* librdbg/src/i386/rdbg_cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* librdbg/src/m68k/rdbg_cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* librdbg/src/powerpc/rdbg_cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* libchip/ide/ata.c: Include <rtems/chain.h> instead of <chain.h>.
* libchip/ide/ide_controller.c: Include <rtems/chain.h> instead of <chain.h>.
* libchip/shmdr/shm_driver.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>.
* libchip/serial/ns16550.c: Include <rtems/ringbuf.h> instead of <ringbuf.h>.
* libchip/ide/ata.c, libchip/network/dec21140.c,
libchip/network/elnk.c, libchip/network/i82586.c,
libchip/network/if_fxp.c, libchip/network/if_fxpvar.h,
libchip/network/open_eth.c, libchip/network/sonic.c,
libchip/rtc/icm7170.c, libchip/serial/ns16550.c,
libchip/serial/z85c30.c, libchip/shmdr/cnvpkt.c,
libchip/shmdr/init.c, libchip/shmdr/intr.c,
libchip/shmdr/shm_driver.h: Cosmetics.
* libchip/ide/ata.c, libchip/ide/ata_internal.h,
libchip/ide/ide_controller.c, libchip/ide/ide_ctrl_cfg.h,
libchip/ide/ide_ctrl_io.h, libchip/network/cs8900.c,
libchip/network/dec21140.c, libchip/network/elnk.c,
libchip/network/if_fxp.c, libchip/network/open_eth.c,
libchip/network/open_eth.h, libchip/network/sonic.c,
libchip/network/sonic.h, libchip/rtc/icm7170.c, libchip/rtc/icm7170.h,
libchip/rtc/icm7170_reg.c, libchip/rtc/icm7170_reg2.c,
libchip/rtc/icm7170_reg4.c, libchip/rtc/icm7170_reg8.c,
libchip/rtc/m48t08.c, libchip/rtc/m48t08.h, libchip/rtc/m48t08_reg.c,
libchip/rtc/m48t08_reg2.c, libchip/rtc/m48t08_reg4.c,
libchip/rtc/m48t08_reg8.c, libchip/rtc/rtc.h, libchip/serial/mc68681.c,
libchip/serial/mc68681.h, libchip/serial/mc68681_reg.c,
libchip/serial/mc68681_reg2.c, libchip/serial/mc68681_reg4.c,
libchip/serial/mc68681_reg8.c, libchip/serial/ns16550.c,
libchip/serial/ns16550_p.h, libchip/serial/serial.h,
libchip/serial/z85c30.c, libchip/serial/z85c30.h,
libchip/serial/z85c30_p.h, libchip/serial/z85c30_reg.c,
libchip/shmdr/addlq.c, libchip/shmdr/cnvpkt.c, libchip/shmdr/dump.c,
libchip/shmdr/fatal.c, libchip/shmdr/getlq.c, libchip/shmdr/init.c,
libchip/shmdr/initlq.c, libchip/shmdr/intr.c, libchip/shmdr/poll.c,
libchip/shmdr/send.c, libchip/shmdr/shm_driver.h: Convert to using c99
fixed-size types.
* ide/Makefile.am, network/Makefile.am, rtc/Makefile.am,
serial/Makefile.am: Remove.
* Makefile.am: Merge-in Makefile.am above.
Add preinstallation + compilation dirstamp support.
* ide/Makefile.am: Remove all-local: $(ARCH).
* rtc/Makefile.am: Remove all-local: $(ARCH).
* serial/Makefile.am: Remove all-local: $(ARCH).
* ide/Makefile.am: Use dirstamps for preinstallation. Reformat.
* network/Makefile.am: Ditto.
* rtc/Makefile.am: Ditto.
* serial/Makefile.am: Ditto.
PR 499/rtems_misc
* serial/mc68681.c: Miscellaneous corrections:
- Correction of ACR_BIT[7] (Baudrate table) Configuration
- Correction of Parity Bit Configuration (Odd was forced)
- Correction of Stop Bit configuration (inversed)
- Correction of ISR Handler to call
rtems_termios_dequeue_character() only if is a Tx Empty IRQ.
- Add RTS CTS Hardware flow control Configuration
* ide/ata.c, ide/ata.h, ide/ata_internal.h, ide/ide_controller.c,
ide/ide_ctrl.h, ide/ide_ctrl_cfg.h, ide/ide_ctrl_io.h,
network/cs8900.c, network/cs8900.c.bsp, network/cs8900.h,
network/dec21140.c, network/elnk.c, network/open_eth.c,
network/sonic.c, network/sonic.h, rtc/icm7170.c, rtc/icm7170.h,
rtc/icm7170_reg.c, rtc/icm7170_reg2.c, rtc/icm7170_reg4.c,
rtc/icm7170_reg8.c, rtc/m48t08.c, rtc/m48t08.h, rtc/m48t08_reg.c,
rtc/m48t08_reg2.c, rtc/m48t08_reg4.c, rtc/m48t08_reg8.c, rtc/rtc.h,
rtc/rtcprobe.c, serial/mc68681.c, serial/mc68681.h,
serial/mc68681_p.h, serial/mc68681_reg.c, serial/mc68681_reg2.c,
serial/mc68681_reg4.c, serial/mc68681_reg8.c, serial/serial.h,
serial/z85c30.c, serial/z85c30.h, serial/z85c30_p.h,
serial/z85c30_reg.c: URL for license changed.
ide/Makefile.am: Reflect having moved automake.
rtc/Makefile.am: Reflect having moved automake.
serial/Makefile.am: Reflect having moved automake.
serial/Makefile.am: Add conditional LIBCHIP.
Conditionally build include-dirs.
* configure.ac: Remove (Merged into ../configure.ac).
* Makefile.am, ide/Makefile.am, network/Makefile.am,
rtc/Makefile.am, serial/Makefile.am:
Reflect having merged configure.ac into ../configure.ac
* network/Makefile.am: Eliminate C_O_FILES.
* serial/Makefile.am: Ditto,
* serial/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Don't use LIBC_DEFINES.
* rtc/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* serial/z85c30.c: Eliminated warning by clarifying statement.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtc/Makefile.am: Use .$(OBJEXT) instead of .o.
* serial/Makefile.am: Use .$(OBJEXT) instead of .o.
* serial/Makefile.am: Don't tmp-install lib.
* rtc/Makefile.am: Don't tmp-install lib.
* rtc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* serial/Makefile.am: Remove AUTOMAKE_OPTIONS.
* serial/z85c30.c: Fixed typo.
* rtc/Makefile.am: Use 'PREINSTALL_FILES ='.
* network/Makefile.am: Use 'PREINSTALL_FILES ='.
* serial/Makefile.am: Use 'PREINSTALL_FILES ='.
* serial/Makefile.am, serial/mc68681.c, serial/ns16550.c,
serial/serprobe.c, serial/z85c30.c: Now install sersupp.h
to <libchip/sersupp.h> so libchip style serial drivers can
be written in libcpu or libbsp.
* network/cs8900.c, network/cs8900.h, network/sonic.c, network/sonic.h,
rtc/icm7170_reg8.c, rtc/m48t08_reg.c, rtc/m48t08_reg2.c,
rtc/m48t08_reg4.c, rtc/m48t08_reg8.c, serial/mc68681_reg.c,
serial/mc68681_reg2.c, serial/mc68681_reg4.c, serial/mc68681_reg8.c,
serial/z85c30_reg.c: Corrected header.
* network/Makefile.am, rtc/Makefile.am, serial/Makefile.am:
Apply include_*HEADERS instead of H_FILES, replace ${..} with $(..).
Include compile.am.
that contains:
* Removes MKLIB
handling)
in the previous commits.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
Jay Kulpinski <jskulpin@eng01.gdds.com>.
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
PROBLEMS
can/will be fixed.
with libchip.
of the SONIC driver to the new FreeBSD stack instead of KA9Q.
Fixed a comment.
busy. This type of behavior perturbs the tests and many of them will
not pass.
