* | Corrected spacing. | Joel Sherrill | 1998-07-28 | 1 | -13/+6 |
* | Removed TX ring buffer. | Joel Sherrill | 1998-07-25 | 1 | -2/+0 |
* | Changed comment on TxBuffer. | Joel Sherrill | 1998-07-25 | 1 | -1/+2 |
* | Added comment to remove use of TxBuffer ring buffer in all libchip drivers. | Joel Sherrill | 1998-07-15 | 1 | -1/+14 |
| | | | | The scheme used in the mc68681 is the one to follow. | ||||
* | Added include of termios.h. | Joel Sherrill | 1998-07-05 | 1 | -0/+59 |
| | | | | | Also added a block of comments above the console_tbl structure to explain each entry. | ||||
* | Added NULL entry for setAttributes. | Joel Sherrill | 1998-06-23 | 1 | -0/+1 |
* | Moved get and set register/data typedefs to this file. | Joel Sherrill | 1998-06-22 | 1 | -4/+14 |
* | Corrected spacing | Joel Sherrill | 1998-06-22 | 1 | -26/+25 |
* | spacing changes | Joel Sherrill | 1998-06-22 | 1 | -31/+31 |
* | Initial incarnation of libchip compiles. | Joel Sherrill | 1998-06-13 | 1 | -0/+78 |
