* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1 | -1/+2 |
* | Added ns16550_set_attributes. | Joel Sherrill | 1998-07-25 | 1 | -0/+5 |
* | Rewrote NS16550 TX interrupt processing to use termios for the buffer | Joel Sherrill | 1998-07-25 | 1 | -2/+9 |
| | | | | | and manage the interrupt sources like the other drivers. This let use remove the ns16550_flush() routine. | ||||
* | Changed static to NS16550_STATIC to make all routines and data global | Joel Sherrill | 1998-07-09 | 1 | -14/+23 |
| | | | | to ease debugging. | ||||
* | Moved set and get Register and Data type defininitions to serial.h. | Joel Sherrill | 1998-06-22 | 1 | -1/+0 |
| | | | | Cleaned up spacing. | ||||
* | Added a comment and cleaned up spacing | Joel Sherrill | 1998-06-22 | 1 | -49/+59 |
* | Base code from ppcn_60x BSP | Joel Sherrill | 1998-06-13 | 1 | -0/+208 |
