91111.c: Formatting.
* libchip/ide/ata.c (rtems_ata_initialize): Avoid implicit cast to uint16_t.
* libchip/ide/ata.c (ata_non_data_request): Change arg from int to
uint32_t (16bit ints are too small).
* libchip/network/elnk.c: Use PRI*32 to print u_int32_t's.
