path: root/c/src/libchip/shmdr/mpci.h (follow)
* Renamed shm.h to shm_driver.h to avoid conflicts with POSIX shm.h.Joel Sherrill1999-11-301-2/+2
| | | | | Renamed file shmsupp/intr.c in some BSPs to shmsupp/cause_intr.c to avoid conflict with rtems/src/intr.c (Classic API Interrupt Manager).
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-2/+2
* minor clean up -- switched to memset for zero'ing SHMJoel Sherrill1995-08-111-1/+1
* Initial revisionJoel Sherrill1995-05-111-0/+59
