path: root/c/src/libchip/shmdr (follow)
* updates from Tony Bennett for PA and UNIX portsJoel Sherrill1996-01-152-6/+2
* all targets compile .. tony's patches in placeJoel Sherrill1995-09-294-3/+10
* Modified UNIX simulator port so all references to native unixJoel Sherrill1995-09-271-0/+1
| | | | | stuff is in the executive source proper in the file cpu.c. This should help avoid conflicts between RTEMS POSIX files and UNIX files.
* posix support initially addedJoel Sherrill1995-09-261-1/+1
* moving files around and adding the exec/wrapup directoryJoel Sherrill1995-09-221-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-113-14/+8
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-173-13/+23
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* minor clean up -- switched to memset for zero'ing SHMJoel Sherrill1995-08-114-60/+54
* Fully tested on all in-house targetsJoel Sherrill1995-05-242-12/+21
* Initial revisionJoel Sherrill1995-05-1118-0/+1433
