* libchip/ide/ata.c, c/src/libchip/ide/ata_internal.h: Remove the
multiblock support from the ATA driver. Multiblock at the disk
level should not be a global policy as a disk may have more than
one partition with different block sizes. An IDE driver could
decide to use the feature with DMA but this a driver specific
design choice. Fixed bugs relating to variable block sizes and
large block transfer.
* c/src/libchip/ide/ide_controller.c,
c/src/libchip/ide/ide_ctrl_cfg.h, c/src/libchip/ide/ide_ctrl_io.h:
Changed the block size to 32bits so blocks of 64K or bigger can be
transfered in a single driver call.
* libchip/ide/ata.c: Revert previous change. Not all ARM BSPs use a
shared irq.h yet and this breaks a significant number of them.
* libchip/ide/ata.c: Use simple vectored CPU macro to select interrupt
model.
* libchip/serial/z85c30.c, libchip/serial/ns16550.c,
libchip/serial/mc68681.c: Reflect termios_baud_to_number having been
renamed to rtems_termios_baud_to_number.
* libchip/serial/sersupp.h: Remove termios_baud_to_index,
termios_baud_to_number (duplicate prototypes).
Add C++-guards.
Include rtems/termiostypes.h.
* libchip/network/elnk.c: Convert calls to legacy routine
rtems_clock_get( RTEMS_CLOCK_GET_xxx, ..) to rtems_clock_get_xxx().
* libchip/shmdr/shm_driver.h: nios2 was not accounted for.
* libchip/ide/ata.c: Remove warning.
* libchip/i2c/spi-sd-card.c, libchip/ide/ata.c: Eliminate using the
GNU/Linux specific error numbers EBADRQC and ENOTBLK. Switch to
EINVAL and ENOTTY as appropriate.
* c/src/libchip/ide/ata.c: Fixed the bug that ignored slave
devices on an IDE bus and cleaned up the initialisation register
call.
* libchip/network/i82586.c: Fix warning in manner suggested by
Arnout Vandecappelle <arnout@mind.be> in
http://www.rtems.org/pipermail/rtems-users/2009-May/005460.html.
* libchip/network/if_dc.c: Fixed warnings.
* libchip/rtc/ds1375.c, libchip/rtc/mc146818a.c: Fix warnings. Reformat
as needed.
* libchip/ide/ata.c: Remove a detection test that fails in qemu.
* libchip/ide/ide_controller.c: Change the status detection and
add a message if the transfer fails. There is currently no error
handle at the IDE drvier level.
PR 1392/bsps
* libchip/i2c/spi-memdrv.c: SPI Memory driver. Fix but where writes
over multiple pages results in extra data being written.
* libchip/i2c/spi-sd-card.c: Added support for high capacity and MMC
cards.
* libchip/network/dec21140.c, libchip/network/elnk.c: Make sure this is
enabled on x86.
* libchip/i2c/spi-sd-card.h, libchip/i2c/spi-sd-card.c: Fixed
RTEMS_BLKDEV_CAPABILITIES ioctl which caused invalid multiple block
writes. Fixed integer type in device structure.
* libchip/serial/ns16550.c: Turn on ns16550_process() for
BSP_FEATURE_IRQ_LEGACY case also.
block I/O functions
* libchip/serial/ns16550_p.h: Remove prototype with no implementation.
* libchip/shmdr/dump.c, libchip/shmdr/init.c, libchip/shmdr/send.c,
libchip/shmdr/shm_driver.h: Cleanup and remove variables which
duplicated data.
* libchip/serial/ns16550.c: Add CVS-Id. Fix #define mess.
* libchip/network/i82586.c, libchip/network/smc91111config.h: Eliminate
all public use of TOD conversion routines.
function within a critical section for printk() compatibility.
* libchip/serial/ns16550.c: Enable interrupt code only for PowerPC or
BSPs that support this feature.
* libchip/serial/ns16550.c: Fix typo.
* libchip/serial/ns16550.c: Add not supported on arm even though it is
not simple vectored.
* libchip/serial/ns16550.c: Not currently supported on architectures
with simple vectored interrupt model.
handling. Various fixes for interrupt related routines. Added support for BSPs with IRQ extension API.
linkage type. Added constant qualifier to operations table and read-only function parameters.
* libchip/network/dec21140.c, libchip/network/elnk.c: Detect when there
is no PCI bus based upon the BSP not having a base address defined.
This means this driver cannot be supported on that board.
* libchip/network/dec21140.c, libchip/network/elnk.c,
libchip/network/if_dc.c: Eliminate vestiges of mpc603e define.
* libchip/Makefile.am, libchip/shmdr/init.c, libchip/shmdr/mpisr.c,
libchip/shmdr/poll.c, libchip/shmdr/shm_driver.h: Update shared
memory driver to not use the clock ioctl to install a method to poll
for input. It now uses a Class API Timer which means we can eliminate
this special IOCTL from all clock drivers.
* libchip/shmdr/setckvec.c: Removed.
* libchip/network/sonic.c: Do not declare a variable just to hold an
ignored return value.
* libchip/i2c/spi-sd-card.c: Fixed integer conversion warnings.
* libchip/display/disp_hcms29xx.c: Initialize softc_ptr to NULL.
* libchip/network/dec21140.c, libchip/network/if_dc.c: Use uint32_t.
* libchip/display/disp_hcms29xx.c: Do not make these static. They
appear to be unused that way.
* libchip/shmdr/shm_driver.h: Correct prototypes.
* libchip/display/disp_hcms29xx.c: Fixed warnings. Initialized
variables and made methods static.
