path: root/c/src/libchip/shmdr (follow)
* 2000-09-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-251-0/+3
| | | | * shmdr/shm_driver.h: Added _AM29K entry. May not be correct.
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Renamed shm.h to shm_driver.h to avoid conflicts with POSIX shm.h.Joel Sherrill1999-11-3017-19/+19
| | | | | Renamed file shmsupp/intr.c in some BSPs to shmsupp/cause_intr.c to avoid conflict with rtems/src/intr.c (Classic API Interrupt Manager).
* Updated copyright notice.Joel Sherrill1999-11-1717-34/+17
* Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros forJoel Sherrill1998-03-241-7/+7
| | | | the CPU family name constants.
* updated copyright to 1998Joel Sherrill1998-02-1717-17/+17
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-0817-34/+34
* First attempt at values for PPCJoel Sherrill1997-08-041-0/+3
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-2217-85/+85
* added mips64orion entries for SHM_LOCK_VALUE and SHM_UNLOCK_VALUEJoel Sherrill1996-09-081-0/+5
* added code to insure that delay is always non-zeroJoel Sherrill1996-05-231-0/+2
* Fixed so now supports more than 16 nodes. Tested for up to 24 nodesJoel Sherrill1996-04-222-1/+10
| | | | by Tony Bennett. Information table is now malloc'ed.
* updates from Tony Bennett for PA and UNIX portsJoel Sherrill1996-01-152-6/+2
* all targets compile .. tony's patches in placeJoel Sherrill1995-09-294-3/+10
* Modified UNIX simulator port so all references to native unixJoel Sherrill1995-09-271-0/+1
| | | | | stuff is in the executive source proper in the file cpu.c. This should help avoid conflicts between RTEMS POSIX files and UNIX files.
* posix support initially addedJoel Sherrill1995-09-261-1/+1
* moving files around and adding the exec/wrapup directoryJoel Sherrill1995-09-221-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-113-14/+8
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-173-13/+23
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* minor clean up -- switched to memset for zero'ing SHMJoel Sherrill1995-08-114-60/+54
* Fully tested on all in-house targetsJoel Sherrill1995-05-242-12/+21
* Initial revisionJoel Sherrill1995-05-1118-0/+1433
