| | | | | | | * addlq.c, cnvpkt.c, dump.c, fatal.c, getlq.c, getpkt.c, init.c, initlq.c, intr.c, mpci.h, mpisr.c, poll.c, receive.c, retpkt.c, send.c, setckvec.c, shm_driver.h: URL for license changed. | ||||
* | Renamed shm.h to shm_driver.h to avoid conflicts with POSIX shm.h. | Joel Sherrill | 1999-11-30 | 1 | -1/+1 |
| | | | | | Renamed file shmsupp/intr.c in some BSPs to shmsupp/cause_intr.c to avoid conflict with rtems/src/intr.c (Classic API Interrupt Manager). | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 1 | -1/+1 |
* | moving files around and adding the exec/wrapup directory | Joel Sherrill | 1995-09-22 | 1 | -1/+1 |
* | Numerous miscellaneous features incorporated from Tony Bennett | Joel Sherrill | 1995-08-17 | 1 | -11/+12 |
| | | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables | ||||
* | minor clean up -- switched to memset for zero'ing SHM | Joel Sherrill | 1995-08-11 | 1 | -3/+4 |
* | Fully tested on all in-house targets | Joel Sherrill | 1995-05-24 | 1 | -9/+20 |
* | Initial revision | Joel Sherrill | 1995-05-11 | 1 | -0/+40 |
