* | Added constants for z85c30_enable_interrupts. | Joel Sherrill | 1998-07-25 | 1 | -6/+17 |
* | Added set attributes routine but did not hook it in to the table. | Joel Sherrill | 1998-07-09 | 1 | -1/+5 |
| | | | | Switched to shared default probe. | ||||
* | Changed static to Z85C30_STATIC so all data and routines could be global | Joel Sherrill | 1998-07-09 | 1 | -14/+23 |
| | | | | for debugging purposes. | ||||
* | Added comments and corrected spacing. | Joel Sherrill | 1998-06-22 | 1 | -193/+194 |
* | Base code from ppcn_60x BSP | Joel Sherrill | 1998-06-13 | 1 | -0/+385 |
