With the addition of dynamically registered libchip serial devices,
there is the need to be able to use printk() before the console driver
has initialized the indirect pointer table. This lets printk() support
routines call pass a control structure directly without a lookup through
the uninitialized indirect one.
* libchip/serial/mc68681.c (mc68681_open):
Var "status" needs to be signed.
PR 1934/bsps
* libchip/serial/ns16550.c: Change to unsigned variable.
* libchip/serial/serial.h: Declare Console_Port_Minor.
PR 1944/misc
* libchip/serial/mc68681.c: Remove #if 0.
* libchip/serial/ns16550.c (ns16550_init):
Remove unused var "ucTrash".
PR 1940/misc:
* libchip/serial/ns16550.c: Reflect changes to console-driver.
PR 1917/bsps
* libchip/serial/mc68681.c, libchip/serial/ns16550.c,
libchip/serial/serial.h, libchip/serial/z85c30.c: Modifications to
add dynamic tables for libchip serial drivers.
* libchip/serial/mc68681.c: Eliminate unused var "success".
* libchip/serial/z85c30.c: Eliminate unused var "dummy".
* libchip/serial/ns16550_p.h, libchip/serial/ns16550.c: Remove
interrupt handler during last close.
* libchip/serial/ns16550.c: Revert previous commit and extend existing
mechanic.
* libchip/serial/ns16550.c, libchip/serial/ns16550_p.h: Support i386
style IRQs.
* libchip/serial/ns16550.c: Install interrupt handler after TTY
pointer is valid.
* libchip/serial/mc68681.c, libchip/serial/mc68681_reg.c,
libchip/serial/ns16550.c, libchip/serial/serial.h,
libchip/serial/z85c30.c, libchip/serial/z85c30_reg.c: Use uintptr_t
or intptr_t instead of uint32_t or int32_t.
* libchip/serial/z85c30.c, libchip/serial/ns16550.c,
libchip/serial/mc68681.c: Reflect termios_baud_to_number having been
renamed to rtems_termios_baud_to_number.
* libchip/serial/sersupp.h: Remove termios_baud_to_index,
termios_baud_to_number (duplicate prototypes).
Add C++-guards.
Include rtems/termiostypes.h.
* libchip/serial/ns16550.c: Turn on ns16550_process() for
BSP_FEATURE_IRQ_LEGACY case also.
* libchip/serial/ns16550_p.h: Remove prototype with no implementation.
* libchip/serial/ns16550.c: Add CVS-Id. Fix #define mess.
function within a critical section for printk() compatibility.
* libchip/serial/ns16550.c: Enable interrupt code only for PowerPC or
BSPs that support this feature.
* libchip/serial/ns16550.c: Fix typo.
* libchip/serial/ns16550.c: Add not supported on arm even though it is
not simple vectored.
* libchip/serial/ns16550.c: Not currently supported on architectures
with simple vectored interrupt model.
handling. Various fixes for interrupt related routines. Added support for BSPs with IRQ extension API.
* libchip/serial/ns16550.c: Fix warning.
* libchip/Makefile.am: Move termios helper routines from libchip to
libcsupport. Add routine which makes it easy for a termios device
driver to inform termios of its default baud rate. This avoids
inconsistencies in later termios settings changes.
* libchip/serial/termios_baud2index.c,
libchip/serial/termios_baud2num.c: Removed.
removed timed abort in ns16550.c transmit code
many different versions of new exception handling code to shared sources.
* ChangeLog, libchip/network/if_fxp.c, libchip/serial/ns16550.c:
Modified to use rtems/irq.h.
* libchip/network/open_eth.c, libchip/serial/mc68681.c,
libchip/serial/ns16550.c, libchip/serial/z85c30.c: Removed warning
* libchip/network/dec21140.c, libchip/network/elnk.c,
libchip/network/if_fxp.c, libchip/serial/mc68681.c:
Modified parameter list to remove warnings.
* libchip/network/cs8900.c, libchip/network/i82586.c,
libchip/network/open_eth.c, libchip/network/sonic.c,
libchip/serial/mc68681.c: Modified types to remove
warnings. Added initialization to remove warnings.
PR 781/rtems_misc
* libchip/serial/ns16550_p.h: Fix baud rate calculation
Fixed warnings generated in various powerpc configurations
* libchip/serial/ns16550.c: Modified
ISR to work with PPC new exception processing
